Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
GE Side By Side Ice Machine & Water dispenser not getting water
I have defrosted Freezer. Water leaks underneath when I depress the water dispenser. Water is at the filter. Line at the freezer door for dispenser is dry.
Ice maker has had hot towels & seems dry. No melting ice.
No leaking in the back
I did not defrost frig. 10 year old Profile
Ice Maker & water dispenser making correct noise.
Only leaking when engaged
  • 166 Answers
You may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Posted on Jun 05, 2010
Ice build up on the floor of the freezer. A water leak on the water line supplying the ice maker and water dispenser??
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Refrigerator Freezer has ice forming in the bottom inside freezer section. It appears to be leaking down the back inside compartment. The top section has an ice maker and water dispenser but I haven't had...
I believe you just described a defrost condensate blockage that is causing the leaking. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a in the defrost pan, water leaking and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
Nov 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Where is drip pan on profile side-by-side
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 13, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
668 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
