Question about Singer 2639
My singer 2639 will not unlock on side to fill bobbin the foot keeps going up and down my bobbin willl not fill on top.
SOURCE: Singer Futura 900
Complete instructions for filling the bobbin and threading the Singer Futura 900 can be found here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_900_futura_threading.htm
Posted on May 07, 2008
SOURCE: bobbin filling on Singer 626
The Singer 626 has a self-winding bobbin. You place the empty bobbin in the bobbin thingie (sorry for being so untechnical). On the left of the bobbin you will see a "lever" with a circular top on it (I think it is red-ish) Again, sorry for being so untechnical. Press the "lever" down. Thread your machine, thread the needle, wrap the excess thread from the needle around the knob that tightens the needle and holds it in place and press your foot down on the foot pedal. The bobbin will automatically wind as you hold the foot pedal down. Do not wind the thread onto the bobbin past the outer white line.
Posted on Sep 29, 2008
  • 22 Answers
SOURCE: Top stitch looks good, bottom stitch is loopy
this is a common problem, don't worry it's easy to fix.  take the spool of thread off, remove the bobbin.  look for any stray thread pieces in or around the bobbin case, rethread the top of the machine and when you do, follow the threading guide precisely and ---here's the trick---make certain that the thread goes between the tension discs.
Posted on Jan 17, 2009
jpack76645
  • 23 Answers
SOURCE: Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
Posted on May 29, 2009
SOURCE: singer futura model 900 sewing machine
Recently had same problem. Underneath the bobbin area on the bottom of the machine is a small white plastic piece that resembles a fan. Singer calls this the bobbin cam actuator. It is usually cracked along the sleeve that fits over the metal pin, bar? This is the mechanism that lifts the bobbin when it is wound. When its broken it can't lift the bobbin to be wound properly.
Posted on Sep 12, 2009
Bobbin thread picks up when there is no fabric in machine,as soon as i put fabric under the foot it skips stitches or doesn't catch at all. have changed needles, re threaded and adjusted timing.
I have run into this problem on newer light weight machines.
Remove the nose cover and look for thread wrap in the upper tension control, even a small piece of fluff can keep the discs from closing when you drop the presser foot.
Try not to disassemble the upper tension control because they can be tricky to get back together.
Check around the slack arm, thread will wrap-up at the pivot.
Good luck.
Feb 18, 2016 | Singer 2639
Need to adjust feed dog height on a singer protoge #2639
there should be a small set screw under the cover where you feed the bottom bobbin at. if you turn it right, it will tighten, and should raise it.just remember how many times you have turned the screw.
Oct 17, 2013 | Singer 2639
How to install bobbin in singer 2639
Go to the singer website for a free manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 2639) & click search
Jul 27, 2012 | Singer 2639
Model 2639 you can hear it working, but the needle does not move at all
Check your bobbin winder mechanism that it is disengaged. Go to singerco.com and go to customer support.
Aug 29, 2010 | Singer 2639
Bobbin problems
Definitely needs retiming, I can attach instructions if you email me. drivewithken@blueyonder.co.uk
Jun 26, 2010 | Singer 2639
How do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Machine will not pick up the bobbin thread.
if your machine's needle threads from front to back, make sure that the flat part of the needle shank points to the rear of the machine. If it threads from left to right, the flat side should face right, etc.
Jun 08, 2009 | Singer 2639
Buttonholer on Singer 2639 sewing straight ahead
set you machine for "zigzag" then: try your buttonholer again.
Also; the thread tension can be adjusted by a small screw in the side of the bobbin for the bottom loop of the stich or, the tensioner on the side of the machine head for the top loop
May 28, 2009 | Singer 2639
Bobbin filling on Singer 626
Aug 17, 2008 | Sewing Machines
Singer 2639 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
