Question about Ovens
F6 is coming up on my turbo chef, it is over heating
  • gibbspj520 Jun 05, 2010
    f6 coming up on my turbo chef, it is over heating
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F6 error means that the electronic thermocouple compartment connected to the control board has detected a temperature above 140 degree F (60 degree C). The unit will require cleaning, there is a fan located on the right top back of the unit whose intake might be blocked and/or the fan itself might be bad, you’ll need to clean that and see if that resolves the issue if not then the fan should be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 05, 2010
  • 1,284 Answers
Hi, there is a temperature sensor built into the control board and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps
Take care
  • Shehu Pro
    Shehu Pro Jun 05, 2010
    You need to replace the fan to stop the over heating.....
3 Suggested Answers
  • 125 Answers
SOURCE: turbo chef oven F6 ec code
Hello. There is a temperature sensor built into the control board, and the temp in that area, is getting too hot. On the back of the unit, right top, there is a cooling fan that comes on at a certain temperature, if the intake is clogged, you will get this error, clean the intake. Inside the unit may be so dirty, it may require cleaning as well. The fan itself could be bad, and does not run, then it will need replacement.
Hope that helps, and thank you.
Posted on Feb 22, 2009
  • 14 Answers
SOURCE: turbo chef is not heating up, coming up on it
the problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Posted on Jul 30, 2010
I have F1 - blower error. Also, it give cooling down error. It works at 208 but not at 240. And i am not able to change it to 208 all time. Any solution please.
Ur using Turbo chef or merry Chef oven? Ur error was cause by fan blower for ur heater to circulate hot air inside the cavity for toasting.. Maybe it's now turning or stuck up. What's the. Model?
Jun 09, 2016 | Ovens
My Subway Turbo Chef is saying wr fail. I self tested and it came up okay, can't find this error message in manual
I have had an F8 error in the past. The wire connecting the top element had broken off. The reason why temperature is not getting up is becaise the top element is not working.
Apr 22, 2012 | TurboChef Ovens
Turbo chef oven heats up too high and not ready
Bad SSR relay. Thermostat is for safety so it tripped first time, however since it's mechanical thermostat( not so accurate ) it didn't tripped on time for next time when it overheat
Jan 31, 2012 | TurboChef TORNADO Electric Oven
Turbo chef is not heating up, coming up on it reads, f8 low heat
Jul 03, 2010 | TurboChef C3 Single Oven
My turbo chef owen sense somtime 208vac and some time 240vac
Hello. If you take the right side panel off, unplug first please. at the back is a blower motor, two screws on the back vertical rail, and one at the front edge of where it is connected to blow, probably under the foil tape, this will remove the blower. On the back wall toward the bottom, under all the relays, is a voltage transformer that tells the controller which voltage you have, replace it, and problem will be corrected. If you are not comfortable with this, call Turbo Chef for a local servicer, and call them to repair.
As for the F6 EC error, you are having a temperature problem due to the control area overheating, there is a blower on the back, and vents on the front, and side, either these are clogged, the fan grid is clogged, and the interior has alot of dust coating the interior of the right side, please unplug, vacuum, and clean out the dust etc.., after reassembly, after about 30 minutes of operation, the blower on the back should be on, if not you need another.
Mar 21, 2009 | TurboChef TORNADO Electric Oven
Turbo chef oven F6 ec code
Feb 04, 2009 | TurboChef TORNADO Electric Oven
OVER HEATING
Hello. If the SSR is closed, and the oven is off, then the SSR is bad. You can call turbo chef for a part supplier,if you are able to replace it yourself, at 1800 90turbo.
Dec 16, 2008 | TurboChef TORNADO Electric Oven
My turbo chef oven
The wave guide cover is a simple fix the problem being that after it is replaced you should have a leak check performed I dont know if you have a source to rent a refractomemter to perform this test. Most honest service companies will have a ref meter to check for rad leakage.
Nov 10, 2008 | TurboChef TORNADO Electric Oven
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
