Question about KitchenAid KGYS850LT Gas Dryer
Kitchen aid dryer Partial drying the cloth
Kitchen aid dryer is Partialy drying the cloth
  • 336 Answers
First you should make sure the exhaust vent and ducting and lint trap is not clogged or restricted, birds/insect nests, or lint build up. If the dryer is heating up it is most likely an airflow issue.
Posted on Jun 05, 2010
Testimonial: "Cleaned the vent, ducting and lint trap, the dryer is working. Thank you very much."
  • Drew Jun 06, 2010
    I'm glad I could help. Thank you for using Fixya.
Our Kitchen Aid Gas dryer is heating, but not drying the clothes. Can this be fixed?
If your
dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about
Dryer Maintenance
heatman101
Jan 19, 2011 | Dryers
Clothes take long to dry on Kitchen Aid Model - KEYE660WWHO
First thing to do is vacuum out all lint from dryer, unplug, remove back and vacuum all lint out of it, also where vent hooks up. Then clean out duct work from inside of home to where it exits. Excess lint holds moister and causes dryer not to dry.
Sep 27, 2010 | KitchenAid KEYS850LQ Electric Dryer
My kitchen aid dryer does does not reach the higher temperatures it used to--it takes a much longer time to dry clothes.-even when set at "high"
Please clean the entire vent system from the dryer to the outside.
Make sure the vent is not smashed behind the dryer.
Long time to dry complaints are usually due to restricted house exhaust vents.
To test...Remove vent from dryer and operate dryer with a wet load if the unit dries ok the vent is @ fault.
If not one stage of the heat element could be burnt out.
Jan 19, 2010 | Dryers
Ink stains vin my frontload gas dryer
Spray hairspray onto cotton and wipe off. Then wipe out the hairspray with a clean damp cloth before drying again.
Sep 24, 2009 | Whirlpool Dryers
Doesn't heat to dry clothes.
i have the same problem and am looking for a solution too so i will write back and let you know
Mar 27, 2009 | KitchenAid Dryers
I am trying to figure out the capacity on my Kitchen Aid dryer, model KEYS677EQ1.
dear customer the capacity for a dryer is mostly comen sense for example if you dry blankets they are farly heavy you can put as much as you like in your dryer but dont forget that wet cloth is heavy on your dryer or wet jeans it will work no problem but on the long run your dryer will wear out faster because of the weight normal clothe what goes in the washing machine goes in the dryer thankyou have a great day from gilles
Mar 15, 2009 | Dryers
The dryer heats up & spins,clothes don't dry,lint areas are now clean
restriction in your vent check it from the back of the dryer it must be 4 inches in dia and clear get a flashlight and look behind the dryer see if its mashed coiled or folded check the dryer hood make sure if there is a bird screen on it its clear easy way to tell if vent is at fault disconnect from dryer and do a load then let me know
Jun 05, 2008 | Roper REX5635E Dryer
Gas clothes dryer not drying clothes
could be an ignightor problem reply and we can talk
Jan 03, 2008 | Dryers
KitchenAid KGYS850LT Gas Dryer Logo
280 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
