Question about Fisher and Paykel GWL11 Top Load Washer
GWL15, no display lights or power
GWL15, lost display lights and power.
I verified power at receptacle.
Motor will spin by hand, not locked up.
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting. Now there are 2 reasons why your machine will not power up.They are 1--your motor controller is faulty. 2--Your drain pump is faulty.If you have or can borrow an electrical test meter I can guide you throe finding the faulty part and then repairing it.Sorry to ask you this but are you 100% sure you have power at the power point? Hope this helps and if you need further help please reply
Posted on Jun 05, 2010
How do I reset my Fisher Washing machine size?
To set the size switch, turn the power on at the power point and off at the console. Press and hold
WASH TEMPERATURE UP then press POWER. EcoSmart will give 4 short beeps
and the pattern of LEDs will change.
To lock the size into memory.
 Press SPIN SPEED UP, the SPIN HOLD LED is on for 7.5 / 8.0kg (650mm wide).
 Press POWER to confirm the setting and also exit this mode.
Apr 15, 2015 | Fisher Paykel EcoSmart GWL15
GWL15 fisher and paykel stops mid spin
If the only light on was the spin when it was beeping,
That is fault code 1
1. (00000001) Motor Control Module Fault
The Motor Control Module has encountered an error when writing to an EEPROM address.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 18, 2013 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel Ecosmart when it gets to Rinse and spin, it stops and just beeps.
Many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter- so many 'faults' are caused by blocked filters.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 31, 2011 | Fisher Paykel EcoSmart GWL15
I have a fisher and paykel washer model gwl11.. it does not go into the rinse cycle. just maes noises and thats it
John C
Oct 02, 2011 | Fisher Paykel EcoSmart GWL15
I have the GWL15 Washing Machine. It stopped working when it got to the spin cycle. Now the following lights went on: The 3rd one over is Green The 6th light over is Orange (Rinse) and the last light...
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
John C
Jun 22, 2011 | Fisher and Paykel Washing Machines
THe water will not drain out of washer, beeps.
John C
Jun 06, 2011 | Fisher Paykel EcoSmart GWL15
I had a problem with my ecosmart wash machine and had a service tech come out. The machine would not spin thus water would not exit. I wasn't there when he fixed it but was told there is a filter in...
The spinning action does not drain the water, the drain motor does- when and if it can!
Many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
Proviso
John C
May 10, 2011 | Fisher Paykel EcoSmart GWL15
Model ZWF16581W front load washing machine - displaying 0.00 and beeping as if \r\ncycle ended won't let me start a new cycle. Lock light off door closed but padlock displayed on the digital display....
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 24, 2011 | Zanussi Washing Machines
My GWL15 washer will not drain when wash cycle is finished, so will not rinse and proceed. Had a penny in drain hose also- still not working. Motor seems warm but cannot tell if it is coming on when goes...
(Try these guidance notes)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
John C
Mar 18, 2011 | Fisher and Paykel GWL11 Top Load Washer
Vacuum will not come on even though power switch is on.
Rainbows draw a lot of power. It may have tripped the circuit breaker for the receptacle you have it plugged into. first make sure the receptacle is ok, especially if it is plugged into a ground fault receptacle. . Next, unplug the vacuum, take off the tank and see if you can spin the impeller by hand. If you can spin it, the motor is free. If plugged into a good receptacle and the power cord is not cut or broken and still does not run then the motor is bad. it could be the brushes in the motor(which can be replaced), or the armature is shorted out, meaning you need to replace the motor.
Jan 17, 2011 | Rainbow E series Canister Wet/Dry Vacuum
Fisher and Paykel GWL11 Top Load Washer Logo
230 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
