Question about Sunbeam Grill Series 650
I have a Grillmaster 650 (circa 2001) I replaced the burner and the "tent" a couple of years ago. There is another part in the center / front of the grill that protects the beginning of the burner. Its just a plate that is maybe 4 inches by 1 1/2 inches (It is so rusted and decayed I cant tell). But like the tent, it keeps dripping grease and fat away from sensitive parts of the grill. I need that little part. Any ideas on where I can get this part.? Andy
5 Suggested Answers
SOURCE: Screws fastening "tent" are corroded
Just had the same problem... I sprayed some WD-40 on both sides to loosen it, then used a damaged screw remover to pull it out. On one side, the head snapped off and I had to use the smallest-size extractor to directly pull out the shank, but it worked.
http://www.4grabit.com/
BTW, you don't happen to have the instruction manual, do you??
Posted on May 26, 2009
greenspan
  • 1734 Answers
SOURCE: I need a part number for the venturi
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 30 Answers
SOURCE: Venturi tubes
The venturi tubes should go over the gas orifice. If the tubes were to drop off, you could have a fire outside of your grill and possibly an explosion.
Posted on Mar 04, 2010
  • 54 Answers
SOURCE: sunbeam model #650 heat tent
There seems to be 2 sizes 25-5/16x8-1/4 or 27-11/16x8-1/4 heres were you can get them http://www.grillstuff.com/gas-grill-flavorizer-bars/?cat=50
Posted on May 20, 2010
I need to buy replacement polls for 2 room dome tent with screen porch
try manufacturer for part replacement or thier customer service for assistance in part replacement
Jul 23, 2017 | Sport & Outdoor - Others
I need pitching instructions for a Great Outdoors Apollo 4 man tent
Take out all poles and stakes and tend and seperate.. First lay tent on ground and streatch out where you wish to pitch the tent. Then take stakes and place them in the four corners of tent through the loops so ththat when you hammer in the stakes the tent is nice and stretched out tightly. There should be two more loops on each side int the middle. When the tent is secure to the ground, take the poles that should have been put together and feed them through the hoops of the tent on the sides and top. Leave the top center parts of poles apart until you have poles through rest of loops and attatch them at the top of tent. front, back and center usually work pretty good for order. Doint middle last because it is the highest point. Hope not too confuseing. I camped a month every year for many years. You never forget.
Dec 23, 2012 | Sport & Outdoor - Others
I need instructions for a grillmaster 720-0697
Hi, here's a link to the PDF file.
http://www.shopnexgrill.com/includes/pdf/720-0697.pdf
Jul 19, 2012 | Grilling
What is the expected lifetime of a tent?
The average lifetime of a tent is 7-10 years when using it 2-3 times a year, each time between 3-7 days. Taking good care of the tent is a major factor in its lifetime.
Jul 10, 2012 | Camping, Backpacking & Hiking
Grillmaster burner no gas
Check and see if burner is blocked or injector to the burner is blocked
If you swap 1 of the buners over this will show you what is blocked
Jun 24, 2012 | Sunbeam Grill Series 760
Hi there i was wondering if you knew the part number for the sunbeam 650 grillmaster burner??? Thanks a ton!!
here is the website, Good Luck Tim:
http://www.clagrills.com/parts/sunbeam_grillmaster/sunbeam_grillmaster-parts-home.htm
May 31, 2011 | Garden
I have a coleman Weathermaster tent I bought a couple of years ago the model number is 2000002250 the issue im having involves the plastic elbows that come with the tent that ties the upright tent poles to...
I have the same model number tent and have some broken connectors as well. I could not find any replacement parts any where local or online. I called Coleman's customer service number at 800-835-3278. The tent has been discontined but they had a few of the connectors "in the office" and shipped me three. Give them a call; they were extremely helpful. Coleman customer service is top notch in my book!
Mar 06, 2011 | Coleman Sport & Outdoor - Others
Oven has small explosion igniting and going off. says tj
A few years back I helped a neighbor with this same problem in a forced air, gas fired, "horizontal" furnace in his attic.
After having him cycle the thermostat a couple dozen times while I watched through the opening in the side of the furnace, I finally figured out what was happening.
First, there were about 6 cast iron burners [about 14 inches long with two rows of gas holes along the length]. These burners were parallel to each other and oriented perpendicular to the long axis of the furnace.
The gas was fed to the ends of the burners with a pipe manifold. The standing pilot light was at the center between burners 3 and 4. Due to the spacing distance between the burners, the pilot light was too far from even burners 3 and 4, the flame could not "jump" to ignite them, or any of the other burners. The manufacturer had installed a thin sheet metal "tent" which ran from the gas entrance end of burner 1 to burner 6, and was about 2 inches above the burner, AND the pilot light.
The standing pilot was on all the time. When the gas control valve turned on, gas began to come out of all the burners at the same time. Naturally it came out of the gas supply manifold ends of all the burners.
The "tent" captured that gas coming from the burners and "filled" up to over the pilot light which ignited the gas at that point, and the flame would propagate along the tent to ignite the gas coming out of all of the burners.
In my neighbors case, the tent had somehow become dislodged so that it did not cover all of the burner ends. For those burners which it did cover [including the pilot light] it caused the burners to light properly.
For those burners who's ends were not covered, and who's gas could not be captured, they would NOT ignite simultaneously with the others.
As these burners WERE feeding gas into the combustion chamber, the gas "envelope" would spread until it reached the nearest flame ignition source, at which time the entire "bubble" of gas would ignite with a minor boom [actually a low energy explosion]. Flame would momentarily shoot out of the burner chamber opening, and from that point the furnace would operate normally until the next restart cycle.
Although there could be several causes, I suspect that the symptoms you describe are the result of DELAYED IGNITION of some or all of the main burners.
IF this is the problem, then the solution is to clean all the burners [including the burner outlet holes in the ignition ends of the burners], clean out the burner compartment, AND properly adjust the orientation of whatever system [you have to evaluate how it works from analysis of YOUR furnace] your furnace has to ensure all burners ignite as close to the same time as possible.
When operating properly, the ignition should be a smooth transition, burner by burner, from the pilot to the farthest burners. In other words. the ignition will "flow" from the pilot outward to each adjacent burner until the farthermost ends ignite last. This usually doesn't take more than one or two seconds at the most.
Unless you are an experienced handyman, and understand this analysis and instructions, I strongly suggest that you engage the services of a professional furnace technician.
Feb 13, 2009 | Imperial Commercial Cooking Equipment...
Grilling Logo
70 people viewed this question
Top Sunbeam Grilling Experts
Gil Shultz
Paul Carew
Are you a Sunbeam Grilling Expert? Answer questions, earn points and help others
