Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
My father's Briggs and Straton 12.5 hp
The engine runs good but upon turning off, all gasoline leaks out.
    Problem Solver:
  • 4 Answers
Check the float in the carb. It may be stuck in the up position due to debris
Posted on Jul 29, 2010
Need a replacement on-off switch for a DeVilbiss GB5000-2 generator
My switch broke as well. Instead of trying to find one, I removed it, and mounted a heavy duty toggle switch on the front of the shroud, just below the original location. Connect the original wire to one side of the switch, and a wire connected to a good ground to the other side. Btw, the off position on the toggle switch is run, and the on is now off. This repair has served me for years.
Jul 20, 2012 | Briggs & Stratton Briggs and Stratton...
I have a B/S 22 HP engine and when I try and start it I hear the selonoid pulling in but the engine will not turn. I can do this several time and finally it will start and runs very well. It took the
Is the noise you hear actually the solenoid popping or the starter gear jumping into the flywheel?? You say it finally starts so I am guessing the starter is engaging and actually bumping the flywheel a little. If that is the case it is probably a dragging starter or weak battery. First thing is to be sure the battery is fully charged then see if it will turn over easily. If not you may have a started problem.
Mar 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Backfiring thru carburator briggs and straton
manual said use champion qc12yc spark plugs gap 40 hard to found i use b&s plugs fail out. do i need to use qc12yc plugs
Aug 14, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Will a 3.5 HP vertical shaft Brigs&Straton engine
Hi, yes it will run without a blade. But it will need a flywheel on the shaft to run better. Depends what you want to do with it. Good luck
Jul 28, 2011 | Briggs & Stratton Garden
Oil leaking out exhaust
when the piston rings get worn, the oil seeps past them, and into the exhaust manifold through the exhaust pipe. you need to change the piston rings.
Jun 21, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Gas in oil 12.5 hp briggs and straton will not start
the float in the carb is stuck open, its flooding with gas. the gasoline is going past the rings and/or valves into the crankcase. you need to remove the float bowl and unstick and reset the float to specs, maybe a new seat and needle and change the oil before restarting.
Jul 26, 2009 | Briggs & Stratton Garden
MTD lawn tractor. 16 hp twin briggs straton
THIS SOUNDS LIKE A THROTTLE CABLE LINKAGE PROBLEM.WITH THE HOOD OPEN AND MOTOR RUNNING RUN YOUR THOTTLE UP AND DOWN WHILE LOOKING @ THE LEFT SIDE OF THE MOTOR TO SEE IF THE CABLE IS FROZEN IN PLACE OR BROKE OR DISCONNECTED .HOPE THIS HELPS
Jul 15, 2009 | Mtd Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
66 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
