Question about Bosch SHE4AM16UC 24 in. Built-in Dishwasher
How do I get my Bosch SHE4AM16UC dishwasher to pause and then start again at the same place it was in the cycle? I pushed the STOP button and then the START button and it started at step one. My dishes will be super clean, but all I wanted to do was pause it for a few minutes.
SOURCE: Bosch dishwasher SHX33A
I had the same problem. The motor had to be replaced. For as much as we paid for this it has not lived up to the Bosch name. It's never been as quiet as other people talk about, and then the motor went out! It's only 2 years old.
Posted on Sep 20, 2007
SOURCE: bosch dishwasher she45m
These dishwashers are designed for "passive drying" -- in other words, they do not heat the dishwasher in order to dry the dishes but leave them wet.  It calls the process "condensation drying" -- which is a fancy German term for "not dry them at all".  I greatly regret buying this dishwasher, for this reason and others.
Posted on Mar 30, 2008
SOURCE: Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
Posted on Apr 19, 2008
here2helpBSH
  • 27 Answers
SOURCE: Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Posted on Mar 19, 2009
buffalonyman
  • 1865 Answers
SOURCE: mold grows on dishes in bosch dishwasher
Put a bowl filled with 2 cups of clorox on the lower rack and run a wash cycle (nothing else in the machine) this will kill the mold spores in the machine, and clear the smell.
Posted on Jul 29, 2009
How to reset bosch diswasher sgs4332 au
hold the start pause button for 5 seconds, the display should then show 1 minute, when its finished its 1 minute drain cycle turn it off then on again
Feb 07, 2017 | Bosch Dishwashers
Bosch Dishwasher Model shu9915uc
ok sir! maybe you have defective motor thats why your unit is in abnormal power.
Oct 23, 2007 | Bosch SHU9915UC Dishwasher
Ifb dishwasher showing an error of 19h
How to reset / resolve Error 19H display IFB neptune DX
Follow following steps
1 power on the machine
2 push start / pause button
3 use + or - buttons to bring it to 0H
4 rotate cycle selector / circular knob to reset position
5 Display will change to 1.
6 again push the start/pause button to complete 1 min cycle.
7 after the display shows 0 . rotate cycle selector / circular knob to choose you preferred cycle.
Sep 05, 2016 | Dishwashers
My Whirlpool GU2400XTP83 stopped during the wash cycle and there is a blinking light above the "light" cycle button. I can not reset the dishwasher, stop or start it.
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times ina row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Sep 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Turn on dishwasher, goes to clean cycle right away.
My Bosch SHE4AM16UC was having the same problem of it going from active straight to clean, and there was water in the bottom making me think that there was either a clog or a pump issue. I took my shop vac sucked all the water out of the dishwasher including the down into the drain area for about 3 min until u think all the water is gone in the entire unit. Then I also took off the drain hose that was connected to either your sink or your disposal and held the shop vac over that area for about 5 min to get all the water and hopefully any clog that may be obstructing the drainage. Put the hose back on and hit start and it worked. So for me it was just a clog either deep in the hose or inside the unit. I hope this helps someone. TonyaB
Jan 19, 2011 | Bosch SHE4AM16UC 24 in. Built-in...
New SHE4AM16UC, professionally installed eight months ago. Worked fine with very light usage until now. Dishwasher starts normally but stops and signals "clean" after less than five minutes on any cycle....
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
All the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes). You should now be able to run the dishwasher as normal. If the issue returns, you could have a problem with the heating circuit (i.e. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 05, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Dishwasher signals "clean" inside five minutes
I would check tosee if your water meaning hot water temp is hook up correctly. i have seen cold water going to machine and causing the machine to do funny things. 1 the unit drains.2. it fills.3.it washes if the water is cold there is your problem .make sure b4 you start machine the water going in is hot. let me know how you made out maybe we can further check. p.s im a old bosch tech:)
Jan 26, 2010 | Bosch SHE4AM16UC 24 in. Built-in...
Bosch she4am16uc/01 not filling with water, can hear what I think is teh pump starting then it just sits there. Autoclean light just flashes and I cannot reset the dishwahser... any recommendations?
pull the dishwasher out and look inside the pan you more than likley have a leak and this is why it is not filling it has a safety so when it leak it will not fill with any more water.
Dec 27, 2009 | Dishwashers
Bosch SHE4AM16UC 24 in. Built-in Dishwasher Logo
783 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
