Good evening, I am confident that I have a bra wire stuck behind the drum in my Whirlpool Duet Front Load Washer. I have a handy hubby - what can we do?
    Sergeant:
  • 351 Answers
Try removing the element from the drum and use a torch to locate the wire,sometimes you can see it sticking through the holes in the drum,so you will be able to pullm it back
Posted on Jun 16, 2010
Drum on duet washer is not finishing load, getting stuck, wont turn
Hello
you need to clean the filer on the front of the machine , or check the pump for a faulty impeller , a good. Clean of all the draining system would be a great start,
Oct 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Hi How do i get a bra-wire from inside the drum. Nothing is protruding into the drum but I an hear it clicking. Elilse
There is virtually nothing that can be done to remove this without taking the entire machine apart. You can try one thing tho, try removing the bottom front panel to access the drain hose. Remove it from the tub and see if you can spin the drum to get it to fall out the bottom:)
Dec 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loading washer makes roaring sound during spin cycles what is the fix?
It has an electric pump that can make a noise by a bra wire or some of that nature resting on top of the impeller.
Nov 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer, inner stainless drum rubs
This sounds like a worn bearing housing or the bearing itself has packed up,either way you would have to strip and check these and replace what is broken
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our washer is making a grinding noise when the washer drains and when the tub spins any ideas what it might be. Washer seems to work fine just making that noise during a drain and spin cycle.
This sounds like you may have something caught in the drain pump. One of the most common items to get stuck in there is a woman's bra wire. Check it out.
Dec 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
BRA WIRE STUCK BETWEEN DRUM AND HOUSING
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Neff V4380X0 Front Load Washer / Dryer
Nail in washer
Hi I had the same problem, but not a nail a bra under wire, they have a wire that is sown in under the cup these often work loose and slip through the holes in the drum,in my case it was catching on the heating element if not removed it would catch the element and even damage it or at best my a bad noise. To get at it i just undid the heater element pulled it out from the drum and this then gave me good access to the drum housing so i was able to get at the wire. You must make sure you unplug the washer from the electrics DO NOT work on any appliance when it is connected to the mains. All washers have an heater at the bottom of the drum.If you are handy it will not take you more than an hour to do this job.Good luck.
Nov 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
How to remove Bra wire trapped between drums.
Try to see if there is a large rubber sleeve underneath that you can remove. It will probably be fastened with a clamp. Make very sure that you get it tightened afterwards, or it may leak.
Dec 05, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
