Question about Hitachi NR83A2S Framing Nailer, Full Head, Plastic Strip Collation
Air leak my hitachi nr83a blows air thru the trigger area, otherwise it works fine, how do i stop the leak ?
  • 59 Answers
My Guess is that it needs a new "O " ring or some other form of seal some where round the trigger actuating spindle. Should be quite easy to fit if you can get one the right size
Posted on Jun 06, 2010
Hitachi 45ab blowing air out of trigger
If air leaks thru trigger as soon as you connect airline, replace the vinyl ball under the trigger stem. If air leaks when you depress the trigger, replace the small oring on the trigger stem. If air leaks slightly from plunger in front of the trigger valve, problem is inside of the gun. Remove the head and pull the large circular plate. Replace the large outer oring. Good luck
Feb 10, 2014 | Hitachi NV45AB2 Roofing Coil Nailer
Air is pouring out of the head of my NR83a Hitachi nailgun
It appears that there is a small o ring that has missed you attention in reassembly and has fallen out of the groove. re do the job paying to gaskets and o rings.
Mar 10, 2013 | Hitachi Nr83a- Strip Nailer-driver Blade...
My hitach nr83a just blows air out the exhaust when pluged in and wont shoot. is this a trigger or exhaust problem ???
Your problem is most likely where the cylinder / head come together. In the Hitachi framers, the cylinder is designed to move up and down (unlike Bostitch where the head valve moves) so if the O-rings are dirty or broken, or the spring under the cylinder is broken - the cylinder won't make a good seal to the head valve.
You can try plugging the tool in and giving a couple of firm taps straight down on the head with a rubber mallet - if the leak stops or slows you'll know the problem is with the cylinder movement.
Check the head valve seal - often they get sand / debris embedded in them which prevents the cylinder from making a good seal.
It is rare for a Hitachi trigger to be a problem.
Nov 24, 2011 | Hitachi Nr83a- Strip Nailer-driver Blade...
My hitachi nr 83a leaks air at the trigger
Often a trigger leak in the NR83A is caused by a bad gasket in the head #877-327. If this is improperly installed, cracked, or overcompressed it will cause the trigger to leak.
It is uncommon for the trigger itself to be the problem.
Sep 24, 2010 | Hitachi Nr83a- Strip Nailer-driver Blade...
Air leaking aroung the trigger assembly from my Hitachi NR83A
if you took the trigger apart the part that you unscrew has a nylon ball and a black rubber ring you should check them and make sure that you didn't loose them when you took it apart,if they are there, then you need to service the gun, and after you clean all the moving part and you put it back together, it may still leak from the top,Take a rubber hammer and give it a good hit,now not to hard, and it should seal
Apr 27, 2010 | Hitachi NV45AB2S Coil Roofing Nailer
Hitachi NR83A air leak
Most all Hitachi nailers that use the plunger style of firing/safety mech will leak air past plunger (part #877-339) when firing, however should not leak when connected to air or resting. If air is leaking past plunger when connnected to air check following:
Remove head to reveal cylinder plate (part#877-318). Remove plate and check outer oring for nicks or broken. If nicked or broken, replace and problem solved. If in good condition, remove cylinder guide (part #877-310) and check two outer orings for nick /cut. Use caution when removing/installing cylinder guide. It is easy to pinch orings when installing causing air leak at plunger. If orings are in good shape then problem is warped body of gun not allowing outer orings to seal. To check for warped body, use the cylinder plate as a guage by lowering it into the area where the cylinder guide rests. Good Luck with your repair.
Mar 12, 2009 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Hitachi NR83A2S Framing Nailer, Full Head, Plastic Strip Collation  Logo
410 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
