Question about Danby DPAC6507 Portable Air Conditioner
I am getting an error code p1 and my air conditioner is not functioning model dpac6507
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
  • 3 Answers
SOURCE: i have an Everstar air conditioner model R51I9/BGCE. the air conditioner stopped and the LCD indicates "P1". please help. also the water indicator light is on, where is the water tank?
Usually means that you need to empty the water reservoir, or that the bucket is not seated properly.
Posted on May 23, 2009
  • 3 Answers
SOURCE: Have a ge model ASW12ALS1 Air conditioner with error code E1
I have a G.E. window air conditioner that kept giving me the E1 error code and would not allow the unit to turn on. After much frustration (and no results from following various tips on internet forums) I decided that I had nothing to lose by taking the thing apart. After all, it was way past the warranty period.
Make sure the unit is unplugged before doing any of the following.
When I took off the cover (not the front grill, but the metal cover over all the internal parts) I found a small black envelope stuck to the top of the styrofoam inside the unit. What an inconvenient place to find what the error codes mean! It obviously means they don't want the average customer to know any of this. "E1" means a short or open circuit, unit inoperable.
With that in mind I noticed that the black two conductor sensor wire was broken. This is the wire that leads from the sensor on the front fins to the control circuit board. After soldering it back together and wrapping it well with electrical tape the unit works perfectly.
If you don't wish to try soldering the wire, it can be unplugged from the circuit board. I would not be surprised if you can order a new sensor (with wire and plug attached) from a G.E. parts supplier.
By the way, this particular G.E. 6100 BTU air conditioner was manufactured by Samsung electronics.
Posted on Jul 03, 2009
  • 6 Answers
SOURCE: p1 error too often
I have this air conditioner. What I did was get a long plastic tube from home depot and connect it to the middle back drain. I then put the plastic tube outside my window, or if u have a drain somewhere put it in there or put the end into a big bucket. Let gravity do its job. I did not connect the tube to the internal bucket b/c I would have to empty it too often. The air conditioner is on top of a table so that water will flow down the tube and out the window.
Posted on Aug 19, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
P1 light stays on. I even unplugged the unit for a day and it still shows P1
Hi Marilyn,
I've just searched for "error code p1 perfect" and the second hit was on fixya in June 2012. Have a look and see what I mean. The easy way to find answers for every product question Just Ask
Jul 29, 2015 | PERFECT AIRE Dehumidifier PA65
P-1 code
Hello Friend, thank you for allowing me to assist you!
If you are getting an error code P1 on your Frigidaire air conditioner, normally it indicates that the bottom tray is full. Carefully remove your air conditioner to a drain location and remove the bottom drain plug and allow the water drain. Then restart your appliance and P1 symbol should disappear after you have let your appliance run. However, if the error code continues, at this point, I would recommend reaching out to a professional to proceed further. - Z
Jul 20, 2014 | Frigidaire FAP094P1Z Portable Air...
Code es error
Hi Kirby, thank you for allowing me to assist you!
Error code ES and P1 are commonly referred to a sensor failure. Because it is a smaller appliance, repairs are often more costly than the actual unit replacement. Is your appliance still in warranty? If so, you might want to reach out directly to the manufacturer to determine the coverage on your air conditioner and the procedures to any potential remedy in that regard.
Best of luck!
Sep 12, 2013 | Frigidaire FAP094P1Z Portable Air...
P1 code on Sylvania 12,000BTU portable AC unitl will not clear
The only thing I have been able to find as far as a P1 error code, is the water tray needs to be emptied. If thats emptied then it would be a issue with the float switch that senses the water.
Best I can find
Aug 21, 2013 | Sylvania Heating & Cooling
Bucket full light is on, I have drain tube out the window, air won't work. How to fix?
Hi Kathleen King - Typically when the error code P1 displays on panel it indicates that the unit has a sensor error. I would recommend contacting a professional to accurately diagnose and repair the unit.
Oct 02, 2012 | Frigidaire FAP094P1Z Portable Air...
I have a polar wind portable air conditioner/dehumidifier/fan with swing louvers model # MPN4-12CRN1-BH8 I cannot get the protection code P1 to go away do you have any suggestions? When I first plug it in...
Check the back of the manual that came with it. I find two things for a P1 Error.
Midea AC "R" Series Error Display = P1
Error Code Definition = Over voltage or too under voltage protection
On a portable unit
P1 or H8 - Water reservoir is full.
Oct 22, 2017 | Heating & Cooling
I am getting a code P1, what does it mean?
P1 Indicates that the water collection tank is full and needs to be drained. Turn the unit OFF & unplug it before attempting to drain it.
Hope this helped and thanks for choosing FixYa.
Sep 13, 2011 | Danby DPAC5070 Portable Air Conditioner
New air conditioner not working P1 error
Check float for drain pan is not taped up for shipping, and remove whatever is holding it up & let it drop down, into pan.
Jul 26, 2009 | Heating & Cooling
Need owners manual for Everstar Portable AC MPM1-10CR-BB6
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
Jun 25, 2009 | Danby DPAC8020 Air Conditioner
Danby DPAC6507 Portable Air Conditioner Logo
191 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
