Question about Toshiba 27A34 27" TV
Tube tv no power. buzzing sound when plugged in and gone when unplugged
  • 748 Answers
Hi
You mean a CRT type TV. What is making the humming sound is the power supply. You probably have two problems, one the HOT is bad and the flyback and two an electrolytic in the power supply is bad. You'll need to take this to a reputable repair person. However, the price of the HOT, flyback and at least one electrolytic will be more than a flat screen monitor at Wal Mart. Unless this monitor has some kind of sentimental or mission critical value, I would just a new one.
Posted on Jun 06, 2010
Was working fine last night ,went to turn it on and you can hear a buzzing by where you plug in your jacks a bee,or high pitch sound.tv has no picture or sound.only sound you hear is this buzzing
Sounds like your power supply is causing the problem. Unplug the TV wait 10 minutes, look in the back for a red button (circuit breaker) push it in. If this does not work you have a low voltage power supply fault.
Mar 04, 2016 | Televison & Video
Westinghouse LTV-37w2 HD have no picture, no sound, no blue power light on - only some buzzing. What it can be ?
if it is just buzzing then the transformer has gone, may have over heated.it transforms the line in volts down to the volts needed to run the tv. so say 240v ac in and tv needs 110v ac. now the volts in will be making the buzzing sound but the coil on the 110vac side has gone. if you change the transformer. has to be the same colour and number. tv should be fine. as the coil in the transformer brakes its just like removing the plug from the wall and not do any more damage. so just the transformer will need changing.
Oct 01, 2013 | Westinghouse LTV-37w2 HDTV
Samsung plasma tv pn42a400c2dxza. when i try to turn it on it starts making clicking sound than it starts buzzing. i unpluged everything from the power supply and the buzzing sound stopped. but when i plug...
This problems is the power supply board is causes and the problems.Try website like Ebay.com buy a whole refurbish power supply board for the replacement,will solved this problems.
Nov 29, 2010 | Samsung PN42A400 42 in. Plasma TV
I have a older sanyo ds19390 tv that is buzzing inside, not thru speakers please help
In older tvs the buzzing sound usualy comes from the HT lead plugged into the tube .open the back and switch the tv on (do not touch anyware near the set the HT lead carries avery high voltage even when the set is off)if u do see arching then u need to clean around the rubber of the ht lead )u can leave the set unplugged for a couple of days to allow the tube to discharge before attempting to clean around it.
Apr 13, 2010 | Televison & Video
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
TV Just Started Making a Humming/Buzzing sound
Replacing a flyback is not something I would suggest for anyone with no electronics experience. Second, lets see where the noise is coming from first. Take off the back and listen to the noise. The flyback will be at one end of the large red wires that go to the tubes. Sometimes the connection at the tube is not 100% and the noise comes from there. BE CAREFUL - there are high voltages going through this red wire that can be dangerous even with the set UNPLUGGED!! IF the noise is coming from the connection at the tube, with the set unplugged, carefully turn the rubber cap back and forth touching only the rubber part with one hand. Put the other hand in you pocket while doing this.
If the noise comes from the flyback side, if you can solder, again with the set unplugged, try resoldering the pins on the transformers. That may resolve the problem.
Keep me posted.
Dan
Feb 13, 2009 | Samsung HCL5515W 55" Rear Projection...
Buzz When I plug the tv in I get a buzzing sound and the power button does not light up and there is no picture or sound.Could it be a tube?
quietlove,
I will guess you remember tube sets from our parents days !
They stopped being Mfr'd in 1972 !
Best solution for your set = replace horiz transformer and
transistor with RCA part # 's 257807 & 237470................T.
Nov 26, 2007 | RCA 32F530T 32" TV
Picture went out and all the tv does is make a buzzing sound
The horizontal output transistor drives a transformer that gives you the high voltage to light up the picture tube,either the transistor or the transformer have gone bad,sometimes both have to be replaced and sometimes the transistor fails for no reason by itself.Be safe and call for help if you are not familiar with tv service.
Sep 20, 2006 | RCA F32450 32" TV
Toshiba 27A34 27" TV Logo
219 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
