Question about Fisher and Paykel GWL11 Top Load Washer
Doesn't drain in rinse mode
In rinse mode, the washer starts to drain for about 10-15 seconds and then stops. The washer stalls there and won't continue cycling.
  • luisa_sgro Jun 06, 2010
    Hi just read your posting.When it stalls do any lights light up and it starts to beep?If it does then the lights are in a row of 8. Starting from left to right which ones are lit?Is it the 1st and 3rd or 5th and 6th etc ? please reply and I can guide you throe this problem.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now when it stalls in the rinse cycle does it start to beep and light up a couple of lights to indicate a fault code? Or do you have the LCD display model that shows the error code.If your machine shows some light on the same line of lights, there are 8 in a row , which ones are lit? Is it the 2nd and 4th or 1st and 6th--etc .Also if you have the LCD display model what is the error code?Please reply for further help.Hope this helped.
Posted on Jun 08, 2010
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Going through full wash as normal but won,t go onto rinse or spin mode?
Most front load units must have two things, door must lock and must sense cold water for rinse. I would check the fill line for the cold water, if clogged with sand, it will not progress through cycle. If the unit doesn't drain it will not spin, is there water left inside the drum area?
I am here if you want more assistance
Aug 28, 2011 | Bosch Exxcel WFX 2467 Front Load Washer
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
Washer stops during rinse cycle
if unit is stoppin in rinse cycle and not advancing into drain/spin mode. you lift the lid and its stalled full of water??? clos the lid again and listen for a slight "clicking" noise, chances are you lid switch has gone bad, and the machine does not recognize the door being closed, and for safety reasons will not drain/ and or spin..very common issue!
Jan 27, 2010 | Kenmore Washing Machines
What is the best way to winterize a standard large capacity washing machine?
If the product will be exposed to sub-freezing temperatures, turn off the water supply to washer, disconnect fill hoses, drain them and reconnect. Remove the drain hose from the standpipe in the wall and place it into a shallow pan at floor level untill the water floe stops. Unplug unit and you are good to go.
If no sub-freezing temps are expected, turn off water supply. Turn on washer for a warm wash cycle for a few seconds to relieve the pressure in the hoses. Turn off machine and unplug it.
Nov 04, 2009 | Kenmore 22422 Top Load Washer
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Washer won't rinse, drain or spin.
My guess would be that you have a faulty timer if you can manually move it and the operation of the washer resumes.
http://tclaundryrepair.com/
Feb 18, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
284 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
