TruTech PVS12701 Portable DVD Player Logo
Posted on Jun 05, 2010
Shuts off on its on - TruTech PVS12701 Portable DVD Player
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on Jun 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
12493
Points
45
Resolder everything inside back onto the board
Hi. I have a Hayward H350FDN pool heater that is Doing this: • Turn on and Temp at 65 • On for 3 1/2 min then shuts down • Restarts and then on for 5 min, shuts down • Restarts and then on for 2 min,...
it almost sounds like the temperature sensor is in the wrong place. that or the flow is inadequate for the heater to run. if you have a sand filter, put it on 'whirlpool' or 'recirculate' and try to run the heater.
Drive belt john deer scott mower detail
Computer ?? Turn Off ??? ???? ???? - Shut Down Computer.
????? ?????January 3, 2018 TP Staff??????
Computer ?? ??? (Shut Down) ???? ?????
?? Computer ?? ???? ????? ?? ???? ?? ?? ?? ??? ??? ?? ??? Computer ?? ???? ???? ????? ??, ?? ??? ?? ???? ??? ?? ?? Computer ?? Turn Off ???? ????? ??. ???? Computer ?? ???-??? ?? ???? ???? ?? ?????. Computer ?? Shut Down ???? ?? ????? Computer ???????? ???? ??. Computer ?? ????? data ?????? (Save) ???? ?? ?? Computer ?? Turn Off ???? ?? ????? ?? ?? ??? ???? ??. ???? ??? ???? Computer ?? Turn Off ???? ???? ??. ?? ???? ?? ?? ???? Computer ?? Turn Off ???? ??.
???:Computer ?? Turn Off ???? ?? ???? ?? ????? ?? ????? ???? ?????.
1. Computer ?? Turn Off ???? ?? ???? ?? ????????? ?? ?? ?? ???? ????? ???? ??? ??? ?? save ?? ??? ??. ???, ??? ??? ???? ?? ?? ??? ?? ???? ??.
2. ?? ??? program ?? ????? ?? ??? ?? ?????? ?? Computer ?? Turn Off ???? ?? ???? ??? ?? ???? ?????.
3. ???, ???? ??? disk ???? ??? ?? ?? ??? ?? Computer ?? Turn Off ???? ?? ????? ????? ?? ???????? ??? ?? ?? ???.
?? ?? Computer ?? Turn Off ???? ?? ??? ??????? ????? ??. ?? ??? ??? Computer ?? Turn Off, ??? Shut Down ???? ?? ???? ??, ?? ????? ?? ???? ???????. ?? ???? Computer ?? Turn Off ???? ??.
??? ?? ????: Computer ?? ???? (Start) ???? ???? ???
Computer ?? ??? ???? ?? ???????
???? 1.
1. "Windows Start Button" ?? ????? ????. ?? ??? ??-????? ?? "Windows logo key" ????.
2. Start Button ?? ?? ????? ???? ?? Start Menu ??? ???? ??.
3. ??? Start Menu ?? "Shut Down Button" ?? ????. ?? ???? Start Menu ??? ????? ?? ???? ??????.
4. Shut Down Button ??? ?? ??? ???? ??, ???? Shut Down ?? ????? Arrow. ?? ?? ???? ???? ??? ?? ????? ???? ?? ?? ????? Computer Shut Down ?? ?????.
5. ???, ?? Arrow ?? ????? ??????? ?? ???? ????? Shut Down Button ?? ????? ??? ?????. ????? Computer ?? Turn Off ???? ?? ??????? ??? ?? ??? ???? ??.
???? 2.
?? ?? Keyboard ?? ?????? ?? Computer ?? Turn Off ???????. ?? ??? ??? ????? ?? ??? ??. ?????, ???? Computer ?? Turn Off ???? ??? ??? ?? ??? ???? ??. ?? ????? ??? ?????? ??? ?? ???? Computer ?? Turn Off ?? ???? ??. ?? ??? ?? ????? ?? Computer ?? Shut Down ???? ??.
1. ???? ???? ??-????? ??Alt + F4?? ??? ?????.
2. ?? ??????? ?? ????? ?? ????? ?????? Shut Down Window ????? ????? ??? ??.
3. ?? ???? Shut Down Window ?? Drop Down List ?? ????? ??. ???? ??? ?? Arrow ?? ????? ????.
4. ?? ???? Drop Down List ?? Shut Down ?????? ?? ????? ???? ?? ???? ?? select ?? ???.
5. ???? ??? ??-????? ??Enter????? ?? ???? Computer Shut Down ?? ?????.
???? 3.
?? ????? ???? ???? ?? ??????? ??? ??. ?????, ?? ????? ?? Computer ?? ??? ?? Turn Off ??? ???? ?????. ????, ????? ???????? ????? ??. ????? ?? ????? ?? ???? ????? ?? ??? ??.
1.???? CPU, ???? Case ?? ???? ???, ?? Power Button ?? ????? ?? ???? Computer Shut Down ?? ?????
??, ?? Computer ?? Turn Off ???? ?? ???? ??? ????? ?? ?????? ?? ???? ??. ???? ???? ?? ???? ?? Computer ?? ??? ?????? Turn Off ???? ?????. ?? Computer ?? Turn Off ???? ?? ???? ??? ????? ?? ????? ??? ???? ?????. ????, ?????? ?? ?? ?? ??? ???? ??? ?????? ??? ??.
May 04, 2018 • Garden
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Just replaced the circuit board after a technician told me that was the problem. White Rodgers 50A56-956. Getting the same result as the old board: clicks on, shuts off
White Rodgers relay clicks shuts off Surveillance Cameras ...
www.fixya.com > ... > Tags > relay clicks shuts off > Surveillance Cameras
White Rodgers surveillance cameras relay clicks shuts off related questions and answers. Ask your White Rodgers questions. Get free help from surveillance ...
White Rodgers car will start up but shuts off Surveillance ...
www.fixya.com > ... > car will start up but shuts off > Surveillance Cameras
White Rodgers surveillance cameras car will start up but shuts off related ...Thermostat works, clicks when turn on heat, shows Stage 1 on display (hooked up .
relay clicks shuts off Surveillance Cameras Questions ...
www.fixya.com > Forum > Tags > relay clicks shuts off
Surveillance Cameras relay clicks shuts off questions and answers. Ask your relayclicks shuts ... I have a white-Rodgers 1F86-244 thermostat. When I ... a new ...
Pull the keys radio never shuts off, I replace the fuse because it was burnt out.
radio will not shut off when car turned off - Car Forums and ...
www.automotiveforums.com > ... > Chevrolet > Cavalier
I have this anyoing problem..when i pull the key out of the ignition the radio ... They could not wire it so that when you opened the door, it would shut off. .... I NEVER had to do anything with the airbag wires or shut the airbag off or anything!
07 Silverado Will Not Shut Off With Key Removed - 1999-2006 & 2007 ...
www.gm-trucks.com/.../115642-07-silverado-will-not-shut-off-with-key...
Jun 27, 2010 - 14 posts - ‎8 authors
The only way I can shut it off is to pull the fue... ... It runs perfect as if I never shut itoff. It is not dieseling it runs like the key is on. The complete vehicle shuts down like it is off ie all dash lights, radio, go of and it will not allow the ...
VW Jetta MKIV/MK4: Stereo doesn't shut off with car 'Volksw
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
1helpful
2answers
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
1helpful
I have a 96 cadillac deville and my interor lights wont shut off
timer is bad that shuts them off after u open and shut a door
should go off when u get in and start up vehicle
Top TruTech Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
ExpressFiX
ExpressFiX
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
