Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak ESP3 printer driver won't install on my Mac
SOURCE: Software Installation problem gets stuck - all in one Kodak ESP3 printer
I have a 6 year old Dell with XP, plenty of hard drive and memory. I could not scan using the software, I went on the Kodak website and followed the Step-by-Step Solutions and Repair which nothing worked, including the Kodak Clear Utility they reccomend for ridding your system of the software, it just locked up at the end.
So, I spent several hours on the phone with Technicians trying to uninstall and reinstall the ESP3 software. None of their methods worked even step by step manually un-installing every file and folder...
So I wrote a nasty email to them and they sent this back, which by the way, didn't work for me either, but maybe it can for you.
According to your email, the issue is that you have not been able to install the software for the printer on your computer. We understand the importance for you to have your printer working properly.
To help resolve this issue, please follow these steps in the order they appear:
1. Disconnect all USB devices from the computer, including the Kodak EasyShare all-in-one printer.
2. Uninstall the Kodak EasyShare 5000 series all-in-one software:
a. In the Control Panel, select Add or Remove Programs (Windows XP) or Program and Features (Windows Vista).
b. Select one of the following software programs from the list of currently installed programs, depending on which one appears in your list:
Kodak EasyShare software
Kodak all-in-one printer software
c. Click Change or Remove (Windows XP) or Uninstall (Windows Vista).
d. When the Install Wizard appears, click Next.
e. Depending on the issue(s) you are experiencing, do the following:
If you are experiencing errors with the Kodak EasyShare software, such as a Tricode, in addition to errors with the KODAK AiO Home Center software, select Remove, click Next, and follow the on-screen instructions for removing the software.
If you are not experiencing errors with Kodak EasyShare software, select Modify to uninstall only KODAK AiO Home Center software, and click Next.
f. In the Custom Setup window, select Remove from the drop-down menu for the Kodak All-in-One Printer, and click Next.
g. In the Ready to remove the program window, click Next.
h. In the Uninstall Complete window, click Continue.
i. Restart the computer.
3. Delete the files and folders that can interfere with the installation.
For Windows XP, delete:
a. Printer folder in C:\Program Files\Kodak
b. Both the Eastman Kodak Company and KDS_Kodak folders in C:\Documents and Settings\All Users\Application Data
c. Kodak 5000 Series AiO folder in C:\Documents and Settings\All Users\Application Data\Kodak
d. Printer folder in C:\Documents and Settings\All Users\Application Data\Kodak\EasyShareSetup
For Windows Vista, delete:
b. Eastman Kodak Company folder in C:\ProgramData
c. Eastman Kodak Company folder(s) in C:\Users\your name\AppData\Local
4. Run Disk Cleanup.
a. Open My Computer.
b. Right-click Local Disk (C:) and select Properties.
c. Click the Disk Cleanup button.
d. When the Disk Cleanup for (C:) window appears, select the Temporary Internet Files, Recycle Bin, and Temporary Files check boxes.
e. Click OK, and then click Yes to delete all files and begin the Disk Cleanup.
f. When the Disk Cleanup is finished, click OK in the Local Disk (C:) Properties window.
5. Shut down all background applications.
a. Select Start > Run.
b. Type msconfig in the Open field, and click OK.
c. Select the Startup tab.
IMPORTANT: If not all the applications in the Startup Items list are selected, write down which applications are selected so you know which ones to turn on again later.
d. Click Disable All , then click OK .
e. When prompted, restart the computer.
6. After the computer restarts, insert the KODAK EASYSHARE 5000 Series All-in-One Software CD into the computer CD drive to begin the installation.
a. Insert the printer software CD into the CD-ROM drive.
b. In the KODAK EASYSHARE 5000 Series All-in-One Software window, click Next.
c. Select CD Installation, and click Next.
d. Select I accept the terms of the License Agreement, and click Next.
e. Select Custom, and click Next.
f. Select Not Installed for every feature, and click Next.
g. When To begin the installation process appears, click Next.
h. Select Remind me later to register, and click Next.
i. When the Kodak Statistics Collection window appears, select Yes, and click Next.
j. When prompted, connect the printer to your computer.
k. Click Next when the Next button becomes active.
l. When Congratulations, your Kodak printer has been successfully setup appears, click Finish.
m. Click Continue, and then close all windows.
7. Before restarting the computer again, turn on the background applications.
b. Type msconfig in the Open field and click OK.
d. Under Startup Items:
- If only some items were originally selected, select the check box in front of the items that you noted in Step 5-c.
- If all background items were originally selected, click Enable All, and click OK.
8. Restart the computer.
Posted on Jan 08, 2009
SOURCE: i just got a new print head for my kodak esp3 all-in-one printer
hello.
with the printer ON, lift the scanner/top to access the cartridges. remove the ink cartridges. lift the gray tab gently with thumb and index finger of one hand. gently pull the print head up and out with the other hand. install new print head back first, then press target with thumb gently until you hear snap/click. reinstall ink cartridges.
good luck,
-k
Posted on Jan 09, 2009
sajid_najmi
  • 31 Answers
SOURCE: Error code 1-2036 on Kodak ESP3 printer
this error code is for printer scanner. run clear utility from www.kodak.com/go/clear
and reinstall kodak software from
www.kodak.com/go/downloads.
Note-  Do not connect your printer while installing the software untill installation wizard say to do so.
MS
Posted on Jun 14, 2009
  • 60 Answers
SOURCE: the kodak aio home center won't open getting error
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Posted on Jun 27, 2009
  • 285 Answers
SOURCE: how do I remove and replace printhead esp3
cartriges Take them out, push the button on the top left of ph and install new one, pushing on the thumb picture. then install cartriges.
Posted on Jul 03, 2009
Software disk will not down load can I down load the drivers etc online
Please go to the Kodak model ESP3 multi-function printer support page by clicking on the link below, or copy and paste into your browser.
Print the instructions for installationo of the software / drivers, then download and follow the prompts to install the Kodak ESP3 multi-function printer.
Make sure you select the operating system on your computer, ea XP, Vista or Windows 7.
Good Luck
http://support.en.kodak.com/app/answers/detail/a_id/36460/selected/true
Aug 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
I have lost my driver disk for esp3
Copy and paste the below URL to your address bar. Under "Select a catagory" select
May 31, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP3 printer will not connect with Windows 7
On June 8,2010 Kodak released a new driver for ESP3 printer.
Version 5.3.0 for Window 7
Download it HERE
Jul 08, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Can not install printer to my computer no disc
The driver is available at the following URL Just click on it and fill out the info needed on the page you arrive at and that's it. One driver.
http://www.printcountry.com/drivers/KODAK_ESP_3_DRIVER_DOWNLOAD.htm
Apr 21, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak esp3 all in one home center is saying disconected but it is not
Remove the esp3 driver on the printer setup window the restart your computer to redetect the device. Also make sure that the printer has no error and also check the connections.
Dec 10, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Disk for Kodak esp3
For this problem you could call the Kodak Technical Support, just tell them that the CD is broken and the drivers from the website is not working so that they could send you a CD
The tech support number is 1800 421 6699
Hope this will help
Thanks
Byron
Mar 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
262 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
