Question about Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher
Rough film on dishes
Dishes have a rough film on after wash, rinse and dry cycle. I have changed soaps and added jet dry. dishwasher is about ten years old
  • 523 Answers
First clean dw use tang then prime sink and run dw after that cut back on detergant
Posted on Jun 06, 2010
Please help! I just moved into a new house where the Frigidaire dishwasher worked great for 2 weeks. Now, it's leaving hard salt-like granules all over my dishes and not rinsing all the food off. ...
Your dishwasher has clogged water ports.
Start the dishwasher with NO dishes in it.
Once it starts the wash cycle,open the door and pour in 1 quart of WHITE vinegar and resume the wash cycle.
That should clear out the residue.
Change your dishwasher soap to the FINISH brand name for happy clean dishes.
Apr 28, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
After washing the dishes are not clean. There is a white film over-all. Our water is "hard." I have had this dishwasher several years.
It probably isn't a problem with the dishwasher.
Manufacturers of dishwashing detergents have recently been required to stop using phosphates, resulting in a lot of upset people complaining about the same thing you described.
You can try adding vinegar to the final rinse of the cycle, or you can install a water softener.
Mar 19, 2011 | Dishwashers
Dishes are not rinsing clean - leaving film and soap scum - seems as if not enough water preasure for rinse cycle or cables are clogged
I suspect that something has changed, say your water has become different if your water authority has changed the added chemicals or the source for your water supply. Another thing is the hot water heater may not be heating your water sufficently to do a through washing. This could happen if one of your heating elements have malfunctioned unless you heat water with gas. Also did you change your dishwasher detergent? Adding a rinse chemical to the cycle may help.
Dec 28, 2010 | Kenmore 24 in. 15312 Built-in Dishwasher
GE Triton XL dishwasher, at first I had the left over powder soap issue until I dismantled the lower spray arm and cleaned the nets and removed the rusty particles in the hole in bottom of washer and also...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Sep 25, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
Blue sticky spots in my dishwasher
some of the soaps out there are tempurture sensitive, several different ingrediants waiting on different temps during differnet times of the cycle,
I have seen this before or at least something similar,
does the soap your using now have the jet dry as part of it
if yes id go back to jet dry, your rinse cycle is not hot enough to fully disolve the jet dry in the soap, it gels and coaleses every where.
its designed to do that, so it will not just be washed down the drain on the wash cyle with the rest of the soap.....
Oct 11, 2009 | Dishwashers
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
There is a whitish film left on dishes/glasses/silverware after wash cycle is finished.
Are you using Jet Dri or another type of rinse agent? If not, that will become your main issue. These machines HAVE to have it, or they wont remove that film. Also, have you changed washing agent (soap) etc. You may be using a little to much. Other issues that can cause this are: bad drain or main pump unit, clogged drain hose, etc. Let me know if you need any other help or information.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Soap film on dishes
Rodney B if you are sure that the white film is detergent and not hard water deposits, then look at how you are using the detergent. When you watch the TV ads for dw detergents, they are showing baked on/extemely dirty dishes being put in the dishwasher and coming out clean. Well they do this as the dw detergent is designed to break down protein based food products. Fats, oils, and such. If you are prewashing your dishes before putting them in the dishwasher, then there is nothing for the detergent to attack and attach to, so it ends up staying in the dishwasher. If you are going to rinse your dishes, then you need only 1 tablespoon of detergent. Dishwashers are designed to clean using 4 parameters, hot water of 130 degrees, water, detergent,& pressure of the water jets. That is how they clean dishes. Now if this is hard water deposits, switching to an enviromently friendly detergent which is high is Citric Acid (What gives Tang drink its tartness) this will reduce this issue. Hope this helps
Jan 30, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Sep 23, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore 24 in. 15252 / 15254 / 15259 Built-in Dishwasher Logo
154 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
