Question about Hunter 52" Ceiling Fan With Light And Remote Control
I need a diagram for the wiring that goes from the fan to remote speed settings and then to electrical wires in ceiling
  • 736 Answers
All of the white wires connect together and to the white house wiring (neutral from ceiling) ..also the neutral or return wire for the controller (may also be white) .. then the black house wiring(or red if you have an external wall switch) is connected to the controller wire marked AC or AC input .. the output marked "lamp" on the controller connects to the blue wire that goes to the light bulb (or bulbs) ... the output called fan goes to the black wire of the fan motor .. the green house wire goes to either a bare wire, green wire or a green bolt that is screwed to the metal of the fan.. thats the safety ground ...
Posted on Jun 07, 2010
I have a 3 speed ceiling fan I wired the light but dont know how to connct wires for fan
If the fan only has 2 wires a blue and a white, blue goes to power supply white goes to neutral. Fan switch itself provides the 3 speeds.
Jul 03, 2014 | Westinghouse Electric Westinghouse...
Wiring diagram for harbor breeze celing fan
The colors of the wires in the Harbor Breeze ceiling fan kits tell you what their functions are. The black wire is hot for the fan, the white is a common wire for both the fan and the light kit, green is ground and blue is hot for the light kit. locate the black and blue wires from the ceiling fan and connect them to the black wire inside the electrical junction box by twisting an orange wire connector onto all three wires. Locate the white wire from the ceiling fan and the white wire from the junction box and attach the two wires together with a wire connector. Connect the bare copper wire onto the green wire from the ceiling fan mounting bracket by twisting an orange wire connector onto the two wires. Push all wiring inside the electrical box. good-day !
Nov 26, 2011 | Hunter 52" Ceiling Fan With Light And...
I have a westinghuse fan with light it has four wires on it green, blue, black, and red what are they ie live neutral etc
Question posted under 3-speed switch
1) Are you replacing the 3-speed switch?
This is a field with much discussion because Westinghouse 4-wire fan switches vary.
Process of elimination is needed to find hot line. From there you test each wire to the hot line wire to determine which wire or combination of wires makes up low, medium, and high speed.
Open following links for some resources:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php
http://www.atlantalightbulbs.com/ecart/catalog/westinghouse-6.html
2) Or are you looking at fan connection wiring at ceiling?
Green wire goes to bare ground.
Fan should have hot and neutral.
Hot line should be black.
Neutral should be white.
Red usually goes to light
Blue is normally not there.
Where is the white neutral wire?
Take multimeter set to read ohms and test black wire to each other wire.
Process of elimination should reveal correct wiring.
Aug 21, 2011 | Speed Ceiling Fan 3-speed Switch By...
Receiver quit. replacement has just one wire and a
all of the white wires connect together and to the white house wiring ... the black of the house wiring goes to the AC input of the module (may be a black wire ) .. the blue wire from the lights goes to the light output of the module (as you already know) ...
now the motor actually has only two wires .. one white that should already be hooked up with all the other white wires .. the other goes to a block that contains the speed controlling capacitors .. and that has the 4 wires (you metioned cominng from the motor) .. the capacitors are no longer needed since the speed control inside the module takes over .. so you can eliminate the capacitor block (thats normally connected to the speed control switch that you wont need either)... that will leave you with just one wire from the motor that has to be connected to the modules motor wire output ... that should do it ... set the code on the module and remote the same (in battery compartment of remote) (good idea to make sure your neighbor isnt using the same code ..
connect the green wire (or bare wire) to the metal of the fan ..usually a green screw or a bare wire .. thats the safety ground ..
May 27, 2010 | Hampton Bay 24002 Ceiling Fan
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay Ceiling Fan, Model 68068. When installed, without connecting the final plug, the fan doesn't operate (like it has no power); but as soon as the last white connection is made, the fan comes on,...
Hello, W/D here. It sounds like you have bypassed your on/off switch.
The white wire is the common wire, which returns the power to ground, and completing the circuit. By connecting this wire, you have completed a circuit, indicating that power was constantly on to the fan.
Gain access to your wiring in the ceiling (trip the breaker first, please).
If you have tied your hot wires to a twisted bundle of black wires, you have tied to the hot thru line. Look for a single black wire. What normally happens with the ceiling wiring is that the circuit hot wire goes to your ceiling box. Another wire connects to this one. It passes on to the next device on the circuit. Yet another wire ties to the bundle. It is your switch hot wire. It goes to the switch, and returns to the ceiling box. The return wire from the switch is the one you're looking for.
Regards, --W/D--
Jul 20, 2009 | Kitchen Appliances - Others
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
Dryers Logo
902 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
