Question about Bernina Bernette 75
Problem with Bernina 630
My question is about my Bernina 630.I get this message after sewing 9 to 12 stitches:Thread breakage or empty spool. I checked everything and I still cannot get it to stop this.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Sounds like one of your thread sensors is misaligned, covered in lint or broken, get a can of canned air and clean out your bobbin case area and you top tension area to ensure no lint/thread is blocking the sensors. If you still are having problems, find your local independent sewing store in your town that gives free estimates and see what they say.
-Hope that helps,
Chris
Posted on Jun 06, 2010
Is the Bernina Activa 140 equipped to use a double needle?
Berninas can use double or triple needles, just be sure the needle is set in the center position and the stitch width is set to zero. If your machine does not have dual spool pins, you can put one spool in a drinking glass on the table behind the sewing machine. You can also probably fashion a spool holder out of a small dowel on a base or even find a standalone spool holder. Instead of using two thread spools, some people will use a thread spool and load thread on a bobbin and put both on the spool pin.
Be sure to thread each separately so the two threads do not become twisted. Your machine may also have dual tension disks, so each thread should be separated when going through the tension unit.
Mar 19, 2018 | Bernina Sewing Machines
I have a Bernina 350 SE. Trouble with buttonholes: thread accumulates in lumps intermittently. Stitches become very small, fabric stops advancing, thread piles up.
Have you tried re-threading the top thread? Sometimes the stitches get small and pull tightly because the thread is looped around a guide or the thread spool. Just a thought as that happens frequently with my machine.
Oct 19, 2017 | Bernina Sewing Machines
Thread bernina embroidery bobbin
The thread sensor eye is probably dirty.
Dec 26, 2017 | Bernina Sewing Machines
Thread broken indicator
It may be that the upper thread sensor flag has come off the check spring at the bottom of the takeup arm cover - unfortunately this is not user-fixable and needs Bernina agent action. This happens frequently with people who, when finishing with a spool of thread, pull the thread backwards out of the machine - you should never do this. You can turn the sensor off by going into the menu that has an arrow with a box around it, but this is only a temporary fix and you should have the machine looked at.
Aug 19, 2012 | Bernina Sewing Machines
Bernina 820 Tension Error Message
You need to take your machine in for service. The 8 series machines have new upper tension parts that can be installed under manufacturer warranty and MAKE SURE your Bernina dealer is well trained on the 820 and 830 or they'll never get it adjusted right. The 8 series are just all around buggars when they're out of whack.
May 20, 2012 | Bernina Sewing Machines
The bottom thread on my Bernina 140 jams
Try pulling more thread out before you begin the seam - about 6". If you can hold the threads while you take the first few stitches that helps too.
Apr 02, 2010 | Bernina Activa 140
Bobbon thread is too losse /thread breaks no
Clean out the bobbin area.
Thread the machine with the presser foot up. This opens the tension so the thread can enter. Threading with the foot down closes the tension and the thread cannot enter as it should. When you sew, the top thread is loose and cannot properly connect with the bobbin thread to form a tight stitch. The stitching does not hold and pulls right out.
Thread breakage - top thread? Check the thread spool to be sure there aren't any nicks to catch the thread.
When the thread breaks, check the spool pin to see if the thread is unwinding too fast and wrapping around the pin. Thread nets can help stop this. You can find them at sewing machine dealers.
Mar 11, 2010 | Singer Sewing Machines
My mother has a Bernina record machine which has for the last 35 years not worked longer than a metre or so stitching on the most basic stitch without tangling the thread on the bottom spool. It has been...
Try threading the machine with the presser foot up and see if this helps.
When the foot is down during the threading, the thread does not enter the tension control as it should, then when you start to sew, the upper thread has no tension and does not form a stitch with the bobbin thread.
Mar 04, 2010 | Bernina Sewing Machines
Sewing Machines Logo
443 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
silly01
Level 1 Expert
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
