Question about Microtek 710S 17" Flat Panel LCD Monitor
I have a Microtek 17 in monitor and recently it has started to flicker badly when switch on after a couple of minutes it settles down to normal. Can you offer any comments re fixing this problem? Many thanks Lindsay
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 06, 2010
Monitor Flicker for awhile and then settles down
The problem is in the power supply/inverter board, this is usually caused by bad capacitors that in most cases have slight bulge at the top causing it to flicker and eventually shutdown. The only option is have them replaced.
Mar 31, 2011 | Samsung 226BW Monitor
Flickering
hmmmmm ok kindaa easy kinda hard first what are you running because all you need to do is go to stat control panel displays then click advance or what ever to change the hert try change until flickering stop ok hope that helped
Jan 12, 2011 | Microtek C783GM 17" Flat Panel LCD Monitor
Had my monitor for four years, great performance
jlallen54, When lcd panel goes to a dark condition please shine a bright flashlight 1 inch from screen an tell me if screen data is still displayed during this "blackout" condition. It might be just a single (1) poor and now thermally intermittant solder connection on the printed circuit board inside the monitor. Do some reading first and then you will understand the problem that your monitor has. 12fixlouie
Jan 17, 2010 | Sony SDM-HS73P 17" LCD Monitor
Monitor flickering
Monitor flickering can be one or several problems.
Depending upon the age of the unit and value, you should decide weather to repair it or replace it.!
More than likely, it is a problem in your power supply.
The capacitors in the supply will leak and most often crown.
If when you start unit after sitting for a while, it shows good and then after a few minutes it starts flickering, you can bet it is one or several capacitors in the supply.
This monitor is a 17 inch and not really worth the time and investment to repair, unless you have the technical skills to remove and replace electronic components.
Nov 05, 2009 | AOC 177Sa 17" LCD Monitor
It recently started flickering when I turn it on. It did this for several minutes before displaying normally. Then it wouldn't display anything at all until I turned it on and off several times. Then it...
duffy325, Don't mess with it!!! Get SAMSUNG to give you a new or REFURBISHED unit t0 replace your BAD unit. Your unit is behaving like I would expect a 3-5 year old unit. It's got a power supply problem, not a front panel switch gone bad problem. FYI also visit YOUTUBE for the longer video clips of "LCD monitor disassembly" and "LCD monitor repair" to find out some common KNOWN failure mechanisims why they fail!! You will be amazed! With your unit's behavior I suspect a "flakly backlight or SMPS/INVERTER" problem. bye for now. If this was of some help, do rate this response on fixya. 12fixlouie
Nov 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Green light flickering & Sunset red screen display.
You've got components that have gone bad, probably from age and the normal heat inside a CRT monitor case.
I hate to say it, but it's really not worth fixing. You can usually find a used but working 17" monitor for under 20 bucks.
Sep 27, 2009 | LG Studioworks 700S 17" CRT Monitor
Flicker monitor
It is likely only "mode switching" unfortunately there is not much that you can do about this.....sorry I couldnt be more helpfull.
May 24, 2009 | CTX S762G (Silver) 17" LCD Monitor
815c microtek
At reboot the screen would flash on and off, finally settling on.Good resolution...normal,
This worsened and finally a black screen.
I measured the ps output, unloaded, and it measures 19 volts...with a little pulsation.Is there a repair manual available on site?
Feb 17, 2008 | Gateway FPD2275W LCD Monitor
Microtek 710S 17" Flat Panel LCD Monitor Logo
99 people viewed this question
Top Microtek Computers & Internet Experts
William Miller
William Miller
Michael Deni
Level 1 Expert
ray gallant
Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
