Question about Car Audio & Video
Concept cc d1200 kepps shuting off as soon as i hook up remote wire i have 3 40 fuses in could that be the problem?
    Problem Solver:
  • 19 Answers
Not really but that's just my opinion. make sure the remote wire is not touchin against a ground wire. and make sure ur power and ground wires are hooked up correctly
Posted on Jun 06, 2010
How to install cc602
How do you hook up Concept amp CC-452.
Oct 31, 2010 | Concept CC-452 Car Audio Amplifier
I have a orion hcca-d1200 and it keeps shutting off and blinking protect light and the esp indicator light. what could be wrong with it?
Possibly a shorted output transistor. If it was the power supply you would be blowing fuses, which I assume you aren't.
Nov 23, 2009 | Orion HCCA-D1200 Car Audio Amplifier
No spark-2001 YZ250
hi mate ,,i wouldnt advise u disconnect the kill switch,,on one of these bikes,, cuz if and i hope it doesnt happen ,that u fell of in the middle of no where and trapped your foot in the back wheel the wheel will kepp spinning,,and u would have no way of shuting it off, unless u can stall it,,which is hard wen face down, ive nown it to happen,, any way if it has been pinched and didnt work any way then yes it would disable the switch
Mar 24, 2009 | 2003 Yamaha YZ 250
Python 474p remote start Van Won't run
first, is it an alarm, keyless entry, remote start, or combination of the three? if you're SURE its just a remote start, you need to find the control module. it will probably be a black box, probably a bit larger than a pack of cigarettes. you can usually identify an aftermarket component by its wiring; it wont look like it fits with everything else that the factory put in there. a dead giveaway is red power wires with an in-line fuse holder in them. THIS IS NOT FACTORY WIRING, THEY PUT THEIR FUSES IN THE FUSEBOX! the module should be either in the driver's kick panel area, or up under the dash around the steering column. when you locate the non factory wiring with the in-line fuses, pill them out. done. if you have any problems, email me at face2face11@bellsouth.net. (i am a mecp first class certified installer with >10years of experience)
Jan 13, 2009 | Vehicle Parts & Accessories
Why does the protect light turn on when i connect the RCA wire?
check the fuses an make sure nothing is grounding off the amp which will make it go into protect mode
Nov 26, 2008 | Concept CC-452 Car Audio Amplifier
I have a concept cc-d800a amp. now it doesnt work?
If you are not an electronic technician you might not be able to fix the amp your self. You can replace the power fuse if the amp does not come on. If it lights up, with out blowing the fuse again, then hook up a speak to the amp and an input. If it plays good. If not and you are not an ET then take it to a repair shop. Amps can usually be repaired, if the cost of repair is not more than a new one.
Nov 22, 2008 | Concept CD-2410 Car Audio Amplifier
Blowing the amp fuses
do you have speakers connected as well? do you have a volt meter
make sure you are getting + from both are you sure the remote is not a 5 volt line?
Jan 08, 2008 | Kicker KX120.2 Car Audio Amplifier
Ppi pc2600
If the fuse only blows after the remote voltage is applied, the output transistors are likely shorted. To eliminate the speakers as a possible fault, disconnect the speaker wires from the amp. Also disconnect the signal cables.
If the fuse blows without remote voltage applied, either the power supply transistors are blown or the B+ and ground are reversed (or they may have previously been reversed).
Oct 17, 2007 | PPI PC2600 Car Audio Amplifier
Concept CC-2502 Car Audio Amplifier
The amps are probably going into protection mode. The wires are most likely not hooked up correctly. Make sure you have a good ground, good power source, and the remote wire is run correctly. Also make sure the speaker output wires aren't touching each other, and you have the correct ohm load for the amp. What kind of speakers/subs are hooked up and how are they wired?
Sep 20, 2007 | Concept CC-2502 Car Audio Amplifier
Car Audio & Video Logo
89 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
