Stays on hello panasonic ez 27 - Televison & Video
  • Blas Perez Torres Nov 04, 2008
    I loose the remote control and on the dvd screen just say HELLO nothing more. How to resolve this problem?
    Thanks
LG told me:
Power on.
Push the powerbutton again and hold it.
After exact 5 sek. remove the plug from the 220V-wallplug.
Stop pushing the power-switch.
Wait 15 min and see...
In my case it didn´t work, so, LG told me, the Software will be demaged.
Posted on Mar 10, 2009
Will mounting sdv8622t/27 antenna higher improve reception.also if the booster stays dry is it ok to mount outdoors
yes, mounting the sdv8622t/27 antenna higher will improve its reception. The more the antenna goes up, the better the reception it receives. There won't be any interruptions if the sdv8622t/27 antenna goes higher. So, it is better if you mount the antenna higher as you intend.
As for the booster, it is not okay for the booster to stay outdoors. The booster should remain indoor, while the antenna stays outdoor.
I believe this is clear to you now. If you still have any more questions about your sdv8622t/27 antenna, please let me know as I would be please to respond to you.
Yours sincerely.
Elect_Comp.
May 24, 2011 | Philips Televison & Video
I need a remote 4 it
Hello
Just select a PHILIPS CL034 UNIVERSAL REMOTE CONTROL. Panasonic is listed in its codes. Codes are
............ 0718 0416 0007
........................... 0618 0807 0039 0739
........................... 0345 0696 0901 0608
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand.
OK.
Feb 07, 2011 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Need the remote code for this model tv
Hello
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Four digit universal remote code for Panasonic are:-
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Note: Switch OFF and switch ON your TV with its front panel power control switch [Main power control] each time before proceeding for an other code.
OK.
Jan 20, 2011 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
What is the tv//dvd/vhs remote code for pv-m2799 treple play como unit?
Hello
Four digit universal remote code for tv/vcr/dvd combo is
0437
Direct Code Entry
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand. OK.
Dec 09, 2010 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
Panasonic toughbook cf-27 cd/rw drive
www.Newegg.com is a great place to purchase this product. Nice laptop BTW...
Armymason
Feb 26, 2009 | Panasonic Toughbook 27 Notebook
DVD PANASONIC DMR-EZ 485V
El manual lo puedes encontrar en http://www.retrevo.com/support/Panasonic-DMR-EZ485-DVD-Players-manual/id/23134ci576/t/2/ aunque unicamente aparece la referencia en español en la pagina 96, como en el manual basico, ¿Necesitas algo especifico?
Aug 21, 2008 | Panasonic DMR-ES10 DVD Recorder
NEED TO CHANGE PHOTO RESOLUTION
■ Number of pixels
Select a higher number of pixels for clearer
pictures when printing.
Select a lower number of pixels [ ] (0.3M
EZ) to store more pictures. Fewer pixels also
means it is easier to send pictures by e-mail
or use them on a homepage.
■ When the aspect ratio setting is
[h]
DMC-LS75/DMC-LS70
(7M)
3072 × 2304 pixels
DMC-LS60 only
(6M)
2816 × 2112 pixels
DMC-LS75/DMC-LS70
(5M EZ)
2560 × 1920 pixels
(3M EZ) 2048 × 1536 pixels
(2M EZ) 1600 × 1200 pixels
(1M EZ) 1280 × 960 pixels
(0.3M EZ) 640 × 480 pixels
on the menu I believe the Panasonic calls it aspect ratio
Mar 06, 2008 | Panasonic Lumix DMC-LS75 Digital Camera
Cannot turn off cc
Yes. one of those six boxes are 'setup' box.
  1. go into setup and you will see cc mode (second from the bottom of the list).
  2. simply select the cc mode and make sure it is set at "off"
  3. exit the menu and you are set.
Regards,
Feb 16, 2008 | Panasonic CT-27G5 27" TV
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
