Question about Proform XP Weight Loss 620 Treadmill
Was running on my vibelife r211 and the fuse blew, replaced the fuse bu when I press start it blows again
  • 713 Answers
Hi,i think you should check the power that is supplied into the treadmill,the voltage supplied into the treadmill is higher than the desired voltage for your unit,hence the fuse keeps blowing up as an in-built safety mechanism which prevents damage to the entire unit,perhaps you should get a power surge to protect the treadmill from excessive voltage supply.
Thanks and take care
Posted on Jun 05, 2010
Honda metropolitan 05 Met II blowing 15 amp fuse
Did the scooter start OK when you first started it after bringing it out of storage, or did you have to use the kick starter? Maybe the battery is faulty and is pulling a lot of power.
Check the charge rate with an ammeter (use a multimeter that can measure 20 Amps DC) and see if the current exceeds the 15A rating of the fuse. If it does, replace the battery.
Sep 27, 2014 | Cars & Trucks
GE Spacemaker microwave makes groaning sound when start button is pressed for a second or two then blows the internal fuse. After replacing the fuse everything seemed to work, lights, exhaust fan, cl
Could be a lot of things but most probably a shorted high voltage diode assembly. If not that then the magaetron or capactors. Remember be careful there are high voltages even when the oven is unpluged. The capactors are usually charged and must be discharged. If you don't know what yor doing then time to get a qualfied tech.
Good luck
Feb 14, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Vr v8,engine fuse keeps blowing,what could be wrong? i have just replaced fuel pump
My friend had same problem so i waited till fuse blew an what i was doing when it blew the nutrel safety was getting hot replaced it now he is good to go
Oct 14, 2017 | Cars & Trucks
My power window and door locks fuse keeps blowing.
When the fuse blows figure out what you are doing, what switch is being pressed, then remove the needed panels to access the wiring to the switch and motor it operates, then you will find the damaged wiring and repair the short, no quick fix, just hard grunt work.
Mar 16, 2017 | 1996 Toyota 4Runner
Vibelife 7117 Error message E1, blowing fuses. Will not start at first, just gives E1 error message. Leave it paused for a while, then it will start but blows 15A fuse straight away. Have disconnected...
There is no solution to this problem. Its a Vibelife brand - that's the Problem! Vibelife is like any number of Chinese, Taiwanese build clones, they are ordered in a batch of several thousand by some dodgy importer and once that batch is sold on ebay or ozauction, its close up shop, order another batch with a different faceplate on the control console and away they go again. In short you've got buckleys chance of fixing it so my advice is:
a. Chuck it and get another one of those el' cheapo treadmills. After all they generally last about a 18 months under normal use and you can afford to buy four of those before you match the price of a professional home use machine.
b. Kind of like above only buy the professional home use machine for about $2600 and make sure is has a 3yr warranty on the motor and control boards. They should last you at least 5 years under normal home use.
c. As for a. but forget buying a treadmill, Invest in gym membership. For about the same price as an el' cheapo treadmill you could have a year's membership, all the treadmills you can use and a whole heap of other machinery as well, not to mention the excercise classes you could go to for fun, socialising and general fitness.
Jul 21, 2011 | Sport & Outdoor - Others
Where to start looking for a short in a 1992 ford ranger. keeps blowing the fuse that runs the dash lights and the tail lights ..first it blew .i replaced .was fine till next night .turned on lights...
connector under the truck, near the trans
cannot remember specifics at this time but remember starting there every time one cam into the dealer with tail light issues and blown fuses
Jun 17, 2010 | 1992 Ford Ranger
Fuse blowing
Your exhaust vent is blocked.
Timed dry is High heat.
Permanent press is a medium heat and intermittent.
The dryer does not get as hot as often in Permanent press mode. Therefore the fuse does not reach critacal and blow.
Remove the vent at the rear of the dryer and run a timed load.
If it dries correctly, repair your vent blockage.
If not, repost and I will lead you to the next step.
Feb 19, 2009 | Kenmore Dryers
Sharp R-9H66C Microwave Convection blowing fuses
check high voltage transformer and high voltage diodes, condencer, and magnetron.,
Oct 27, 2007 | Sharp R-963 Convection/Microwave Oven
Proform XP Weight Loss 620 Treadmill Logo
293 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
