Question about RCA 32V430T 32" TV
RCA MODEL #32V434T
WHEN YOU TURN ON THE TV IT SOUNDS LIKES ITS COMING ON BUT SHUT OFF.
  • Philove May 13, 2008
    The color of the screnis apink tone and it shut back off.
  • SVTCobraLTD Jan 08, 2009
    Has anyone confirmed that its the high voltage transformer? Mine wont turn on. The red light next to the power button just stays lit when pressed.
It is the high voltage transformer
Posted on Oct 08, 2008
Mine does the same thing I'm thinking a fuse has blown out and if taken to a tv repair shop or finding the right size fuse you can fix or get it fixed yourself..
Posted on Sep 05, 2008
RCA 32'' TV
Unfortunately, the Power Supply has spat the dummy out. It is giving enough power to light the LED but not enough to run the set. To replace it will probably cost more than buying a new set. But ask around your local repairers for a price before you make any decisions...
Feb 23, 2010 | RCA F32444 32" TV
My 32v434t television.
The TV was making the clicking noise and not turning on because an internal error was being detected.
Now things had got worse , and something had blown inside the TV.
The burning smell and high pitched noise is coming either from Flyback transformer or PSU board. Repair is a delicate matter and must be done by a technician.
Jul 05, 2009 | RCA TruFlat 27F520T 27" TV
RCA 32V434T TV turns itself off and on by itself. Any suggestions on how to fix it?
When your tv turns on by it self you prob have the alarm set. For the tv to turn like a clock would go off when u need to get up. You need to check the the sleep/ wake up timer to see if it is set.
Jan 25, 2009 | RCA 32V420T 32" TV
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
RCA TV 32V434T transformer?
When the HVT goes out, it will take the HORZ output, in short, you will hear a high pitch noise for a sec, when pluged in. As to your question, Its not a hard repair, however its not what I would call a begainer repair. This is what make the high voltage (about 32,000 volts) for you set to work. If you DO try it, becareful. And don't forget to change Horz output p# 274762. After changing the parts, unit will not run for more then 10 seconds. You have to use a volt meter and set the G2 for 290v, with no signal and blue screen. + or - 5 volts will cause unit to shut off.
Tvman
Jul 14, 2008 | RCA 32V420T 32" TV
Rca 32v434T need part numbers
The H.O.T. Transistor number (original is 2SD3402 (which is no longer available)) it's replacement is the 2SC5902.
The H.O.T. Transformer part Number is RCA 271996
Oct 30, 2007 | RCA 32V550T 32" TV
RCA 32v434t
Has anyone confirmed what the problem is? Mine wont turn on. The red light next to the power button just stays lit when pressed.
Oct 22, 2007 | RCA 32V420T 32" TV
Power problem rca 32v434t
RCA 32V434T likely has a bad flyback--#271996. RCA 32F531T flyback no longer available,#262343 Fix one,dispose of other.
Sep 26, 2007 | RCA 32F531T 32" TV
Open Questions:
RCA 32V430T 32" TV Logo
418 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
