Question about Hampton Bay 54 In. Dawson Ceiling Fan in Weathered Copper
Hampton Bay Fan will not turn on.
In the past the remote would reset if someone turned off the power. Now it seems to have lost the connection to the fan and no longer responds to the remote. Is there a way to reset the remote to the fans reciever?
  • 736 Answers
On some you hold down a button on the remote control while you turn power on .. you keep the button pressed for maybe 20 seconds .. i dont remember what button but probably fan on or light on .. the receiver acquires the code from the remote .. if you still have trouble i can probably find the specific instructions ..
Posted on Jun 07, 2010
This is a copy and paste that worked for me!! Awsome ,.--on some you hold down a button on the remote control while you turn power on .. you keep the button pressed for maybe 20 seconds .. i dont remember what button but probably fan on or light on .. the receiver acquires the code from the remote .. if you still have trouble i can probably find the specific instructions ..
Posted on Sep 15, 2011
  • MAGGIE Apr 22, 2013
    THANK YOU! IF YOU CAN FIND THE COMBINAISON, I WOULD LIKE, I'M TRYING ALL KINDS OF BUT IT DOESN'T WORK. THANKS
Remote for my hamton bay ceiling fan 70 inch model DL-4109S-01 won't work. How can I get it to work?
first off see if the remote is working
if it is a point in the fan direction is is probably infred operation. to check turn on the camera of your mobile phone and point the remote at the lens
if it is working then a white light will appear on the screen of the phone when you press on the remote on button and disappear when the off button is pressed
if that works then it will be in the receiver in the fan
Sep 05, 2015 | Hampton Bay Dryers
My Hampton Bay Brookedale ceiling fan worked fine for a while. Went to turn it on the other day and won't work. Ceiling fan remote seems to work (light goes on when buttons pressed) but fan or l
The light on the remote is a battery light. First mistake was buying a store brand fan which are mostly low-end parts. Try adding a different remote w/receiver.
Mar 02, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
I have a Hampton Bay Miramar 60 in ceiling fan, when you try to turn it on the upper light just blinks and nothing else happens. You can't even turn the blinking light off. HELP!!!
Turn off the breaker that controls power to the fan. Remove the batteries from the remote and press the buttons in case one is stuck. Reinstall batteries or new ones. Turn on the fan breaker and try using the remote again
Dec 16, 2012 | Universal Remote Control Hampton Bay...
Lost remote
Well you can purchase a universal remote in place of your lost remote. You need to connect the universal remote to your fan, universal remotes have a code search button or sequence. Turn on your fan, activate code search, & press the power button until the appliance turns off, then press the set button. or use the manual book provided by the universal remote manufacturer.
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Lost power. Fan will not turn on.
Sounds like the fan controller may have fried. You may want to get online and contact the manufacturer.
Jun 08, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Motor will barely run
If it's when you set the remote on med or high, check to make sure the switch on the fan isn't set on low. Turn the remote to high and pull the chain switch to see if it goes faster. Someone may have tried to turn it on or off with the chain, forgetting about the remote. Good luck.
Mar 26, 2010 | Hampton Bay 24002 Ceiling Fan
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
I Have a hampton bay ceiling fan mod. 523 342,
if you have connected power directly to the fan motor and it doesn't turn...replace the fan.  However, also check the switches on the fan as you may have bumped them.
Mar 24, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Mind of it's own
your remote and fan is set to someone elses frequency by little toggle switches
you will have to remove fan to where it hangs make sure power off
find the remote sensor inside electric case at ceiling in the fan
this is a dip switch to control frequencies
09c4f2f.jpg you will see something like this adjust the dip switches
means change the dip switch for fan
then on remote open the remote battery pack find the dip switch in there
change those dip switches to the same as in ceiling fan
put fan together and turn back on power
your fan should now not pick up the other frequency of another remote and they have a span of about 50 yards to pick up frequencies
Jun 07, 2008 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 54 In. Dawson Ceiling Fan in Weathered Copper Logo
526 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
