Question about Philips HTS3544/37 Theater System
I have no sound :(
I usually watch my movies with the home theater system on aux 1, and its no longer producing sound, i've tried getting sound from using the radio and disc, but nothing is working. I've tried buying new cables thinking maybe it was that, but no, that wasn'.t it
    Brigadier General:
  • 8,546 Answers
If the (internal) radio doesn't produce sound it's not signal cables. What cables were you exchanging?
This sounds like a basic NO SOUND problem.
How does it fare when you run speaker setup?
How about the MUTE button?????
Posted on Jun 06, 2010
Philips home theater suddenly doesn't produce sounds
Sounds like the main amplifier section circuit inside the system is damaged. Contact any service technician, or the authorized service center for Philips.
Jul 13, 2015 | Philips Audio Players & Recorders
Cannot get sound. green cable is not connected. three cables connected together-- red and blue cables connected to aux in left and right. do not see where green cable should be connected. we just...
The actual color the head on a given cable is irrelevant as long as it connects an output to its compatible input.
Jacks on the electronics follow a common color code and are labeled for the color-blind.
Analog audio jacks are usually red (right) and white (left).
Composite video is usually yellow.
Red, green and blue are traditionally for Component Video. In other words, NOT SOUND.
A disconnected cable is usually a good reason for a signal to fail. But one should not guess where they go.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/JVC-TH-C50J-Home-Theater-Systems-manual/id/318ci575/t/2/
Get the basics set up first.
Mar 27, 2011 | JVC TH-C50 System
I have a RCA Home Theater System RT2380BK I have the speakers wired but i want to hook it up to my dish network when I'm watching movies.Can u help me?
The dish network reciever should have audio and video out on the back, If its a HD device it should also have COAX out (hd audio) get the cables for audio and feed the into a input on the back of your home theater system, there should be several inputs, usually labled like video 1 video 2, tape deck etc etc. the audio in are red and white or red and black usually, the coax connector is orange, and you only need one cable to hook that up. If you have HD audio on the dish network that will sound best in your home theatere system
Mar 10, 2011 | RCA RT2380 Home Theatre System System
I have an older Kenwood Home Theater system (approx. 2000-2001). I am tryuingto connect it to my new large screen TV (Samsung). Since the theater system does not have an HDMI connection port, how do I...
Use the red and white looking audio outs on your TV next to your yellow video out they are together (RED, WHITE, YELLOW). These are known as RCA jacks. Find a RCA wire and connect it to the AUX input of your receiver and the output of your TV. Turn your receiver to AUX mode and it should work.
Dec 02, 2010 | Kenwood Audio Players & Recorders
How do I hook up my samsung home theater system to my sansui tv to get surround sound when watching the tv
if your tv has audio out jacks connect them to the audio in jacks on your samsung system. it may say video 1,video 2,or aux in. use this step if you have a cable box as well.
Oct 21, 2009 | Samsung HT-TXQ120 Home Theater System...
No sound on tv
do you mean you wanted to get sound from the Home Theater System Speakers when watching TV programs?
If yes, you need audio cables (red & white or optical) and connect it from your TV's AUDIO OUT port to your HTS unit's AUDIO IN or AUX IN port. Then set your HTS's input to AUX.
Jul 01, 2009 | Samsung Audio Players & Recorders
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
I, have a LHT874 theater system no sound when watching tv
HI, check if you have to turn up the outputs on your tv or even switch them on,also make sure you are useing the audio outs and not an input then set your system to the same input the cables are pluged into and set sound to prologic 2.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | LG LHT854 Theater System
No sound thru surround sound system in TV Mode
You need to connect your TV to the AUX connection in the back of your HT system. Then set your HT system on AUX 1 and wait about 5 seconds for the TV sound to come through. If it does not work on AUX 1, you may have to try on AUX 2 or AUX 3 settings on your HT system. Make sure the A/V cable you use is good and in working order and is a good quality cable.
Hope that helps, Gary
Jan 30, 2009 | Samsung HTZ-510 Theater System
Wiring with a sattelite receiver and new Samsung TV
Nope RamaTheMan - you are incorrect! No way to get an actual surroundsound from your TV on this turd - this came straight from the Samsung FAQ -
"You cannot get surround sound from your television. On the other hand, if your television has audio output jacks you can connect your TV or Set Top Box to your Home Theater System and get stereo sound (that is, sound from the left and right speakers of your Home Theater System only).
To connect your TV or STB audio output jacks to your Home Theater System and get stereo sound, follow these steps:
  1. Turn off your TV and Home Theater System.
  2. Connect the Audio Out jacks on your TV to the External Audio Input jacks on the back of your Home Theater System. The External Audio Input connectors are typically labeled AUX IN. Note: There are usually two pairs of Audio Input jacks, AUX 1 and AUX 2. Each pair has a jack for the left audio input and the right audio input. Often, there are two Video AUX IN jacks as well. You can plug the audio cables into either audio AUX 1 or AUX 2. See the following diagram.
  1. Turn on your TV and Home Theater System.
  2. Press the Function Button on the front panel of your Home Theater System until the display on your Home Theater System shows AUX 1 or AUX 2.
For advanced installation, if you are using a High Def STB, you can connect an OPTICAL connection from the STB to the HTS. This is a specified cable that must be purchased separately.
In either instance, you must then set the HTS to its auxiliary input. (i.e AUX 1, AUX 2, DIGITAL IN) in order to get the sound from the HTS.
Note: If your television does not have Audio Out jacks, you may be able to get stereo sound by attaching the Audio Out jacks on your VCR to either the AUX 1 or AUX 2 audio inputs on your Home Theater System. If you attach your VCR to AUX 1 or AUX 2, you will have to tune your television to channel 3 or 4, and then tune to the station you want to watch on your VCR."
Dec 26, 2007 | Samsung HT-X50 System
Philips HTS3544/37 Theater System Logo
173 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
