Question about Hayward Pool Products 25 Sq Ft Micro Clear Filter System w/ 40 GPM Pump
Is a Hayward cl-100 ef chlorinator the right model to use for a 27 foot round above-ground swimming pool. I am having trouble keeping the chlorine level at an adequate level (dips too low) even with the dial set at full chlorination.
  • 106 Answers
The cl100 should do the job. The first thing I would do is check the chemicals. Make sure you have enough stabilizer (cyanuric acid).If it's low your chlorine will not last long at all. Check the ph and alkalinity also. Make sure you are running the pump long enough. the cl100 only adds chlorine when it's running.
Posted on Jun 05, 2010
How much of a cup is 20 grams of granule chlorine
check the links, but best by far is an electronic kitchen scale as grams is a measure of mass (weight) and a cup is a measure of volume.
chlorine dosage calculations and measurements pool volume
www.swimmingpool.com.au/ChemicalBalanceChart.html
  1. Cached
  2. Similar
40 x 20 x 5, 12.0 x 6.0 x 1.5, 110,000 ... CHLORINE DOSAGE CHART (This chart is a guide only)DOSE PER 10,000 LITRES ... Granular Chlorine, 80 Grams ... Tables I-1 and I-2 provide volumes in drops (dp), milliliters (mL), teaspoons (tsp), ... The values moving down a single column represent how many of the units at the ...
Chlorine to prevent swimming pool water problems - POOL WIZARD
www.havuz.org/pool_pool/pool_maintenance/water_testing/chlorine.htm
  1. Cached
  2. Similar
When planning to buy a test kit to measure the chlorine levels in your pool, it is ... Take the water sample from at least 20-30 cm below the surface and at least ... As a rough guide, a pool needs about 600 grams of granular chlorine (2-3 cups) ...
How many grams of granular chlorine does a cup hold - Answers.com
www.answers.com > ... > Categories > Science > Units of Measure > Metric System
  1. Cached
  2. Similar
280 +/- 5% ... many grams in a tablespoon chlorine? Approx 20 grams ... How many cups of granular pool chlorine in one pound? 2 cups. 48 people found this ...
How to measure chemicals??? - Trouble Free Pool
www.troublefreepool.com > Forum > Swimming Pool Care > Just Getting Started
  1. Cached
  2. Similar
May 26, 2013 - 7 posts - ‎3 authors I've been using a measuring cup but I assume when hth says 8 oz....they mean 1/2 pound. ... Ha, found the answer on this video, guess they do mean fluid ounces. ... Using CYA granules for example - if my measuring cup said 32oz, that is 2 lbs, correct? ... 8638 gallon 20'x52" Intex ultra frame round AG.
How to measure Chlorine Granules? - What's The Best Hot Tub
www.whatsthebest-hottub.com > Hot Tub Forum > General > Hot Tub Forum
  1. Cached
  2. Similar
Aug 9, 2006 - 15 posts - ‎8 authors My question is, since I only have a 100 gallon spa, and the Chlorine Granules say to add 1/2 oz per 500 gallons of water, how do I know and ...
how to convert 10 grams into understandable unit? ' Yahoo Answers
https://ca.answers.yahoo.com/question/index?qid=20100527135338AAbL0Np
  1. Cached
  2. Similar
May 27, 2010 - I have to put 10 grams of powdered chlorine in my kids swimming pool ... But you can't use a measuring cup or tablespoon to measure mass ...
Nov 15, 2016 | Computers & Internet
First thing to do about chemicals for above ground sand filters
the values I set for my customers pools is as follows:
chlorine 1.0 - 3.0 ideal
ph 7.4
alkalinity 100 ppm
calcium 200 ppm
stabilizer 50 ppm (saltwater pool 25 ppm)
These values will provide balanced swimming pool water
Jul 01, 2014 | Blue Wave Sandman Above Ground Sand Filter...
My husband converted our 27 x 52 round above ground pool over to saltwater two weeks ago and we have yet to be able to get in it to swim. We drained all 18,700 gallons, scrubbed the liner and refilled the...
Wrinkles in your pool liner wall is a slight problem and can be a place for algae to grow, BUT can be treated and cleaned.. Algae will appear if your not providing the correct amount chlorine, regardless of wrinkles or not.. Let me tell you how I take care of my 14,500 gallon 18' X 33' X 48" pool using only the 8110 Intex model and hope you can apply some of my techniques to your pool and system...
In the 2 years I've own my system, I have not added any chlorine, even for those times my system failed and water turned green.. Yes.. I could have bought SHOCK and CHLORINE and added to my pool to kill the algae, but chose to vacuum, brush and set my chlorinator to max and did it without buying any of these expensive chemicals.. It took over 3 days to finally see results after running my system at at 12 to 14 hrs pump and 10 to 12 hrs chlorination.. After my pool cleared and chlorine level was at optimal, I lowered my chlorination to around 6 to 8 hrs.. Right now that the temperature is around 95 degrees, I run the pump for 12 hrs and chlorinate for 10.. My chlorine level is slight low and today I plan to raise my chlorination to 11 hours.. My pool water right now is crystal clear and clean. I vacuum my pool daily and check the electrolytic cell weekly for optimal results..
Now...you have a huge above ground pool, almost 19,000 gallons!!! To start.. you should have added almost 500 lbs of salt!!! and ran the pump only for over 24 hrs to properly dissolve the salt..
Next, you should test the water salt concentration level and should have been between 2000 and 3000 ppm. After the proper level and because your pool is so big, run your pump at 12 hrs or longer and possible 10 to 12 hrs chlorination...
You said the manual vacuum sucks up the liner??? They sell a nifty device that hooks up at the end of the hose and attaches at the skimmer inlet that has a relief spring activated door that prevents sucking up the liner and also, you may to look for a different vacuum head???
Bottom line... NO, the only way to clean the algae is NOT with vacuum and brush only..It could be done with SHOCK and CHLORINE.. I chose not to add shock and chlorine to mine.. But you will need to vacuum the dead algae and clean you filter several times..One more thing... I hope your chlorinator is big enough for your size pool.. The max gallons the manual shows is for a 14500 gallons, like mine... Good luck and hope this info helps...
Aug 14, 2011 | Intex Automatic Salt Water System for ...
My salt water pump keeps saying low salt. I have had the water checked and there is plenty of salt. I have cleaned the cell and it still says low salt. The pump is on;y 1 year old. I dont know what else to...
I suggest you clean the cell according to manual and try it then. If it keeps producing chlorine then keep swimming. If the pump is flowing water fully (if not clean baskets and filter) and it can't keep the chlorine above 2 ppm and you have 30 to 50 ppm stabilizer in the water then there is a major problem in the chlorinator. I don't trust the salt indicator on some chlorinators but that is less important than if it chlorinates. You can but salt test strips. I hope this helps.
Aug 12, 2011 | Intex Automatic Salt Water System for ...
Hello I have a 15x48 intex above ground Easy Set pool and saltwater system. All was working well for about a week and a half. I couldn't get my ph and TA levels right so I brought a sample to my local...
As a alternative to the cell, you could add chlorine, temporarily ... so the kids could swim right away.
If the manufacturer recommends vinegar, that is what you should use. Some people say muratic acid is effective in cleaning the device. Try cleaning another night.
Evidently, your water was on the acid side ... evidenced by the report from your pool professional.
In establishing good water balance, first it is important to remove all metals ... Second, get alkalinity set (anywhere between 80 and 120 with 100 being the goal). Next, pH should be set. 7.2 to 7.8 is a pretty wide range. 7.4 is the goal. Chlorine should now be introduced and 4 ppm is a good number but you can go higher, Some US States allow as high as 10 in commercial spa and hot tub situations. In your case, the chlorine you are making (or not making in the present situation) is not protected by Cyanuric Acid (sun screen for chlorine). Also called Stabilizer, any number between 50 and 100 is ok. 80 is the goal. With no Cyanuric Acid "protection", your chlorine will be gobbled up almost as quickly as you make it. Note, grandular type chlorine normally comes with Cyanuric Acid as an ingredient. Numbers above 100 should be avoided. Since the acid is persistent, the only way to get the excess out of the pool is to remove some water, which will also remove calcium and salt. Just be aware ...
Do you know what the salt rquirement is? The content of your pool? One particular manufacturer I am famliar with wants 2800 to 3400 PPM with 3200 being the goal. At that level, this particular manufacturers (not yours) device operates most effectively. I say this to stress you should be aware of the Intex standard and where your salt level is. You can measure this with a special kit from Taylor or you may have your pool professional check it for you.
Enjoy your pool - I hope this information is helpful. Thank you for your question @ FixYa.com
Jul 13, 2011 | Intex Automatic Salt Water System for ...
Hi, I have let my intex above ground pool go green over winter and with summer approaching don't know if I need to add extra salt or something else to get the pool ready for swimming. It is a 14 foot,...
You need to get liquid chlorine and add about 2 liters and let your pool filter run for a couple of days and in the mean time clean your filter twice daily. If the pool at this stage is still a little green add more chlorine and broom the bottom to stir it up. After this as once your pool is back to almost normal, clean the the filter again and add clarifya. To keep your pool in good condion over summer buy 2 pool floaters, put 2 chlorine tablets in one and blue block pool sparkle in the other and each week add 1 liter of chlorine. Hope this helps you as i have the same pool and i do this and don't have any problems. You can also add salt to your pool if you like but dissolve it in water before you add it to the pool.
Oct 25, 2010 | Intex Automatic Salt Water System for ...
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
What chlorine should i use for my pool?
You should use granulated CL in this pool. Maintain CL at 5 ppm - check daily.
Jul 20, 2010 | Intex 15' X 42" Easy Set Pool Complete...
Light brown algae(?), small 2 leafed clover growing in pool.
add a clarifier this will make particles bigger and will be more managable either through filter or vac
Jun 13, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
No chlorine reading
Salt is sodium chloride, you can only measure salt levels now as your CL (cloride) is bound to a NA (sodium). Table salt =NACL, Your Intex system will tell you if your salt level is too high or too low but your old test equipment for free chlorine will continue to tell you no chlorine as it can't react with the chloride any longer as it is bound to the salt. That is why they tell you you never have to add more because the salt stabilizes it. Your chlorine is there it's bound to the salt. Use the pool it's fine and it makes your water feel really soft! Just keep the salt level right and your fine> It's confusing as they call the unit a chlorine generator! I had the same issue, called Intex and they told me the above.
Jun 01, 2009 | Intex Automatic Salt Water System for ...
Hayward Pool Products 25 Sq Ft Micro Clear Filter System w/ 40 GPM Pump Logo
284 people viewed this question
Top Hayward Pool Products Pool & Spa Experts
Jay Finke
Jay Finke
ray gallant
Tom Chichester
Are you a Hayward Pool Products Pool and Spa Expert? Answer questions, earn points and help others
