Question about Ryobi Cultivator
Fuel hoses are absent
Where do I connect them and what size are they?
What is the name of the first hose that is connected directly to the fuel tank.
Glad to help. Hi it's called a FUEL FILLER NECK HOSE PIPE. i have no data on size. Cheers
Nov 05, 2016 | Ford Cars & Trucks
Mccullough FHH18A - Looking for connector adapter/ size ?
Why not just purchase a new hose assembly?
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 03, 2014 | McCulloch FHH18A Electric Pressure Washer
STIHL FC90
the fastest way is to replace the line it connects to pull the old line out take the new hose and trim it down to 1/3 about a 1/2 long feed a stiff wire threw the hose opening and out the gas cap opening slide the line over the hose and slowly pull the wire back til the hose sticks out then pull the hose threw connect the filter to the hose then pull into place trim the hose to size
Aug 11, 2012 | Garden
Fault code p0444
Check the following conditions:
  • Absent or tampered fuel cap.
  • Absent or tampered O-rings at fuel vapor and EVAP purge line canister fittings.
  • Cracked or punctured EVAP canister.
  • Damaged source vacuum line, EVAP purge line, EVAP vent hose or fuel tank vapor line.
  • Poor connection at the ECM. Inspect the harness connectors for the following conditions.
  • Backed-out terminals.
  • Improper mating.
  • Broken locks.
  • Improperly formed.
  • Damaged terminals.
  • Poor terminal-to-wire connection.
  • Damaged harness. Examine a) the wiring harness to the EVAP vent solenoid, b) EVAP canister purge valve and c) the fuel tank pressure sensor to ensure whether an intermittent open or short circuit prevails.
  • Kinked, pinched or plugged vacuum source, EVAP purge, or fuel tank vapor line. Ensure that the lines are not restricted
Nov 29, 2011 | Kia Cars & Trucks
I know i need to drain the tank before i take it off, but i don't know how to drain it. please help
It is simple find a clean container.From the tank you will find the fuel valve and the fuel hose connected to your carburator. First close the fuel valve, if it is easier to remove the hose from the carburator, remove it and to put it to your container. Open the valve to drain the gasoline. Otherwise take a rubber hose about half meter of the same size and put one end of the hose to the container, disconnect the fuel hose after the valve and connect the other end of your hose which is in the container. Open the valve to drain the gasoline to the container.
Jul 11, 2011 | 2009 Suzuki Boulevard S40
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
Chainsaw would try to start but not run pulled it down and found the fuel hose was deteriorated. I am not sure where the fuel hose original path was and how it goes into the tank. Also is the fuel hose a...
Details vary with brand and model, but in general the fuel line goes into the tank somewhere near the carburetor and connects to the fuel filter inside the tank. The other end connects to the carburetor inlet-- usually near the upper end of the carburetor. Lower down on the carburetor, there is another port that connects with fuel line to the primer inlet port. Another line goes from the primer outlet back into the tank. Usually, one just goes to a saw service shop and buys lengths of the proper size line. Much cheaper than buying as a service part from the manufacturer. Hope this helps!
Jan 08, 2011 | Garden
Mcculloch BL150 Blower. Both fuel lines from tank to primer have broken. The holes in tank body suggest two different fuel line sizes.? 2mm ID & ?. Is there an exploded view of the connection-...
Usually the smallest hose is the suction line in the tank and the larger hose is the return hose to the tank. The primer bulb should have 2 different size hose barbs.
Dec 01, 2010 | McCulloch Garden
I haVE A CRAFTSMAN MODEL 358350380. i WAS TOLD THIS IS THE SAME saw. My brother in-law said he rebuilt the carb for me.....now it pours gas out everywhere when you fill the tank with gas. I think that...
Hi; I suspect he replaced the fuel hoses. If it is running it is most likely plumbed correctly however there should be 2 different size hoses and I think they are all the same. Small hose in tank (pn 350069216) with filter on the end to carburetor input. Small hose from carburetor to air bleeder. Large hose (pn 530069247) from bleeder to return connection on the tank. I think the large hose is the wrong size or not connected to the return.
It should be plumbed like this:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Your IPL is here (the print is deceptive, it appears the feed line goes to the primer; it does not!):
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
IPL
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358350380&pathTaken=partSearch
OM
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0810019.pdf
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 28, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Removing fuel line from fuel filter
Hi, Fuel filters and some other hose connections on vehicles today use a clip mechanism that is easily released with a small plastic tool. These tools are available in most auto parts stores. They come in a set to accommodate different size hoses, and metal barbs. Simply put the longer end of the tool toward the fitting and press to release. Good Luck!
Feb 13, 2009 | 2000 Kia Sportage
Ryobi Cultivator Logo
20 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
