Question about Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range
Jennair GS2526CEDB-11 side by side, has stopped making ice
4 Suggested Answers
elhomspam
  • 58 Answers
SOURCE: Jennair side-by-side
clean the coils
Posted on Apr 30, 2008
marka19
  • 1430 Answers
SOURCE: I have ice accumulating at the bottom of my
First make sure the door is sealing properly.
If it is at the bootom of the freezer behind the backpanel is a drain hole this has become clogged. To unclog try some warm water and a piece of wire. Pour in about a cup of warm water to melt the ice then run a wire down the tube. This is where the water from the defrost cycle goes. There is a drain pan underneath to catch the water. for a diagram go to www.appliancehelponline.com and enter your model #.
Posted on Mar 23, 2010
machinetech7
  • 1344 Answers
SOURCE: My Jennair JFC2087HRS suddenly stopped making ice. I already replaced the filter but still nothing. Now what?
More than likely the ice maker has gone out. The part nunber for that is going to be D7824706Q
Posted on May 27, 2012
Jcb 2059 Jen air fridge not cooling freezer o.k.
Its a defrost issue.The freezer works,then cooling starts and then its time to defrost.But in defrost the unit is not working.It can be faulty defrost assembly parts.Or the problem is with defrost timer at the lower back side of refrigerator.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Jennair jcd2289 side-by-side does not make ice
If you are getting water from the dispenser, then the water valve is good. The icemaker will need to be replaced since when the icemaker cycles and empties the ice tray, it should call for the water to refill and it is not doing so. Here is a link to the replacement icemaker.
Oct 16, 2012 | Refrigerators
May 26, 2012 | Jenn-Air JFC2087HRS Side by Side...
I have a luxury JennAir side-by-side stainless steel refrigerator (about 3 yrs old). 42" or so wide. I've had significant ice build-up in the freezer, around the fan unit. I have just turned the unit...
Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your refrigerator. Please send me an email through our customer service address,
NAR_JennAir_CustomerExperience@JennAir.com
and type 'Attention: Audrey' in the subject line. Please include your full name, phone number or email address, and model/serial number, and I would be happy to try to help resolve the situation with your appliance.
Oct 13, 2010 | Jenn-Air JSD2488G Side by Side...
I have ice accumulating at the bottom of my JennAir side by side refridgerator on the freeezer side. any idea why ?
Mar 23, 2010 | Jenn-Air JCD2389G Side by Side...
Jennair french door fridge: freezer too cold, refrigerator section warm
i'll try to help w/out a model number but here it goes. more then likely your ice-mkr has stopped.right? if so turn ice-mkr off and it should help w/your freezing problem in the freshfood side.now find out why your ice-mkr is not making ice. things to look for are
1.no water hook up or water turned off under the kitchen sink.
2. a cube stuck in the ice-mkr's ejecting teeth.
3. a defective ice-mkr. vist www.searspartsdirect.com and input your model #,then choose ice-mkr to buy it. good luck
Jul 12, 2009 | Jenn-Air JFC2089HE French Door...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jenn-Air http://www.jennair.com/catalog/product.jsp parentCat=2&cat=17&prod=155 Electric Range Logo
64 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
