Question about Garden
My 950d Kobota engine blows black smoke while under a load and will shut off.
  • 177 Answers
Sounds rich carby service required
Posted on Jun 07, 2010
Why is my cub cadet xt1 blowing black smoke cleaned air filter made sure oil level is correct.still blows black smoke
Make sure that at full throttle the chock is not being used. Black smoke coming out of the exhaust of gasoline engine is a sign of a rich fuel mixture (too much fuel, not enough air). A brief puff of black smoke may be visible during hard acceleration when the fuel mixture goes momentarily rich, but under normal running conditions and idling the exhaust should be transparent. If black smoke is visible all the time and the inside of the muffler is coated with heavy black carbon deposits, it would tell you the engine has a rich fuel condition.
On engine, a rich fuel condition and black smoke can be caused by a stuck or maladjusted choke, a leaky metal or hollow plastic float inside the carburetor fuel bowl, or a fuel saturated foam plastic float, or an incorrectly adjusted float (set too low). A trestricted fuel filter may also contribute to a rich fuel mixture.
Jul 04, 2017 | Cub Cadet Garden
Blows black smoke and sputters
Hi David, The link below is a youtube video showing why and how to stop your motor from blowing black smoke...........CHEERS..
How to troubleshoot engine smoke color issues Must watch
Apr 28, 2016 | Garden
1992 Peterbilt 379 feels sluggish pulling load up hill and is blowing black smoke
have a turbo boost pressure test done under load on a chassis dyno
under load the boost should be right up
check for leaks in the intercooler hose fittings or cracks in the intercooler
black smoke under load indicates a faulty turbo or turbo air leaks.
May 13, 2015 | Cars & Trucks
Twin turbo 80 horse power deutz Diesel engine blows black smoke under load
Diesel engines smoke when under a heavy load. Unlike a gas engines, a diesel engine uses fuel that is more like an oil.Smoking is a good indication the fuel is not completly burning because of loaded engine spee. White smoke indicates the fuel is not ignitingefficiently. Truck, boats, tanks abd anything else using diesel fuel will smoke when it gets more fuel than it can use.. Easing up on the throttle will lessen the smoke but not eliminate.. Of coarse if the demand is lessened by applying less loadyhe fuel consumption drops.Not to worry as long as the smoke doesn't attract the EPA.
Sep 15, 2014 | Cars & Trucks
My 2001 xj cherokee TD blows excessive smoke when the engine is under pressure.
Sounds like a broken oil ring. As far as the engine stalling, if your really low on oil the motor will shut down so as not to damage any bearings and other internal parts. Does the engine seem to be turning over faster and taking longer to start than usual and take a little longer to stop when you turn the engine off. If so you could have an issue with the compression rings in one or more cylinders. Do a compression test. If the #s are near where they should be it's likley oil rings. If the #s are low it's likley the compression rings. Either way if its one of those issues you'll need to overhaul your engine
Jan 17, 2014 | Cars & Trucks
Excessive white smoke out of blow by
Just letting you know that white is water, blue is oil and black is gas coming out of the exhaust.
Jul 20, 2017 | Cars & Trucks
XJS V12, 1986. Loses power and splutters on hard acceleration
Most probably is the crank sensor under engine worn out. )0 % trobleshut starts here.
Einar Norway
Sep 27, 2008 | 1986 Jaguar XJSC
Duramax black smoke under meduim load and over heats
my twins 98 ford taurus has a problem. it started with the motor fan not shutting down it was shut off, then i shut down finally. they were driving to work this morning, when they got therethe car started smoking black smoke and throw all the water out. can this be a fuel pump
Jul 23, 2008 | Chevrolet 2500 Cars & Trucks
My landrover 2ltr tdi 2002
my freelander 2ltr tdi
is blowing out black smoke and has lost power
Jun 21, 2008 | 2002 Land Rover Freelander
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
