Question about Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor for 56j Frame Motors Ust1152
Turning off 3 or 4 times the pump worked to start priming. then it stopped and just hummed. It also tripped breaker....Do they have auto shut off?
    President:
  • 2,702 Answers
The pump motor has a short in it, most likely to be in a field coil it may be repaired but its likely to be far cheeper to replace the motor and there should be a way to turn it off,,,the brakers will trip every time the motor starts to humm becouse the motor is pulling far to many amps for that trip so to save a "fire!" it trips out,,,,do yourself a big faver and have it looked at fast
Posted on Jun 05, 2010
My utilitech 1.5 hp pool pump keeps tripping the breaker. What is wrong?
check and test pump motor possible failing but try lubing bearings and check pump impellers for debris
May 03, 2017 | Pool Pump Pool & Spa
The circuit breaker trips as soon as the circulation pump tries to start on initial priming. I think that the soft start on the pump has stopped working is this likely and can it be repaired without...
you might have a weak breaker. or a dirty start switch and or a bad capacitor.; search you area for your local pool pump motor repair guy with free testing.. a repair to the motor should cost 20-85$.. remember to prime the pump after a repair.. jay Florida . hit the yes if i was of help
Aug 29, 2011 | Emerson Pool & Spa
Haywood Max-Flo Pump (self priming)for indoor inground pool 3/4 HP ... model C48J2N131A -- yesterday turned off master breaker switch to everything in the pool area (including power to pump) so that I...
The motor may have blown the start capacitor. It is the black cylinder about 1-1/2" dia x 2-1/2" long. Look at the end with the wires for a small hole. Is it blackened or have a hole blown thru? If so replace it. Otherwise have a local electric motor repair shop look at it for possible repair or replacement.
Sep 06, 2009 | Hayward Pool Products Hayward Max-Flo 1...
Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Jul 06, 2009 | Emerson Pool & Spa
Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Jun 28, 2009 | Polaris Pb4 - 60 Booster Pump
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 | Garden
My self priming pool pump all of a sudden stopped pumping. It is set to run everyday and one morning it was making a humming sound but wouldn't start. This has happened in the past before so I thought it...
You too can find out my solution for just $ 9.95. I was looking for some advice so I looked elsewhere until I found it. Thank you anyway for your time.
Jan 14, 2009 | Pool & Spa
Hayward 1.5hp Pool Pump Motor Motor A O Smith Electric Pool Motor  for 56j Frame Motors Ust1152 Logo
188 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
