Question about RCA Televison & Video
For months when push power button on remote the green light flickered, sometimes for hours, until the tv finally came on. After awhile it even got up to 15 hours before the tv came on. Now the tv will not turn on at all, via remote or button on the tv.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please tell me the name of manufacturer and model number of the unit so that I can provide you with model specific information.
Thanks
Rylee
Posted on Jun 13, 2010
  • collins_jeff Jun 19, 2010
    RCA Colortrak 2000, Model No. F27201GG
    Thanks for your help.
  • Rylee Smith
    Rylee Smith Jun 19, 2010
    From what you have described it seems to be a horizontal/vertical circuit issue. You’ll need to open the back of the unit and check/test HOT (horizontal output transformer) and flyback, replace the part that has gone bad.This is only recommended if you have electrical expertise.Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
We've been experiencing the problem for about a month or so now you try to turn the tv on the green light appears then it shuts off... It does it with the remote and even when trying the actual tv tur
OK, need to know a few things before providing an answer on this one
1) Has the screen flickered in the recent past?
2) Has this ever occurred before?
3) Have you heard any noise coming from the monitor?
4) Has the screen grown dim or brighter lately
Thanks!
Apr 05, 2013 | Computers & Internet
No picture, No sound
It sounds that the IIC Bus circuit shorts bey some faulty components connected to it. The troubleshooting work to this section circuit is very skilled one. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 11, 2013 | Digital Lifestyle FA1B32Z 32 in. LCD...
I have a Sharp 32"
try checking the system for timer or sleep mode operation try to setting it off
Jul 16, 2011 | Sharp 25R-S100 25" TV
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
How to program my DISH Network remote to my DVD player?
It's kind of silly but I just pushed the VCR mode button, pressed the power on and off mode button & pressed the up button until the remote found the code. Took awhile but it finally worked.
Dec 28, 2008 | DISH Network DVR-625 DTV Receiver /...
TV will not turn on
the exact same thing happened to me but there is no red light when the TV is plugged sould i replace it?
Apr 17, 2008 | LG 17LX1R 17 in. HD-Ready LCD Television
Need codes!!!
1. Go to http://www.urc.philips.com/ 2. choose US URC modles 3. choose US2 4. choose US2-P63S. Really dumb but the owners manual states PH601S but in Philips web site its called US2-P63S -
Sep 07, 2007 | Televison & Video
Trisonic ts-rc488
OK EVERYONE I FOUND ALL YOUR ANSWERS , IM JOHN FROM NEW JERSEY JAC1NJ@AOL.COM , FOR THE TRISONIC UNIVERSAL REMOTE CONTROL , TC-RC488 AND MAYBE OTHERS , INSTEAD OF THE CODES THIS IS EASIER,TURN ON THE TV OR VCR ETC. FOR THE POWER MUST BE ON WHILE DOING THIS PROCEDURE , PRESS THE YELLOW SET UP BUTTON AND THE DEVICE KEY U WANT SUCH AS TV1 OR VCR1 AND HOLD THEM BOTH DOWN UNTIL THE RED LIGHT ON UR REMOTE STAYS ON THEN IMMEDIATELY AFTER HIT THE YELLOW SETUP BUTTON AGAIN UNTIL UR RED LIGHT STARTS BLINKING THEN POINT THE REMOTE AT YOUR TV OR VCR AND KEEP HITTING THE RED POWER BUTTON AS THEN YOUR REMOTE IS TRYING TO FIND A CODE AND WILL EVENTUALLY FIND A CODE , AND YOUR TV OR VCR WILL SHUT OFF , THEN THE RED LIGHT WILL BLINK LET IT BLINK UNTIL IT GOES TOTALLY OFF, THEN HIT THE POWER BUTTON AND YOUR REMOTE SHOULD WORK , SOMETIMES YOU HAVE TO HIT THE DEVICE KEY AND YELLOW SETUP KEY SEPARTELY AND THEN THE RED POWER BUTTON, I CALLED TRISONIC AND ACTUALLY HE HELPED ME AND I HELPED HIM , HE SAID I SHOULD WORK FOR TRISONIC , THIS IS A QUICK SEARCH , NOT REQUIRING ANY CODE NUMBERS, HOPE I HELPED YOU ALL SINCERELY , JOHN A.CLINE , CHECK OUT MY LIST OF LYRIC BOOKS AND MUSIC AT WORDCLAY.COM BYE!!!!!!!!!!!!!!!!
Aug 19, 2007 | Trisonic TS-1666RFS Remote Control
Televison & Video Logo
22 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
