Question about HP w2207 Monitor
Display switched from horizontal to vertical while monitor is in the horizontal position. What keystrokes are necessary to return the display to horizontal?
  • 742 Answers
Try pressing these key combination:
1. CTRL + Arrow Keys
2. ALT + Arrow Keys
3. CTRL + ALT + Arrows keys
These are shortcuts defined by your Video Card's support programs like NVidia or something alike.
The arrows key directions determine the direction to which the screen will rotate.
Posted on Jun 08, 2010
When I turn on computer, the monitor say going to dpm mode. any help?
DPMS (Display Power Management Signaling) is a standard developed to save energy and maximize the useful life of computer displays. By switching the horizontal and vertical sync lines on or off, a DPMS compliant video card provides the capability to place the monitor into one of four modes (Normal, Standby, Suspend, Off).
Each mode puts the display into a different powered state from fully powered up, to the Off mode. In the Off mode, only a small auxilliary circuit is running which monitors the horizontal and vertical signals to wake up the monitor.
Dec 21, 2010 | Computers & Internet
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
How do you adjust the vertical and horizontal of the image on your screen?
Press the OSD (On Screen Display) button on the face of the monitor. You'll find controls to control the size & position both horizontally & vertically.
Jun 01, 2010 | Dell E773C 17" CRT Monitor
LG 700B SHAPE SIZE AND POSITION UPSET PLEASE HELP TO RESTORE
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
Menu button of my monitor is not working properly
Try to fix that on display setting under windows display setting set it on lower setting. You can do that alternatively by booting on safe mode. Then readjust your display setting.
Mar 08, 2009 | LG Studioworks 563N 15" CRT Monitor
Monitor disply movable horizontal lines.
yes you first check the supply at vertical ic 12v if present then replace that vertical ic if supply is not present then check the regulator ic in smps if faulty then replace it
Nov 20, 2008 | SAMTRON 55V 15" CRT Monitor
Monitor display is vertical instead of horizontal
What Video card are you using?
WIN XP
Right click Desktop>>>Graphics Options or
Right Click Desktop>>>Properties>>Settings>>>Advance
and change the rotation to NORMAL
For Intel Video card go to GRAPHICS Properties
For ATI Video card go to CATALYST
For NVIDIA Video card go to PHYSx
Oct 09, 2008 | Dell Computers & Internet
Display problem
What position of a single rose color line? Is it vertical line or horizontal line?
Jun 22, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Display on monitor has swapped from vertical to horizontal
Type ctrl-alt then use the up, down, left, and right arrow keys until it's where it's supposed to be. If that doesn't work, right click on the desktop, select graphics properties. Then there should be a display settings, there you'll see where you can change the rotation of the display.
Aug 08, 2007 | Hyundai ImageQuest ImageQuest Q15S...
Display adjustments
Is the H. Position not showing up in the menu? Or is it that you can't seem to get to the Horizontal positioning that is the problem? Usually there are 4 keys: Auto, <, >, and Menu (I'm NOT counting the power button of course) Menu starts off the process while the < and > get your through the menu. When you see the V. Position, hit the "menu" key and the H. Position should pop up.
Mar 26, 2007 | HP P1110 21" CRT Monitor
HP w2207 Monitor Logo
160 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
