Hi There,
My Samsung L100 camera has full battery power but when i turn it on it beeps and turns off within 3 seconds, Sometimes it will display the last photo image taken, other times nothing will show on the screen at all, last night it displayed the last image with 'Standby' at the bottom. I have tried changing the mode using the dial at the top of the camera, but this doesnt seem to change a thing!
Your advise or some tips to adjust this problem would be greatly appriciated.
Have a good day,
Krista
Are you absolutely sure the battery is good? Do you have a battery eliminator that you can plug into camera to double check? Do you have another battery you can throw in there ? Is the memory chip ok? A corrupted chip can sometimes shut down a camera.
If unit still does this with a known, confirmed, good power supply, then the electronics are at issue and given the high cost of proprietary parts and labor, a repair might not be cost effective.
SOURCE: Samsung camera power-on problem and beeping
same problem! camera HAD been dropped....carefully pull up with a gentle twist on the 'tilted ' side.
thanks for the tip! camera works fine!!
SOURCE: My i85 camera's lcd no longer displays what you are looking at
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. [email protected] Mr.Tracy Johnson
SOURCE: Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
SOURCE: Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
