Question about Disney Mix Max Digital Media Player
How to replace battery in mix max I guess I'm asking how to access the battery for replacement and it is easily bought somewhere?
I have just bought replacement battery for my samsung c3050 which is not keeping its charge very long. The battery supplier advises to put phone in standby mode. What is this please?
the 3050 dosn't have a standby mode only an idle witch is the mode when you turn it on but dont access any af the features or web/calls you will probably find if you completly charge and discharge the phone a few times the battery will hold a better charge if not i'd send it back and ask for a refund as the battery is likely faulty
Sep 14, 2014 | Samsung C3050 Cell Phone
Bad diodes: Replace them or the alternator
told, and what tests did they do , in order to say, those magic words.
(max amps tests under max load (tools) or a scope test.
if they didnt do those to tests, they are just Guessing.
if you want to guess. why not do that yourself, after all its your wasted cash , not his... see?
IMO, youll never ever get the diodes out and back in , and not mess it all up. (some are easy , most are hard.)
if on the other and all all this post really is , is the failure to state
the symptoms, and then asking how to do the tests. then we can do that.
let me guess, (i roll the dice) and land on.
Battery will not charge, driving, and voltage is not 13.3v to 15v driving.
so the battery discharges, and the soon the engine stalls.
did i guess right?
Nov 19, 2013 | Suzuki Cars & Trucks
I'm trying to enter set up. It is asking for password. I don't have one have do I get in?
You will need to clear the cmos memory. Unplug the laptop from the mains power supply. Remove the laptop battery. Press and hold the ON button for a minute or two to try to discharge any stray capacitance. Now comes the hard part. Locate the CMOS backup battery. This might be easily accessed from underneath, or under the keyboard. If you are unlucky then it will be hidden somewhere not easily accessible. If you provide the actual model number I might be able to find out where the battery is. If you manage to find the CMOS battery, you need to disconect it from the motherboard (or remove it if it is in a socket). Leave the battery disconnected for a few minutes. Replace the cmos battery and put the laptop back together. with any luck the cmos will be reset to default and you will be able to get into the bios.
Feb 20, 2011 | HP Computers & Internet
Have a 93 MightyMax hit hard in front, considering replacing body
call your auto parts store and ask what yeasr have interchangable parts they have all the parts listed on computer and they can tell you what you can mix and match
Apr 15, 2010 | 1993 Mitsubishi Mighty Max
How do u delete songs off the mix max
WELL are you going to tell me or do i guess???????
how do u fricken delete old stuff>??????
Jan 26, 2010 | Disney Mix Max Plus DS19025 Digital Media...
Mix max won't play music, turnoff or charge
If it is not recognizing by the computer, not turning off, or recharging, then you have a problem with the battery in itself (or battery related components).
You probably won't be able to get a battery replacement for that unit.
With anything, when a computer system, router, MP3 player, IPOD, etc. has problems functioning correctly, there is more than likely a power issue with the unit.
Aug 06, 2009 | Disney Mix Max Digital Media Player
Just bought 2008 model 650 can-am max xt dealerhad 41 miles on it,they changed oil before i took it home ,it set in my garage for two days , when i went to ride it i checked the oil an it was over full...
If the oil is milky it has a bad and leaking seal somewhere that the gas is gitting in, or it has water in it. Water does not mix well with oil as you may know so I'd guess its gas is getting in. If it does run, change the oil right away then see if the oil develops the milky look again. Probably a seal would be my guess. Good luck.
Apr 21, 2009 | RTO 125cc ATV Quads Full Size Adult four...
White blotch on Mix Max
No contact disney they will replace it free of charge it you have your recipt
Dec 27, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
128 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
