Question about Kenmore 64802 Top Freezer Refrigerator
Water has been repeatedly pooling on the bottom of the frig (under vege and fruit drawers) and on some shelves. I tried to trace the leak, but having difficulty. Refrigerator (and freezer) is still cooling. Twenty minutes ago I flipped off the "power miser" button and have not seen any water collecting since then. Help! Thanks!
  • 4,070 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jun 05, 2010
GE side by side, GSS22UFMWW, water dispensor does not work, when I try it water leaks from the bottom of the frig. I can hear it pumping.
Turns out there is actually a small drain hole on the bottom of the freezer where condensation and such goes. Take out your bottom drawer/shelf and look in the back of the freezer.
Pulled out the bottom white tray that is under the wire shelving and at the back of the freezer is a small hole. Pour in a cap full of bleach and then 1 cup of boiling water. There can be condensation builds up and clogs the hole.
Sep 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
How to stop water from pooling on the middle of shelves. The water seems to come from nowhere. Also, what is the best setting for the humidity sliders on the fruit and vegetable drawers.
If it is a static appliance with a ventilator this can happen at colder settings you can try to increase the setting so the condensation can be decreased.That water is the condesed water which comes from your food.
Actually these has a very small impact if you do not have %100 sealed drawer.If you have fresh vegies it should be totatlly closed so the humidty levels increase in the drawer so the freshness.
Sep 26, 2009 | Maytag Refrigerators
Water is forming on the floor. Appears the water is pooling under the crisper drawer, then seeps through the seal. GE TBX 18CI. Any ideas?
You should not have any water at all forming inside the frig compartment unless you have a water dispenser on the frig. The water resevoir is located in the frig compartment at the bottom behind crisper. There may be a small leak or loose water connection on it. Hope this helps.
Jul 24, 2009 | Refrigerators
Leaking water
the water reservoir tank could be your problem, take out the drawers and operate the dispenser and see if water is leaking from it. if so replacement of the tank is very easy
May 21, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Water collects on shelves and below the crisper bins at bottom
Your defrost drain hole is frozen closed.
Remove the back freezer panel and defrost the ice with a hair dryer.
Once the drain is clear poura 1/4 cup bleach in the drain hole.
Mar 11, 2009 | Refrigerators
Water dripping from somewhere inside the refrigerator
I believe the problem is with the drain line when the frig goes into defrost mode
see if you can trace the drain line that oes into the evaporator pan at the bottom of the frig
facing the frig remove the bottom panel that goes across the front and pull out the evaporator tray to see if it is dry
take a flashlight and see if you can see a plastic tube that the water should be dripping into the pan
try to trace the tube up into the frig ther is some type of catch basin inside the frig on the back panel usually around middle area
If you are not able to find it you can call whrlpol customer service 1-800-253-1301
or call an appliance service enter and as them f they can walk you through the problem
Good Luck
Jan 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking water
test: first, turn off water supply to frig. then dry up all water. then ensure frig is running at right temperature. now gradually turn on water and observe where leak is. My guess is it is overflowing the ice-maker. there is an adjustment for this. pop off the cover over the end of the ice-maker. look for a screw adjustment. turn it counterclockwise.
Jun 04, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Kenmore 64802 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
