Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Red light Replaced lamp. Female connectors were never secured inside unit. Reoved back panel and secured female connectors. Installed new lamp. Strted TV, blinking green then the red light of death...Removed interlock switch and tried again....light would come on for 10s, then off for ~30, then on for 10, then off and the indicator light shows red. Ballast? Connection?
  • 1 more comment
  • vmantri Apr 10, 2008
    where can I get schematics (PDF?) of the area to replace caps?
  • vmantri Apr 12, 2008
    Update: I did nothing to the TV but just powerd it up thi monring. Now, they TV stays on and I get very ppro picture quality. Grainy lines appear and disappear on screen. Colors are not true. The bulb is staying lit and I can circulate through the TV menus.
    IS this stil a cap problem or something else?
  • vmantri Apr 19, 2008
    The Jamicon capacitors were indeed one of the issues. There were four (4) 16V 1000uF caps and two (2)Nichicon 10V 3300uF caps swollen and these were replaced. I bit the bullet and got a local Mistu tech to come out and replace the caps. The lamp now lights and I thought all was good but it appears (according to the tech) that the FMT board is having problems. This is the second issue. The tech had two other units (boards, rack, power suplpy etc...) pulled from other TVs ready to ship back to Mitsu...apparantly Mitsu does not just sent out replacement FMT boards and they are having the whole components pulled from tvs and then shipped out to MDEA. So while my lamp lights, there are still intermittent video distortions on the screen that appear every 10 seconds or so. Great picture one minute, then a fuzzy disturbance for ~1s then great picture again. I am hoping the FMT board does not go b/c that will add to my already growing repair bill...
  • Mitsubishi Master
  • 8,617 Answers
There are two 3300Uf @ 35V capacitors that will cause that problem they are located on the PWB. they are right next to each other and the only ones with that rating on the PWB board
Posted on Apr 10, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry Apr 10, 2008
    I would recomend going to the following link you can get the full service manual emailed to you for only 13.99 and they will provide free tech support by on line instant messaging with a support tech. That chassis is a little complicated to get aprt but the manual clears it up and with the tech support you shouldnt have any problems as its a straight forward repair. heres the link they email the manual within minutes of purchase.
    http://servicemanuals.vstore.ca/
  • Sonny Berry
    Sonny Berry Apr 12, 2008
    the mitsubishi dlp has the jamicon capacitor issues with the PWB, FMT and DM boards. the failure of the lamp to light is the two 1000uf caps on the PWB. any streaks or distortions too video is vauased by three bad 1000uf caps on the FMT, and then there will be a symptom of the green status light constantly blinking without stopping and no start up and that is caused by four bad 1000uf capacitors on the DM board. What happened was mitsubishi got a bunch of bad capacitors and they will need to be replaced. I am one of the repair techs at the link I posted above. That chassis is a bear to get apart, but the repair is a straight forward repair once you get to the boards.
  • Sonny Berry
    Sonny Berry Apr 21, 2008
    Thats the capacitors causing the problem on the FMT the board needs the 4 jamicon 1000uf @35V capacitors replaced
Tail light electrical connectors are fried, i need to replace the connectors cant find them online? help
Call your local junkyards to see if any of them have any Silhouettes in their inventory with tail lights still installed. If they do, remove the tail light that you need, disconnect the connector and examine the connector (both Male AND Female sides) to make sure it's not fried too. On mine, both the male and female pins connected to the green(Ground) wire in the vehicle harness that was corroded.
If it looks good, install the connector and cut the wiring on the vehicle side a foot back from the connector and remove the complete tail light assembly with the connector.
The Female connector is built into top of the Lamp Holder Assembly and since both pins are corroded, the Lamp Holder must be replaced at the same time as the harness side.
Cut the damaged part out of your car leaving enough of your harness to splice the wires together. I soldered mine and covered them each with shrink fit tubing at the joint then wrapped all the junctions with electrician's tape for protection and some water integrity??
By the way, the complete Tail Light Assembly cost me $40.00 and I wound up with a spare left lens!
Hope this helps.
Nov 06, 2011 | 2001 Oldsmobile Silhouette
Tip
Damage or Fire Warning on Samsung DLP Television
I was reading some articles in a website and i found out that there is a problem with the Samsung DLP.
If you don't install firmly the connectors may cause damage to both the ballast and the lamp and maybe you can get small fire...
i will add a picture of the connector and the link to the blog.
so if you are installing your TV lamp do it the correct way so this wont happen..
good luck
this is a connector image..
http://www.fixyourdlp.com/2010/03/22/damage-or-fire-warning-on-samsung-dlp-television-bp96-01653a-lamp/
Please read carefully!
FixYourDLP.com has identified a potential hazard that may severely damage your Samsung TV with lamp code BP96-01653A!
Samsung DLP lamp units, model BP96-01653A may fail due to improper insertion. We discovered this while doing some tests on these enclosures. If you don’t install the BP96-01653A firmly into the TV, the housing connector may cause damage to both the ballast and the lamp—or even worse a fire.
You’ll know immediately if there’s something wrong because as soon as you turn your television on, and there’s white smoke emanating from the back of your television.
You should shut your television off immediately and open your lamp door and pull out that lamp. Inspect it and hopefully, you’ve just burned the connectors to the ballast, and not the ballast itself. Our testing has only caused the connectors to burn or melt, but don’t take any chances—we’ve never seen a fire, but we also don’t rule out the possibility of fires either.
Here is a correct installation method and the reasons why a bad installation will cause the connectors to burn:
IMPORTANT SAFETY WARNING
Regarding the installation of a BP96-01653A lamp unit into a Samsung DLP Television.
Installation
Step 1
Figure A – Open panel, lamp unit removed
You must install the lamp unit to fit snug with the ballast connector.
To do this, align the lamp unit with the female ballast connector facing down, on the bottom side of the enclosure, then slide the lamp unit until it snaps into place. Check to make sure the unit is firmly inside the television.
Figure B – Snapping the lamp into place
Snap the wire brackets in tightly by lifting the bottom set up to meet with the top bracket. The wire bracket keeps the lamp and lamp enclosure seated properly to reduce the risk of fire.
when installed properly, the unit should sit secure and slightly elevated from the floor of the compartment.
Figure C – Close back panel securely
Once the lamp is firmly secure, close the back panel to engage the blue lamp door sensor switch. Leaving the door open will prevent the television from starting up.
Important Damage or Fire Warning
Because of the nature of the ballast or lamp driver, there is a risk of damage or fire to your television set.
The ballast ignites the lamp with up to 20kV of electricity to arc the gas tube inside. If the ballast does not have a firm connection with the lamp unit, the arc will occur between the ballast connectors (from the ballast to the lamp), which may cause a fire, or melt your plastic connectors. Indications of this are a rapid clicking sound, a burning smell, and/or a non-functioning lamp. If you improperly install the lamp into your television causing a ballast or lamp failure, this may void your warranty for the television or the lamp product.
on Mar 23, 2010 | Televison & Video
When I replaved samsung hls6767w lamp with hosing with new lamp with hosing I noticed burning smell.I assumed it is new lamp buring smell. After 15 mnts when smell did not go I removed power and when...
Most of the time the female end of the connector comes right of a part called the ballast. Ballast's are replacable. Is the aluminum melted? I am not sure where to purchase the ballast. The female connectors is ussally atached to frame with screws or sometimes clips
May 27, 2011 | Samsung HL-S6767W DLP TV
The brake lights sensor is on but nothing is wrong with my lights, what could it be?
Hi you probably have a faulty bulb but it hasnt blown yet check for blackning of the bulb glass
or even that you have the correct wattage of bulb its embossed on the side of the metal part of the bulb ,also check for any water seepage into the lamp unit or wiring that might cause corrosion
the bulb warning selfcheck system sends a control voltage through the lighting circuit on your car any high resistance in the circuit like a faulty bulb will put the warning light on the dash on to let you know theres a fault
Oct 22, 2010 | 2000 BMW 3 Series
99 silhouette.all bulbs are in working order.right (not left) signal flashes fast when headlights are on and even worse when brakes depressed(lights on or off).also lights on both rears are real strange on...
I had similar symptoms - rapid flashing of directional when headlights on and brake depressed when making a left turn, both directional indicators in dash light dimly when brake depressed, "Check Traction Control System" indicator On even with ATC turned Off and "strange" indications in tail lights.
Check the pins in the connector at the Lamp Holder Assembly for your Rt. Tail Light for arcing and corrosion. (The female pin is in the vehicle harness connector and the male is part of the Lamp Holder Assembly.) If found, because the male connector is part of the Lamp Holder Assembly, you'll have to replace the Lamp Holder Assembly and the harness section coming in from the vehicle containing the female connector.
I just repaired this problem in the left tail light on my '01 van with a part from a '99 van I found at a local salvage yard.
Jun 01, 2010 | 2001 Oldsmobile Silhouette
The signal connector came out back of T.V. Where abouts on back do I put it back in?
hope you mean the cable is disconnected, and not the outside threaded male connector that came as part of the t-v! if that's broken off, could be complicated to replace. if it's the cable (female, inside threaded- electronics can be a bit sexist at times!) then look at the back for 'cable or antenna in' carefully re-attach the female to the male connector. it can become frustrating to get them aligned properly. make sure the copper wire in the center of the female connector is straight!! so it fits properly!
be patient! if it's a 'push on', makes it easier, but not as secure. if it seems loose, a gentle 'squeeze' with pliers can tighten it up, very gentle!!
good luck!
Sep 09, 2009 | Panasonic TH37PX60 37 in. Plasma...
Question on the back ports on head unit
Hello BCRich356,
The USB input to the KDC-X993 is a cable hardwired into the back of the unit. To extend the length of the cable, you would need an extension with a male connector (like on the thumb drive itself) on one end and a female connector (like the thumb drive plugs into) on the other end.
There is no port on the back, it's hardwired. Just like the AUX cable.
Hope this helps.
May 05, 2009 | Car Audio & Video
The F connector has broken off of a Sylvania model 6520FDG set
Replace the connector with a bit of cable and a new female end. Go to Walmart or BigLots, buy a 6' extender cable (6.00) cut off the female end with 6" of cable, strip it back and solder in in(?)
Go to Dollar Tree, spen a buck and get a 3-way splitter. Take home, saw apart and get the connectors off the board inside (3 of them(!)
or... Check Mouser, Allied, Newark, Radio Shack, Ace hardware for the part.
. Good luck
(You need a Female, F-Head, PCB Mount connector
Mar 26, 2009 | Sylvania 6520FDG 20" TV/DVD Combo
"Replace plate" messge appears. I replaced it but the message remains!
Regarding "Replace Card" warning, 90% of the time it's the female metal connector on the red wire going to the spring metal connection screws... The connector can have a buildup of corrosion ( green) build inside of the crimped connection. In that case, the crimped connector will need to be replaced. The black wire may also suffer from corrosion, but to a lessor extent. The replacement crimps need to be stainless steel crimps. The copper crimps corrode easily. Another thing to look out for are loose connections. The final solution would be to replace the card, or see your friendly dealer.
Nov 08, 2007 | Ecoquest Fresh Air Air Purifier
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
243 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
