Question about Miele Red Star Bagged Canister Vacuum
Miele Red Star, small spark at outlet, no power to vacuum
Just borrowed my mothers Red Star to clean my new place... Used it in one room perfectly, and about 2 hours later brought it to a different room to use. Plugging it in in this room created a tiny spark at the outlet, (tiny tiny white smoke puff and pop) , I heared the vacuum start for half a second and shutoff... The outlet still has power, and I have tried other outlets. As of now I still cant get the thing to turn on... Is there any way I can fix this myself? It must have tripped a fuse inside the vacuum or something. I am pretty handy, any tips? She needs it back tomorrow!
  • 52 Answers
The vacuum has a standard tube internal fuse. If you are lucky that is all it is. See the site http://www.sannerud.com/house/miele.html for instructions on how to open it up.
hope that helps
Posted on Aug 11, 2010
I need a new motor
red star was part of there low end line. not cost effective as miele parts prices are outrageous.
May 06, 2010 | Miele Red Star Bagged Canister Vacuum
Meile red star
Yes, this very well could be a problem with the cord reel, especially if it happened all of a sudden. There's a few ways that you can diagnosis this problem yourself. First make sure the cord is all the way reeled into the vacuum. Next find an outlet that's close, and only pull out enough cord as you have to, to be able to reach the wall outlet. After you've plugged the machine into the wall, use one hand to slowly pull more cord out of the vacuum, and use the other hand to continuously turn on and off the vacuum pushing the foot pedal that controls the main switch. Slowly pull the cord out, and turn the vacuum on and off, on and off, on and off.
At any point while you were doing this did the vacuum come on, even for a very short time? Did it even make a noise like it was trying to start? If you heard a noise, or the vacuum even came on for a time, then this definitely indicates that you have a bad cord reel.
If it didn't make a noise or come on, you still may have a cord reel problem, but you'll need to take the machine apart to further diagnosis it at this point. A simple continuity electrical tester will be needed to test the cord reel.
Here's a very detailed repair instruction that I left for a similar model Miele on Fixya already. The model that you posted the repair under is a Miele Red Star which is an S314i, the model I repaired the cord on was actually a S514. The cord repair on both of these models is identical however, except your Red Star actually has two screws that need to be removed from the variable speed control box, the S514 only has one. Otherwise, it's almost completely the same repair. If you need to purchase a cord reel for your Miele, here's a direct link to the Miele S300 series cord reel that goes with your Red Star:
http://www.govacuum.com/miele-cord-reel-s300-series-06777540.html
Even better, if you purchase the cord reel from GoVacuum, you have 60 days after the purchase that you may return the cord reel to us if that wasn't the problem (we do test all the returns to make sure that they weren't damaged when being installed), and as long as the cord reel is returned undamaged, we give you a full refund, we don't believe in restocking or shipping fees. Better yet, we even include a return label with every order that you may use for free to avoid return shipping charges.
If you find that the cord reel is not the problem, that can only leave one of three things; the switch, the motor, or the pc control board that's on your motor. In 10 years of fixing Miele vacuums however, I can safely bet that it's your cord reel.
Anyways, here's the link to step by step instructions on how you can remove the cord to test it, as well as replacing it. If you have any questions, please feel free to use the Clarification or comment form here on Fixya, or contact us by phone. If this was helpful to you, please be so kind and rate my repair as helpful by clicking the thumbs up icons at the top of the page. Thanks so much!
How to Test & Change a Miele Cord Reel:
http://www.fixya.com/support/t2281026-miele_s514_will_not_come
Chris J.
GoVacuum
Apr 06, 2010 | Miele Red Star Bagged Canister Vacuum
Miele s314 red star-motor stopped working-on/off switch broken?
Most likely the problem is with the cord winder. This is the most common problem with Mieles. It is actually the most common problem with any vacuum with a cord winder. A Miele repair center should not change you to look at the vacuum and tell you what is wrong with it. The Red Star was a great model and if the powerhead is still in goood condition I would get the vacuum repaired. If it is the cordwinder they can usually be repaired and it should cost about $75.00. If you need a new cord winder this will cost about $150.00. The top piece can be pryed off, however if it feels like it is switching than it is not jammed.
Oct 08, 2009 | Miele Vacuums
Miele Red Star Powerhead overheats and turns off
be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
try to test your cleaner by use less length hoses
thanks
Jul 04, 2009 | Miele Red Star Bagged Canister Vacuum
Our vacuum (a miele S718) has cut out.
Probably WAY too late to help you now, but may be of assistance to others (I repair appliances): Several times, I've had Miele Vacs which show the red light, but the motor never powers up. If the vac was working perfectly before, 98% it will be a bad solder joint on the Motor pcb. Although it varies per vac: Remove the bag & 4 screws around.
Unclip & remove lid (flex off pivots), then remove centre screw. Lift off control panel. Remove all other screws under the control panel area.
Lift out motor & unscrew motor pcb. Turn over & inspect for any black joints - repair as ness. Reassemble in reverse order - note: difficult to locate top cover back on if lid wasn't removed, as lid power connection can interfere. Hope this helps...
Jan 31, 2009 | Miele Red Star Bagged Canister Vacuum
Miele cannister vacume power head not working
take me off your list ..... tell people that their is a charge before they give personal info .....rip off!!!!!
Nov 24, 2008 | Miele Red Star Bagged Canister Vacuum
I have a Miele Red Star vacuum, model 314i. I bought a HEPA filter for it but am not sure how to install it.
At GoVacuum we put together a General Miele Maintenance video together for Miele Owners. Although the video showcased in the video is not specifically your Red Star machine, the filter installation is going to be the same.
Check it out here:
Sep 03, 2008 | Miele Vacuums
New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Feb 21, 2008 | Miele Red Star Bagged Canister Vacuum
Miele Red Star Bagged Canister Vacuum Logo
446 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
