Question about Whirlpool Dishwashers
The plates fall over in the dishwasher (Whirlpool).
The ''tines'' that hold the plates are too short for my new dinner plates. They fall over and onto each other.
  • 457 Answers
SOURCE: Normal dinner plates hit the top washer arm in Bosch dishwasher
TRY TO ADJUST THE FINS IN THE BASKET TO SIZE PLATES . THE MANUALLY RECOMMENDS HOE TOLOAD DISHES.
Posted on Feb 28, 2010
  • 901 Answers
SOURCE: water spinner hits dinner plates and cannot turn.
Check the side left & right side. There should be an adjustment. Pull the rack and observe. you might have to select the lower rails.
Refer your user manual.
Posted on May 24, 2010
  • 901 Answers
SOURCE: Hi, I have a Westinghouse ADP6000WH dishwasher and...
You have to check the slider rails. If you watch the there be a different slot. You can remove and place it in that area.
Otherwise remove the top rack and run as special cycle for this dishes alone!!!
  • 7 Answers
SOURCE: dinner plate stops arm rotating,
on the topshelf of the dishwasher there are 2 lots of slide wheels . these are to set the shelf at different heights they should be on the lowest wheels to give you the maximum distance between the bottom tray and the spinning arm
Posted on Jul 30, 2011
caroldon
  • 17130 Answers
SOURCE: whirlpool ADP8540 IX dishwasher -
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor. The water pressure must be good and the spraying must be seen to be good. If there is low pumping or pressure then the spray arms will not turn around to inject with pressure. If so the pump must be checked for clogging.
Need to check the inlet valve, the pressure pump as it seems to trip the controller unit.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the drain valve/pump activated so as to drain off all the water.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Posted on Aug 18, 2011
Tings not holding dinner plates
please replace the parts go www.repairclinic.comGod bless you
Apr 05, 2013 | Dishwashers
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Dinner plate stops arm rotating, plates must be able to go in. why is the arm hitting the dinner plate.surely you must be able to wash your dinner plates in there, from tray to arm is 250cm.
Jul 30, 2011 | Dishwashers
My standard size dinner plates are too tall, the rotating part is catching the plates
Some machines have height adjustable top shelf.
Should be couple of clips on side of rack to raise / lower.
Other than that you will have to get smaller dinner plates.
Please dont forget to vote this answer was helpful
Many thanks
Feb 16, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Water spinner hits dinner plates and cannot turn. i can see no way to adjust the height...my dinner plates are average size i didnt have a problem with my other dishwasher.
May 24, 2010 | Dishwashers
May 21, 2010 | Dishwashers
Control Panel Problem on a Maytag DW MDBTT79AWW
I had this same problem, ordered the replacement control panel from whirlpool. The new panel worked for two weeks, then stopped working again. OUCH!
The replacement part costs $264.34 and has no warranty if you do it yourself.
I think I am now going shopping for something other than a Whirlpool or Maytag machine. They have terrible customer service.
Feb 12, 2010 | Maytag Dishwashers
Feb 11, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Our dinner plates hit the rotating arms of the jets. We have checked the manual and we are loading correctly. Just doesn't make sense.
Solution - there are 2 sets of rollers about 2 inches apart. You just click off the stoppers at the end of the sliding arms on the top shelf, take out the rack and put it back onto the higher set of rollers!!!
Jun 30, 2008 | Hoover Dishwashers
Dishwashers Logo
107 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
