Question about Victor Fire Stick Weed Burner Heating Torch 0384 1261
I have fire stick weed burner . When I turn on
I have fire stick weed burner . When I turn on the propane and try to ignite the torch end there is no propane getting to the end. There is a small release of gas and that is it. What could be the problem?
  • 59 Answers
I should think the jet is blocked . you will have to take the jet out to clear it I think although pricking it with a thin piece of wire might help.
Posted on Jun 06, 2010
My 40-FAC heater will not ignite and run. The igniter has been replaced. What should I check next?
These models require electrical power to run the blower fan.
When you connect the electrical cord, the fan should turn on, then you should be able to start / ignite the propane. if the fan does not turn on when you connect the power cord, you will not be able to ignite the propane.
Dec 09, 2014 | All-Pro Propane Garage Shop Heaters - All...
MY 3E218B HEATER WON'T FIRE
limit switch
tilting safety switch
try propane torch on burner to burn off any restrictions.
by any chance are you useing old fuel?
Dec 05, 2014 | Cars & Trucks
Dsi flt after trying to fire 3 times piezo works
Try removing the safety cut out (looks like a resistor in a plastic sleeve going to thermostat terminal) . Just disconnect it at both ends and connect the female spade from power wire directly to thermostat male terminal where the cut out was connected and try it. If it works, replace it when you get a chance. That protects system in case of flame jumping up in that area due to problems or spider webs etc. Once it's been tripped, it's no good. If that's not the problem, try cleaning your ends of your electrode, and make sure they are in front of flame when burner ignites, as it also act as a flame sensor. Let me know how you make out.
Jun 21, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
I would like to buy one but I want to make sure it works for ice--the only reason I need the dual turbo propane torch kit
Ice doesn't argue much with any heat. Get one of those propane torches they use for roofinfing and heating tar,or burning weeds. I think I paid 29.00 and it puts out a wall of fire an iceburg would run from. Pardon the pun "run"
Oct 28, 2009 | Northern Tool Dual Turbo Propane Torch Kit
Pro Series 2400: I can't light the grill. I
If you hear gas going to the burners then you need to clean your grill if you don't then it a bad regulator
Jul 16, 2009 | Brinkmann 810-8410-S Stainless Steel...
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Victor Fire  Stick Weed Burner  Heating Torch 0384  1261 Logo
136 people viewed this question
Top Victor Welding Tools Experts
Bill Boyd
Are you a Victor Welding Tool Expert? Answer questions, earn points and help others
