Question about GE (PSS26MSRSS) Side by Side Refrigerator
The control panel for the icemaker, water, etc isn't working. Is there an exploded view of this for troubleshooting?
We have a lot of water coming out from under out refrigerator. It take like 3 bath towel to wipe it all up every 6 hrs. Can you tell me what it could be?
Posted on Jun 07, 2010
  • GE Master
  • 1,606 Answers
The dispensor board is not communicating with the main control board . Replace the main control board . Pt # WR55X10942 . This is the board behind the 8 X 10 panel behind the refrig . Easily replaceable .
Posted on Jun 06, 2010
  • Mike Smith
    Mike Smith Jun 06, 2010
    c'mon sea , give a direct solution ! And get your dad out of the picture ...LOL
  • GE Master
  • 4,655 Answers
Yes, Click Here=> GE ARTICA PROFILE TECHNICAL INFORMATION Top left of the Tech Sheet feeds display panel and temperturecontrols if digital. Top left of wiring diagram is J4 and at bottom left hinge there is a pin plug connection that most likely has a beak in the connection. Check voltage DC should be 13 volts between red and blue or red and black. Click on wiring diagram and it opens into a Service Manual. Have questions please ask. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Jun 05, 2010
Whirlpool gh7155xhs troubleshoot
Unless there is moisture or grease on the control circuit board, it's likely failing membrane keypad.
There is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
For model GH7155XHS0, the exploded view and parts list are here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20885939.pdf
The part number is 8171854 "Controller Sub Asy".
For model GH7155XHS1, the exploded view and parts list are here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208183934.pdf
The part number is 8183977 "Controller Sub Asy"
You can order the parts from the Pros here.
Some connectors may have a lock.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
Apr 27, 2013 | Microwave Ovens
Wiring diagram and board lay out for jvc lt42x579 tv
I have the copy of JVC LT-42X579 service manual that covers the following :
precaution
specific service instructions
disassembly
adjustment
troubleshooting
wiring diagram
block diagram
circuit diagrams
pattern diagrams
voltage charts
waveforms
using p.w. board & remote control unit
exploded view parts list
exploded views
printed wiring board parts list
remote control unit parts list (rm-c2050-1c)
packing
packing parts list
If you want the copy click it HERE.
Jdvillanueva
Sep 29, 2011 | JVC LT-42X579 42 in. LCD TV
GE JVM1540sn1ss Microwave loses all power including interior light, control panel, etc. I have to set the clock each time. I can wiggle door or control panel and power comes back on. I appears there...
It may be a loose fuse holder or a rare condition, an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you need further help feel free to contact me with your full model number and symptoms.
Jul 06, 2011 | General Electric Microwave Oven
My icemaker quit working. Water does not come in to fill the tray. Water source is turned on. In door water dispenser works fine. What should I do to troubleshoot? I don't hear the solenoid click in...
have you checked the inflow tube to see if it's iced up? if your icemaker isn't filling with water and your getting water in the dispenser your feeder tube is probably frozen
Apr 11, 2011 | Kenmore Side by Side Refrigerator
GE Spacemaker 1800. Check power supply - good. Changed both fuses - Done. Not working yet. Does not have any signs of power yet. 24 hours earlier, I had water boiling almost all day, cooking. Did this...
Depending on the full model number (from the tag in or on the unit, something like JVM1860SD003, etc.) there will be one or more thermostats / thermal cutouts / TCOs which can open if overheated.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Any TCOs you need to be concerned with will have thicker wires. The one with thinner wires will read different form the others, and that is normal. See the mini manual for details.
Jan 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Icemaker/water dispenser not working.
Just had to defrost the water tank inside the fridge for a few minutes. Using a waterproof heating pad with extension cord did the trick. Even a fridge needs a warm blanket from time to time.
Oct 21, 2009 | Jenn-Air JFC2089HE French Door...
My whirlpool gold side by side refrigerator ice maker has stoppoed working. Is there a process to troubleshoot and determine the cause?
Pour about 1/2 cup of water into the icemaker . If it freezes and dumps , replace the water inlet valve . If it does not dump , and holds the cubes , replace the icemaker . Also , make sure the coils are clean and free of dust , lint , etc..
Aug 13, 2009 | Whirlpool Refrigerators
F9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
May 17, 2009 | Kenmore 63792 Microwave Oven
How to replacemale gear for ice auger on 2003 whirlpool side by s
Here is a place that has an exploded view of your icemaker, and mounting: http://www.pcappliancerepair.com/model-display.php
On the left side of the page, scroll that view down until you see the freezer door parts, and click on the words. This will bring up the proper view where you can see where the screws etc are that hold the unit in.
They, as well as the several other places I checked, show the auger motor as a sealed unit, that you get to by removing the icemaker from the door.
Apr 21, 2009 | Whirlpool GS6NBEXR Side by Side...
My lower oven does not work; top oven works fine
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" (tech sheet) hidden inside the unit behind thecontrol panel or hidden inside behind the back cover, etc., and it's very helpful when troubleshooting, testing, and locating components.
Nov 24, 2008 | Microwave Ovens
GE (PSS26MSRSS) Side by Side Refrigerator Logo
292 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
