Question about Traulsen UR48DT-6 Refrigerator/Freezer - Self-Contained
I have a Traulsen Refrigerator Freezer in a home installation with a separate comressor skid installed in the garage. I am havinf difficulty with the frezer compressor. Should I repair the freexer compressor or have the entire freezer/refrigerator skid replaced? Thanks TimTyson
    President:
  • 2,702 Answers
At the end of the day its all down to costs
first ask yourself how old is this compressor?
how much to fix it and re-gass it?
if you pay to fix it, how much life is left in the old girl?
how much for a new compressor?
now,,,how much life will be in that one???? years!
not a hard choice,,but all down to costs!
Posted on Jun 06, 2010
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)...
Regardless of the design...
THERE are only two reasons for excessive FROST.
- massive air intrusion (check seals & gaskets)
- defective defrost circuit (check defrost timer/controller)...
EZ trouble to fix...
Post comment reply: 7/3/2016...
In general... there are only three elements to the defrost circuit:
- 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present).
- 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all).
- 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).
Anytime you don't feel you've got this surrounded just comment me back... I'll be around.
Go to Bing homepage
http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
Jul 02, 2016 | Traulsen Freezers
Is it worth fixing a 30 yr old Traulsen commercial reach in refrigerator/freezer? The compressor on the freezer needs replacing but the refrigerator is working fine.
Is there a compressor for the refrigerator separate from the freezer? Weigh the cost of repairs against the cost of a new unit, then decide.
Mar 16, 2016 | Traulsen Refrigerators
I have a traulsen freezer/refrigerator. Is there anything I need to do to convert it from fridge to freezer, other than adjust thermostat.
You probably will not be able to get much lower than about 28 degrees without having freeze up problems. A freezer uses different and more controls. Also, the compressor and expansion device may need to be changed. You need to do more homework on this as it could be a very expensive conversion. Let me know if I can help further.
Dec 12, 2010 | Traulsen G20010 Commercial Refrigerator
Traulsen commercial fridge will not cool
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 31, 2010 | Traulsen G20010 Commercial Refrigerator
The refrigerator is working but the freezer don't. Is on and it sounds working but the air wont come inside the freezer. traulsen rdt 2-24 dut
check for either a bad evap fan motor or a bad fan delay. It could be an under charged freon level too, but I would check the other items first as they usually go bad more frequently.
Jun 23, 2010 | Traulsen Refrigeration 48'' Wide x 24''...
Very loud compressor in traulsen freezer
It's probably a hermetic compressor. Nothing can be done. It's got an internal rattle, possibly defective valves, or freon was avercharged.
Aug 02, 2009 | Traulsen 7 cu. ft. / 198 liter Commercial...
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
How do you adjust temps (Traulsen URS 48 DT)?
You can go to traulsen.com and download the owners manual for your model and serial number. I did and it was VERY helpful to me. Let me know.
Apr 06, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
Traulsen Commercial Freezer needs charging?
The refrigerant level is low. The only thing is that the unit may not have a low charge. There can be several things that cause the unit not to refrigerate properly. It could have weak valves in the compressor or even a bad TXV(thermostatic expansion valve). Have you had this box repaired yet.? I see that this is an old post.
Dec 09, 2008 | Traulsen 24.2 cu. ft. / 685 liter...
Refrigerators Logo
228 people viewed this question
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
