Question about Maytag MSD2756GES Side by Side Refrigerator
My fridge is not defrosting. I pulled out the
My fridge is not defrosting. I pulled out the heating element and it appears to not have any resisitance across the contacts. If it is resistance heat, why is there on resistance. It is also curved down badly. I do not know for usre if the element is broken or if the controller/timer board is bad. It is a Maytag model MSD275GE.
  • Kerry Collins Jun 05, 2010
    Where is the defroster timer for my MSD2756GE side by side fridge/freezer?
    President:
  • 1,561 Answers
Most refrigerators and freezers are frost-free. In this type of unit, a heater is automatically turned on by a timer in order to melt the frost inside the unit. Frost is melted by the heater at several different spots in the unit, starting with the coldest and most frosted areas. When the frost is completely melted, the thermostat automatically switches to a cooling cycle in order to maintain the standard freezing temperature. Because this process is automatic, frost does not build up inside the box.
The unit's compressor system, which forces the coolant through the coil system, is driven by a capacitor-type motor. Other basic parts of the cooling/defrosting system include switches, thermostats, heaters, condensers, and fans. A do-it-yourselfer can test and replace many of these refrigerator components.
Servicing the Defrost Timer If the compressor doesn't run, it is likely that the defrost timer is malfunctioning. This part is located near the compressor. To test the defrost timer:
Step 1:
Unplug the refrigerator.
Step 2:
Disconnect the wires from the timer and timer motor. Remove the timer from its brackets by backing out two retaining screws.
Step 3:
Test the defrost timer with a VOM set to the RX1 scale. Clip one probe of the VOM to each defrost timer -- not motor -- wire, and turn the timer control screw shaft until it clicks. If the defrost timer is functioning, the meter will read zero. If the needle jumps, the defrost timer is faulty. Replace it with a new one of the same type.
Step 4:
Connect the new defrost timer the same way the old one was connected.
To check the defrost timer motor, clip one probe of the VOM to each motor wire, setting the scale to RX100. If the meter reads between about 500 and 3,000 ohms, the motor is functioning properly. If the meter reads higher than 3,000 ohms, the timer motor is faulty. Replace it with a new one of the same type. Connect the new motor the same way the old one was connected.
Servicing the Defrost Heater
This component is a heating element located on the evaporator coil. When the refrigerator or freezer switches to the defrost cycle, the defrost heater is turned on to melt the frost in the compartment. Failure of the defrost heater causes failure to defrost.
Test the element with a VOM set to the RX1 scale. To gain access to the heating element, remove the compartment's wall panels. Clip one probe of the VOM to each element terminal. The meter should read between 5 and 20 ohms. If it doesn't, the heating element is faulty and should be replaced. Replace the heater with a new one of the same type and electrical rating. Connect the new heater the same way the old one was connected.
Take care.
Posted on Jun 05, 2010
    I got 22.6 ohms across the heating element contacts. Is this exceptible?
Large Ice Build up on top inside back of fridge unit.
Could be the auto-defrost has stopped working. Most modern frost-free fridges have a heating element behind the liner where the cooling element is and the ice forms. Between the thermostat controlled periods of cooling the heating element should switch on for a short time to melt any ice that has formed and the resulting water forms into droplets that roll down the fridge liner until it is channelled into a drain leading to a tray mounted on the electric motor. The warmth from the motor evaporates the water and completes the maintenance-free frost-free system.
Possibilities are faulty wiring/connections, defrost timer, defrost element.
The defrost timer could be integral with the thermostat.
Some older fridges had a manual switch to start the defrost process.
Jun 30, 2016 | Refrigerators
Why is there water in the bottom of my fridge
Depending on your fridge and age there is a drain line inside or on the back of your unit. It could either be clogged or frozen. Again depending on your fridge you may be able to take the panel out in the back of your freezer and defrost the line. Basically your unit will go into a defrost cycle to melt any ice off your coils in your freezer to prevent any ice build up. It is controlled by a defrost timer and there is a heating element below the coils. It could be a freak thing or you may need to check the defrost timer or heating element. Also make sure you have a good seal on all door gaskets. Check that by putting a piece of paper in the door when it's closed it should have a little resistance when you pull it out.
Sep 02, 2014 | Whirlpool Refrigerators
Top half of both fridge and freezer appears to have stopped working.
Your defrost heater or defrost thermostat may be bad. Test defrost heating element for continuity. If heater is good, replace the defrost thermostat. In most cases, replacing both is advisable.
Dec 17, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
Where would i locate defrost timer on my ge bottom freezer refrigerator
Older fridges use a defrost timer to control when the fridge goes into defrost. Yours is a newer model and uses a control module which controls all of the fridge's functions including defrost timing. It does not have a defrost timer. It cost around $150. But I would check the defrost element first. A lot of problems with the defrost are usually a burnt out heating element. Use a meter and check that the element is not electrically open.
Dec 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Hello, I have a problem with an LG fridge GRS392GCA. temperature inside the machine raises after a few hours. I discovered that the coil was totally surrounded by frost. I heated the frost. the fridge...
usually it is not the heater but the controller for the defrost.
Which is a plastic package on the side if the coil, plugged into the roof.
Replace it, they are not expensive and testing one is.
Sep 12, 2009 | Refrigerators
Automatic defrost no longer works
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 19, 2009 | Refrigerators
GE Profile - fridge not cooling
Aug 17, 2009 | Refrigerators
Samsung fridge rs52530bwp the fridge side will not work
I have a similar situation before in your case if your heating element is working then you are lucky I had a samsung fridge and the defrost heating element was bad and i was forced to install a different one because i would have to change the hole evaporator in order to replace the heating element so what dit was to use a mechanical 10 hour defrost timer and install a generic heating element and a defrost thermostat on serial so it want work on less the evaporator has froze over i drill a hole to the back of the fridge and i wren the cables to the back of the fridge cover then whit foil tape an take power directly from the power cord i install the timer next to the control board so every 10 hours will give power to the heating element but will not come on unless the evaporator has froze up. on my case i had to do it like that because the heating element i use was to strong for the control board and would just burn it up. but will work even better using the original heating element. NOTE: find the diagram of a old fridge that will help you to figure out how to install the timer and the defrost thermostat no need for the timer to cut off the compressor keep in mind than the defrost thermostat only close the circuit when is chill below freezing so i recommend to use a new one I hope this help you
Jun 10, 2009 | Samsung RS2630SH Side by Side Refrigerator
Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
Oct 09, 2007 | Zanussi ZX99 / 5 Bottom Freezer...
Maytag MSD2756GES Side by Side Refrigerator Logo
231 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
