Question about Sharp XR-10X Multimedia Projector
How to replace a ballast on the sharp projector DT
How to replace a ballast on sharp projector DT -100
  • tjoeyfl Jun 06, 2010
    I'm looking to replace the ballast not the lamp
    thank you
  • 75 Answers
Flip over the projector with the bottom up to you. you will see a panel door front right of the lens. There is one screw to be removed from the lamp panel door. There will be two holding screws that hold the lamp housing in place, remove these. grab the handle and pull up towards you thus releasing the lamp housing assy. Then place the new lamp and firmly press down and then tighten the two screws that held the lamp assy, then replace the cover.
You will then need to reset the lamp timer. by pressing the menu+enter+the arrow button between the keystone and menu button simultaneously.
Posted on Jun 06, 2010
  • ridinghood Jun 07, 2010
    My apologies. The ballast is the part that connects to the power supply with 2 wires, the main board by 5 wires and the lamp by 2 wires. This is the only picture i could find that may resemble what you will be looking for inside the projector. Hopes this helps you out.
My projector blew a bulb after installation what the problem generic bulb
Hello :
Check out the Power supply to the lamp . It must not be high . . Check if the voltages are correct to the lamp's unit and it's PCB [printed circuit board]. I recommend using a service manual .
Check for manual here please :
Sharp DT-100 Multimedia Projector manual .
Here is how to replace a projector's bulb correctly :
1:Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp
I hope this will help .
rate please !
Mar 21, 2010 | Sharp DT-100 Multimedia Projector
The projector stopped working...no warning...will not power on
do you main deadset? check your main outlet of your power, check the power cord if good.if that problem occur again you must change the power board of your projector.
Oct 28, 2009 | Sharp DT-100 Multimedia Projector
My projector suddenly stopped working
The instruction manual says that to reset the timer you have to hold down (simultaneously) the Menu button, then Enter button and the Down arrow...then press the Standby/On button on the projector. This worked the first time I replaced the bulb, but now that I've had to replace it again, its not working. Good Luck.
Mar 21, 2009 | Sharp DT-100 Multimedia Projector
Sharp DT-100 projector bad picture quality
Hi There Not sure what you visually describe as "blurry" This could be two things - a typical white screen will waste all the definition and brighteness unless you sit in a dark room Our ICE Digital Daytime Screens will take any projector and make the image up to 2000% brighter with a resolution reseolving ability of 20 million pixels. So in this case the definition you are alluding to could be lack of contrast, image definition due to insufficient light from the projector relative to the lux level of the room. Alternatively the lamp could be getting old. The brightness of a lamp falls off rapidly so as you use it more and more the image will become duller and duller contributing to a "blurry" or image lacking in punch etc.
The technical lamp hour spec life is only a manufacturers "up to xxx hours" and not what you will achieve in actual life.
If you want we are able to supply lamps as we ship internationally and also the same with our ICE Digital Daytime projection screens. Sharp DT-100 Lamp cost is $US261 delivered. Lamp Code AN-100 http://www.youtube.com/watch?v=HvZ2DlVJ790 http://www.youtube.com/watch?v=qL_44xfK9y8 Regards Kevin Andreassend ICE AV Technology Ltd http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Jan 30, 2009 | Sharp DT-100 Multimedia Projector
Remote contol code for a DT 510 projector
try one of the sharp tv codes. if you just want to use the remote to turn it on, this might work. if you want to use it for other functions of the projector, it won't. the remote is not set up for that.
Jan 15, 2009 | Sharp DT-510 Projector
Sharp XR-10X Multimedia Projector Logo
435 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
