Question about SimpleTech 120GB SIMPLEDRIVE PORTABLE USB 2.0 DESIGNED BY PININFARINA 120 GB Hard Drive
I have a SimpleTech 120GB external hard drive. The USB connection port at the circuit board is broken. Can I buy a new plug-in circuit board and hard case for this unit?
  • 192 Answers
Simpletechs have a three year warranty so if your drive is newer than that it is covered. You can go to www.simpletech.com (they are really hitachi drives) for details on warranty repair. If you are sure its not covered the case can be opened and inside you will find a SATA drive and you can buy a new SATA external enclosure for 19.99 at Radioshack. This includes the circuit board, cable, and new case.
Posted on Jun 05, 2010
  • 8,404 Answers
Take your drive to the computer repair shop in your town and have the guy there fix this for you. If he or she cant do it ... they can make a recommendation.
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
Freecom usb port broken away from circuit board inside enclosure
It is hard to buy replacement for the same enclosure, but there are many USB2.0/3.0 enclosures available on the market for 2.5 and 3.5 inch drives.
Make sure read reviews for issues and performance on those enclosures.
Apr 10, 2014 | Freecom Xs External Usb Hard Drive 2tb
For the last couple of months I've had to un-plug, then re-plug my EHD to get it to be recognized by my HP laptop. Today my HP says that the device is not regonized. Can the Signature Mini be re
If you have a SimpleTech SimpleDrive connected to your computer and you're experiencing problems with the external hard drive, there may be several reasons why it's malfunctioning. Troubleshooting your computer can help rule out common problems and the possibility that the hard drive may be defective. If you recently purchased the device and suspect there is something wrong with it, return the defective drive to SimpleTech or the reseller for a replacement. Incompatible USB Port Problems SimpleTech SimpleDrive plug and play options makes it easy for you to connect the device to your computer. But you may encounter problems if your computer's USB (Universal Serial Bus) ports are not compatible with the external hard drive. Make sure your ports are powerful enough to operate the drive. USB 2.0 ports are recommended, but if you're using an older computer with 1.0 ports, the hard drive will function much slower or you may receive an error message that the device is not compatible with your system. b> Missing External Drive Letter If you're unable to find the SimpleTech external hard drive's letter on your desktop after you have installed the drivers for the device, it's possible that the external drive may be assigned to another drive. Sometimes, the hard drive is assigned to a network drive and you may need to manually change the drive's letter in Disk Management. b> SimpleTech SimpleDrive Incorrectly Formatted b> SimpleTech SimpleDrive is normally pre-formatted for Windows NTFS (New Technology File System), but Mac users may need to copy the backup software and reformat the external hard drive for FAT32 or Mac OS to be able to use the external drive. If the external hard drive is not formatted correctly for your system, it may not function or work properly. b> External Hard Drive Inaccessible If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing.
Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
Replacing a Defective Hard Drive You can return a defective hard drive that is under warranty to SimpleTech. The manufacturer will exchange the device if the seal is not broken. But if you break or tear the seal on the case, any warranty claims will not be accepted and the device will be returned back to you. SimpleTech will only accept the device if you contracted a commercial data recovery company to retrieve critical data from the external hard drive and the seal needed to be broken. Before returning the defective drive, you will need to secure a RMA (Return Merchandise Authorization) approval number from SimpleTech and furnish any invoices or documentation regarding the data recovery company's services
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/ these can be purchased on Ebay cheap and easy to install http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d for roughly $9 or $10free postage Hope this helps.
Jan 24, 2013 | SimpleTech Signature Mini 250GB External...
When i plug in the usb to my computer it is not recognized and does not show anywher
b>
Dec 14, 2012 | SimpleTech 500GB SimpleDrive Pro External...
Won't recognize external hd
Dec 11, 2012 | SimpleTech SimpleDrive Pininfarina 500GB...
Broken wires between control board and the light board sp-u35/160gb
Can I buy a new print control board my bud has one was able to get it working his put my hard in his Simpletech but where do u buy parts ? eclyde@metrocast.net Thanks
Oct 17, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
Computer is not recognizing
If you receive an error message that says "Drive Inaccessible," the SimpleTech SimpleDrive may not be able to read the service area of the platter. If the external hard drive emits a loud or abnormal sound, this could mean the device is failing. Test the drive on another computer to see if it is working properly. Otherwise, the external hard drive's surface area may be damaged or corrupted.
hope this helps
Oct 15, 2012 | SimpleTech SimpleDrive Pininfarina 320GB...
I have a simpletech 120 GB external USB hard drive with NO power supply. Do you know what the power rating is (ac or dc, how many volts, amperage...) or where I can get a new power supply for it? -Thanks
12VDC, 1.5A external power adapter Well that is what this page says, it's not your 120GB drive but unsure if it's no the same model maybe. However all external HDD that need a power supply should be needing 12 volts, as they are just internal drives mounted in a shell and some simple circuitry to power and connect it.
May 22, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
I have a 320GB external usb and it is coming on but not being recignized by the computers. Blue light comes on and goes off, it maks noise as if it is running. BUT my computers detect new hardware but says...
The problem is with the controller board inside the SimpleTech drive. The solution is to remove the 2.5" form factor SATA drive from the case and install it into a new case. I have had 2 SimpleTech drives (both Pininfarina style) fail on me and in both cases it was the controller board and NOT the hard drive inside.
To remove the drive you have to remove the label on the bottom that says "Do not remove or you will void your warranty. Under that label you will see two phillips head screws. Remove them and the case can then be pulled apart. The controller board is screwed onto the bottom of the hard drive. Remove the screws and slide the board carefully off of the SATA connection and power ports and now you have a bare drive.
Go and by a 2.5" SATA form factor hard drive external case from some PC store or from eBay. I got mine on eBay for $10.00 including shipping. Install the drive in the new case plug it in and away you go. Make sure that you buy one that DOES NOT NEED AN EXTERNAL POWER SUPPLY.
It is almost NEVER the hard drive itself that fails it is almost always the controller board. Make sure that you open the case and check that your hard drive is really a SATA drive before ordering the case. If it happens to be PATA (IDE) then make sure you order an external case for that type of drive. They are NOT the same and you HAVE to get the external case that mates with your hard drive.
Good Luck,
John
Aug 17, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
My SimpleTech Hard Drive has stopped working
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Mar 13, 2009 | SimpleTech (SP-U25/120G) 120 GB USB Hard...
SimpleTech 120GB SIMPLEDRIVE PORTABLE USB 2.0 DESIGNED BY PININFARINA 120 GB Hard Drive Logo
490 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
