Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Bosch SX 250 Lp. I get EA code and will not start. Was very windy last night. Does anyone know how to correct this issue?
EA & EC are telling you that the flame is not covering the flame sensor rod.
Take the front cover off by unscrewing the 2 phillips head screws about 1/2 way down the cover and may be covered by a plastic plate that unsnaps.
Locate the flame inspection glass window near the right side above the control panel. Prepare to observe the flame from start, until the error appears. Visually locate the flame sensor rod: there are 3 rods that pass through the plate below the burner - it is the right most of the 3, angle your head so you can focus on this single rod. Begin water flow by opening a valve or the pressure relief valve that should be outside the cabinet, at the bottom.
Did the flame ignite? it should make several tries before an error.
if it ignited, did the flame cover the flame rod, or did it jump up over it leaving the rod in clear gas below the flames?
In the LCD display, upper right corner, is an indicator in the shape of a flame. It is visably displayed when the flame is covering the flame rod, indicating that the flame is being detected by the electronics. If the flame covered the rod but the indicate is not on, the rod itself may be dirty. Remove it with the other 2 ignitor rods and careful clean the sensor rod with something like steel wool to remove the corrosion. Re-install and test again. If that didn't fix this condition, your control circuit is faulty.
If you find that the flame jumps over the rod and doesn't emerce the rod, check the draft vent pipe for any obstructions, water, bird nest, etc, and any obstruction of the combustion air supply. Check the the gas blower starts up, check for water or white dust in the clear tubing that attaches to the black blower intake from the gas meter.
Otherwise, you will need to follow the procedures to adjust the CO2 and this WILL require a combustion gas analyzer! If you are at an elevation above 2,000 feet, expect to make this adjustment.
Posted on May 08, 2012
EA means your gas flow is not at the right pressure for the heater to work, you need to make sure that you are suppling the right amount of gas to your heater to start.
Bill
Posted on Dec 15, 2010
My bosch tankless water heater is flashing ae
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch & Tankless LP Hot Water Heater
I have had Bosch 250 sx ng heater for the last three years with continuing problems maintaining consistent hot water. Either the unit will not heat up or during a shower when you add cold water to cool the...
Here's Bosch's A2 error code pdf:
http://waterheatertimer.org/pdf/Bosch_A2_error_code_troubleshooting.pdf
Want the truth?
I answer Bosch, and other brand water heater questions at fixya.
Never, ever install a tankless water heater unless your wallet is 2" thick and you enjoy nuisance problems that you can occasionally fix yourself plus doing recommended continual maintenance.
Tankless with never pay back, otherwise the news would be filled with stories of people saving money. The only reports of savings comes from sellers of the product. Averages savings on gas bill is $1-8 per month, but all costs are energy.
I cannot recommend a solution to fix the Bosch problem if trained service reps cannot solve problem.
If other product-owners report same problem with that model, then problem is likely related to software and/or PB-board problems, which is same as saying your computer motherboard is no good. And most people know that when a computer motherboard has failures, then the computer is unreliable and should be replaced.
Always research a product before buying.
You can solve most tankless problem yourself, same day, no waiting for parts, Sept 2011, for about $350.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Sell the defect tankless for parts, or get up to $12 per 100 pounds for scrap metal at the recycler.
Other resources that you can read:
Sep 21, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
Installed this unit last Sept. I have started getting A# error codes. This has something to do with a jumper. I'm not sure how to correct this issue.
Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, water heater forum, fixya links, disclaimers, and links for finding service technician.
Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 31, 2011 | Bosch AquaStar 2400ES-LP
I have a bosch aqvastar 250 sx ng error code EC keeps appearing
Q. EC - Ionization failure during operation
A.
  1. Verify gas type (See Fig. 2 in installation manual) corresponds with the type of gas supplied to the heater.
  2. Verify the three yellow wire connections to the set of electrodes (underside of the burner assembly) are secure.
  3. Verify that venting meets specifications per chapter 3.6 of the installation manual. Improper venting may cause premature failure of the flame sensor rod.
  4. Check gas pressure. See Bulletin TWH-G2-03.
  5. Check and adjust CO2 readings. See Bulletin TWH-G2-12.
  6. Gas valve or flame sensor may be damaged. Call Bosch Water Heating with observations and results of previous steps.
Mar 06, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch 250 sx ng tankless water heater showing error code. checked fuses and they are fine. tried resetting many times still not working
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Best place to start is troubleshoot section in manual. Page 24
http://www.boschhotwater.com/Portals/7/TechManuals/250SX_English.pdf
Problems range from air supply, gas supply, venting, part failure or combination of listed things.
Don't forget, tankless require yearly maintenance, outlined in manual, and cannot be exposed to more than 11 grains hardness in water, and should be de-limed each year.
All costs are energy.
I suggest reading entire manual several times, so you are pro about your tankless water heater.
Even with this knowledge, trained service technician will have to be consulted
some day, and tankless should never be installed if factory trained technician not available in area.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
Install tank type water heater that can be put online when Bosch is not working
Add a comment for more free help.
Mar 04, 2011 | Bosch & Tankless LP Hot Water Heater
Tested my bosch 250 sx with no gas hookup a2 error showed up.I s this possible wit no gas hookup yet?
1) Error code A2 shows on following link:
2) Open following link for Bosch tankless troubleshooting resources, including Bosch contact information, typical manuals, error codes, tech support, parts, fuel-saver calculator, service bulletins, water heater forum, fixya links, disclaimers, and links for finding service technician.
3) As a general rule, tankless are best when installed by experienced, trained technician.
4) This is partly because Tankless manufactures refer you back to installer when there is a problem, and party because so many factors affect tankless operation.
5) Tankless require perfect alignment of factors to work properly, including vent, air supply, gas supply, combustion maintenance, water flow, water pressure, water quality, overall maintenance, plus internal parts working in harmony.
6) Read manual cover to cover, make sure tankless receives yearly maintenance as outline in manual.
Feb 09, 2011 | Bosch AquaStar 250SXO-LP-RE...
Bosch on demand tankless water heater gwh 2400 E LP error code "
BOSH AQ 250 On demand propane water heater ran out of propane, got gas now, but get EC flashing on the display and the unit won't fire? Lost manual, any suggestions. Thanks, Jim
Jan 06, 2010 | Bosch AquaStar 2400ES-NG
Bosch 1600H-LP Overheating Problem
did you check to see if your temp regulater is working properly? also you have a thermocoupler that senses the heat of the water and works in conjunction with the regulator. have either one or both replaced and the problem will be solved. please rate this thanks
Aug 27, 2008 | Bosch 1600H-LP Liquid Propane AquaStar...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
617 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
