Question about Refrigerators
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
    Scholar:
  • 44 Answers
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Posted on Jun 06, 2010
Error code er 1f
Check all wiring behind fascia and freezer door hinge
Apr 13, 2014 | Kenmore 73502 / 73504 / 73509 Bottom...
Error code 1F
That would be you need to replace the icemaker fan motor.
Nov 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore Elite Refrigerator, Model No. 795.77573600. The ice and water dispenser give the error message Er 1F. In searching online it appears that this problem is related to the ice compartment...
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 25, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Not making ice error code 1f
Pull the line off at the icemaker and check for a filter at the inlet...often **** builds up there and stops off the water...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 12, 2010 | LG LFX23961SW Bottom Freezer French Door...
Getting er 1f on refrigerator door. unplugged and replugged - fixed it be when door was opened it happened again
1F means you have an issue with your fan motor cooling your icemaker--- usually this means you need to replace the fan motor. Until you can replace your fan motor turn off the switch for the icemaker, then flip the circuit breaker to off for a few seconds and turn it back on. The display should remain lit and operable, but you won't have an icemaker
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 07, 2009 | Refrigerators
KENMORE 79577579600 REF. with an error code er-1f the manual said " poor bldc connection, drive IC , and TR. checked the connection and its fine but WHAT IS THE DRIVE IC AND TR? if I unplug the fridge and...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^$#%
Jun 13, 2009 | LG LRFD25850 French Door Refrigerator
LG Model LFX25960 has error code ER 1F
Turn off the switch for the icemaker, then flip the circuit breaker to off for a few seconds and turn it back on. The display should remain lit and operable, but you won't have an icemaker. See service manual pg. 32: http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
LG=JUNK!
Jun 14, 2008 | LG LRFC25750 Refrigerator French Door
Error code 1F
ER IF means the icemaker fan is malfunctioning. Common cause is ice buildup in the fan shroud. LG has recently upgraded that shroud to drain off moisture that collects in there. The icemaker fan, when looking in the freezer, is the one on the left.
Very common for the icemaker itself to fail during the first year, have replaced many. They have since changed the design of it and it seems to have solved the problem.
May 16, 2008 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
268 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
