Question about Sewing Machines
Bobbin will not pick up thred - Sewing Machines
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 53 Answers
Sounds like your hook to needle timing is off. When you sew through thick materials, a lot of machines
have issues where the needle sticks in the fabric but all the internal parts shift and this causes the hook to needle timing to go out. The begging signs of this is skipping stitches. You will have to have you local independent sewing store do this adjustment for you
Hope that helps :)
Chris
Posted on Jun 06, 2010
Can't get to pick up thred from bobbin
go to this link and scroll down the page you might find out why.... Can get to pick up thread from bobbin Google Search
Oct 24, 2017 | Sewing Machines
How does bobbin work
don't forget to load the spool under the foot plate with cotton as well and make sure its loose thred it up and try to watch if it picks it up from under the foot and pull it out so you have one cotton from the bobbin and one coming out from under the foot through a small hole and try again
let me know if you still have problems with it the timeing might be out a bit as well
Jan 22, 2015 | Sewing Machines
Elna lotus
try cleaning under the needle plate & in bobbin area for loose threads or lint
try using a new needle--make sure the needle is inserted correctly in the needle holder
try rethreading the machine top & bobbin
if you try all these suggestions & the machine still won't pick up the bobbin thread then it's possible that the machine is out of time & would have to be retimed at a sewing machine shop
Mar 02, 2012 | Elna Sewing Machines
I am not able thred the thred from the bobbin. The thred got jammed up when I was sewing, and I removed the bobbin and now I can't get the thred back in.
What is blocking the hook and shuttle? I am not too sure what you are asking, where are you trying to put the thread? Please, be more clear.
Nov 20, 2010 | Brother CS-6000
Not putting thred on bobbin
It would help to know the brand and model of the sewing machine you are referring to.
Mar 16, 2010 | Sewing Machines
Elna 1600 underside of garment stitching not catching correctly - ?something to do with the bobbin tension?
its more likley to be the needle tension if its not picking up the bottom thred but if the bobbin tension is very tight this could be causing it, but it will all bunch up if it was
Jan 19, 2010 | Sewing Machines
The needle is not picking the thred from the lower
The timing mechanism is likely off. Take off the plastic bobbin case and see if the eye of the needle, on its way up, is just below the metal hook that catch the thread. If not, you need to ajd the timing mechanism
Jan 01, 2010 | Sew Smart Sewing Machines
Cant bring up bottom thred even after we read how to
re thread the upper and lower threads
make sure the bobbin is in the correct way (check manual for the correct spin on the bobbin clockwise or counter clockwise
change needle or check that it is in correct, if it has a flat side goes to the back, the long groove on the needle when goes down should just meet with the hook in the bobbin area to pick up the thread
Sep 07, 2009 | Elna Sewing Machines
Top thread won't grab bobbin thred. It's a Kenmore Mini Ultra
Re-sync the bobbin to the hook:
the needle should "pick up" the bobbin thread when the needle is about 1/4 inch below the hook move the mechanism slowly and, observe the interaction and you will see the adjustment screws on the carrier shaft you will need to adjust
Aug 02, 2009 | Sewing Machines
Sewing Machines Logo
70 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
