Question about Samsung HL-P4667W 46" Rear Projection HDTV
TV HAS LINES ON THE SCREEN
THE HD CHANNELS ARE SHOWING PERFECT PICTURES BUT THE CABLE CHANNELS HAS LINES AND ARE FUZZY.
  • 505 Answers
Sounds like a scaler problem.
hd bypasses the scaler, any non hd will be bad, try other stuff like dvd and video games. if its consistent, you need a new digital main pcb
if not, let me know i can help
Posted on Jun 06, 2010
Nothing showing up on tv screen, only fuzzy lines
hi,
exactly the same problem here. I could suppose its a firmware problem because it happen with or without the hard disk. I also checked "stand alone" the hard disk and it works properly.
I'm trying to find if its possible to start an automatic firmware reloading from an external USB pen connected to box.
May 06, 2012 | LaCie 1TB LaCinema Mini HD
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
New flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
Jan 05, 2010 | Philips 23PF5320 23 in. HD-Ready LCD...
Vertical red lines apear on Sony XBR after Roku install
try re-botting your HDbox,also refit your scart lead to your box & t.v.
If you drop me an e-mail I will go through how to re-bot your box,if you don't know - re-botting your box helps pull in all the new software for your box - think it like a pc needing to update the programmes.
e-mail add.pbviewingsky@yahoo.ie.
Aug 07, 2009 | Televison & Video
My Vizio 42in. is really fuzzy
If the picture is clear when using a DVD and remains "fuzzy" only with cable, then either the cable is bad or the up-conmvert from standard def to Hidef is creating the "fuzz". Depending upon the method used by the set to perform the "up-convert", the noise you are seeing may be normal.
Dan
Jan 27, 2009 | Vizio L37 Television
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Horizontal problems
Its may due to problem on IFsection or tuner,afc problem
Jan 12, 2008 | RCA D52W19 52" Rear Projection Television
HD4208TIII-PDP 42'' Plasma TV
Your TV may not support your HD channel signal. Check with HD DVD & non-HD DVD players to confirm.
Jan 01, 2008 | SVA-USA HD4208TIII-PDP 42 in. EDTV-Ready...
Screen blacks out on HD channels
Saying that the problem is with your TV doesn't make any sense since your TV is fed from the cable box.  Your TV doesn't know one channel from the next.  If it had a problem it would effect all channels.  You may not have enough signal to the INPUT of your cable box due to a problem on the pole or at your house or both.  Insufficient signal can cause some digital channels to not get decoded properly by the cable box.  The lower channels will show noise symptoms such as what you describe but they won't crap out altogether like the digital ones.  Have a cable tech come out and measure the signals.
Do you have splitters in line with the cable anywhere?  If there's any way to beef up the amount of signal getting to the cable box try it.
Oct 15, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Snowy picture on certain channels and only sometimes
Hello, the best option for you is to put another (small) TV instead of plasma to check whether your cable is OK. If you need more info please advice. Arpi
Mar 16, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Samsung HL-P4667W 46" Rear Projection HDTV Logo
102 people viewed this question
Jerry Greenberg
Jerry Greenberg
