Question about Whirlpool GH7155XHS Microwave Oven
Whirlpool gold gh5184xpb Everything seems to be working but it doesn't heat. If you use the buttons for popcorn or dinner plate, an error message F3H appears. Recently got a wireless router in our home (three days ago, everything worked fine until now). Could that be causing the problem?
    President:
  • 2,702 Answers
Its very unlikley to be the wireless router,,,
things like this just happen,,,i would say the magnatron had gust given up the ghost, thats the part that gets the food hot,,,safest bet is have it looked at but get ready to buy a new unit as its likley to be the cheepest way out
please dont go poking about inside your microwave,,
it will still have 1000's of volts inside it,,, these volts will kill you if you tuch the wrong part,,be warned!!!
Posted on Jun 06, 2010
My plate just cracked while microwaving popcorn
Make sure you don't put any dishes in the microwave with something like popcorn because they retain more heat and have nothing to transfer the heat too. If you mean the built in spinning plate that you set stuff on and you have an older model the fan might be broken. Something similar happened to my microwave as it is pretty old i just removed the panels and cleaned everything/blew it off with an air hose and it started working again. I'd check with the manufacturers also!
Sep 25, 2012 | Panasonic NN-T694SF Microwave Oven
Whirlpool gold GH5184XPB-4 Last used to cook potatoes. sensing then cooked. Now runs but does not cook. Any ideas? Joe
There are three reasons for this, a bad magnetron "common problem" or a high voltage diode and capacitor can be a factor. If the magnetron is at fault it is cheaper to replace the microwave oven.
Mar 10, 2011 | Whirlpool Microwave Ovens
Error message
may be u dnt have any service
Dec 04, 2009 | Whirlpool GH6177XPS Microwave Oven
Whirlpool Gold Accuwave wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
May 19, 2009 | Whirlpool MH7140XF Microwave Oven
Microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Nov 26, 2008 | Whirlpool GH5184XPQ Microwave Oven
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
KENMORE ELITE MICROWAVE
F3H is a humidity sensor error.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If it still fails, you have a bad sensor.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 01, 2008 | Kenmore 62702 Microwave Oven
Whirlpool gold microwave over range model gh9184lq-2
Oct 25, 2008 | Microwave Ovens
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Feb 23, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
229 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
