Question about Margaritaville Frozen Concoction (DM1000) Blender
THERE USED TO BE A BLACK TURNER THAT SCREWED INTO THE BOTTOM OF MY BLENDER JAR IT WAS PLACED OVER THE BLENDER BOTTOM. SOMEONE MISPLACED IT.
  • calasheba126 Jun 06, 2010
    yes,it was very helpful,i hope. anyway i'll call them tomorrow & see what they say
  • 881 Answers
Rather than trying to find that lost turner, you can buy a replacement Jar directly from their website. It cost around $40. The link is below:
Margaritaville.com
or try calling them for a replacement if your case is covered by the warranty. Here's their number:
1-877-689-2737
You can also email them here:
nsg@spemail.esecurecare.net
Posted on Jun 05, 2010
Krups blender switch lights, but motor doesn't turn
Hi I take it that the bottom was not screwed tight when the milk spilled. Try unscrewing the bottom, take it apart and clean it in warm water and mild washing liquid . Put it together again and screw tightly. And off it should go.
kolbrun
Mar 14, 2014 | Krups KB790 Blender
How do i get the bottom off the blender jar?
The best way that I've found to remove the bottom from the blender jar is to put the blender jar back on the blender base (make sure it locks in place) and then turn the jar to the right. You'll feel the jar detaching from the base. Once it's loosened up, remove from the base and finish turning the bottom, manually. Before I found this method, I had tried everything to get the plastic bottom detached from the jar. Without removing the bottom, there's no way to clean it properly and rather than be unsafe I'd need to throw the whole works in the trash. But the method I've described above works every time!
Aug 13, 2011 | Jenn-Air JBL800 Work Top Blender
Misplaced manual. How to assemble Cuisinart Smartpower 7 speed electronic blender- Specifically need to know where to place the gasket.
Hello, W/D here.
You can download your manual here:
http://www.cuisinart.com/manuals.html
It is at the bottom of the page.
On page 4 of the manual is the instructions for assembly of the jar. With the jar upside down, lay the gasket on the threaded area, insert the blade/plate, and screw on the base. Nothing to it.
Best regards, --W/D--
Jan 30, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
Ultrex blender #08330, will not turn in lock position,whats is wrong??
MAKE SURE THAT NOTHING IS BROKE AT THE BOTTOM OF THE JAR.
I HAVE THIS EXACT MODEL AND HAVE NOT USED IT FOREVER...EXCEL CONDITION, TRYING TO SELL TO SOMEONE WHO WOULD LIKE IT.
NOTHING WRONG, JUST DON'T NEED IT LAYING AROUND COLLECTING DUST.
THIS BLENDER IS AWESOME!
INTEREST?
Nov 24, 2010 | Blenders
GE Blender Jar loose rotator
Remove the bottom clean the unit fully. Add the bottom blad assebly and this will fix your problem. The "sooty" is plastic shavings. Take note that the fitting were the "jar" connects to the motor that this is not wearing away. The unit i have broke and i am unable to find a replacement blade assembly.
Apr 04, 2009 | Blenders
Will not work
First ensure that the blender jar is placed on the right orientation, othherwise the blender wont start.
Remove the Jar and place it on the other way if you are not sure.
If you still get the click, try leaving the blender power cord unplugged for a while. The click means that the blender has power, but the motor is not starting.
If it still does not work , and the jar is in the correct way and you did the above, then the blender is faulty, probably a faulty motor, or a broken wiring.
Dec 19, 2008 | Krups 574 Power Xtreme VI Premium Work Top...
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Margaritaville Frozen Concoction (DM1000) Blender Logo
75 people viewed this question
Top Margaritaville Blenders Experts
john h
Tom Chichester
Are you a Margaritaville Blender Expert? Answer questions, earn points and help others
